Question about Sunpentown WA-1310E Portable Air Conditioner
Wa 1310e mode switch
Cannot change mode
Toyota troubleshooting
Broken rings caused by excessive power maybe. Do a compression check, that will tell you.
Aug 06, 2017 | Cars & Trucks
Tip
What to do if your ricoh afficio 1022/1027/220/270 show sc542
First of all do not panic as the copier is in auto jammed mode.
Switch off the copier.Here the list you should do as the sc542 revealed your termistor in fuser unit is out of order.
1. Open the lateral door and take out the fuser unit
2. Below the fuser unit , you will see the 2 unit termistor with red plastic contact.
3 Replaced it both with the new one then reinsert the fuser unit in the copier back.
4.Closed the lateral door.
5.Switch on the copier,you should go into sp mode by push yellow[c] button follow by button 1,0,7 then push cancel button[red colour] for several seconds until the screen revealed you are in sp mode.
6. Switch off the copier for 1-2 minutes then switch on.
7. Wa la......it's working back as new
8.By doing this you will save several hundreds dollars by calling the techician isn't it.
Yours sincerely
on Apr 16, 2010 | Office Equipment & Supplies
Incorrect email address
Click on your username in the upper-right corner and select "My Profile". You may then change your email address and any other data.
Apr 02, 2013 | Computers & Internet
Jai un probleme avec un copieur Gesttner 3220 . A l ecran il me marque le code sc542 je demande de l aide SVP
Gestetner 3220 is similar to ricoh brand
sc542 means your termistor had to be replaced with new one.
if you know the technique, switch off th copier,the open the lateral door,take out the fuser unit.
under or below it you will find 2 unit termistor with red
contact . Properly replaced both with new unit then reinsert the fuser unit in.
Switch on th copier,reset the machine to sp mode
to get into sp mode ,you have to push yellow[C] button follow by button 1,0,7 then push red button[cancel] for several sconds until the screen show sp mode.
When you in sp mode, switch off the machine,then wait for 1-2 min then switch on the copier, wa la it's working. You should try it and it save your cost.
Apr 13, 2010 | Gestetner Copier
How do i change my noika e71 offline mode to online?
Hi.
If the SIM card that you are using is accepted on your Nokia, then all you have to do is turning off the phone, removing the battery for one minute to reset, and turning back on.
By default the phone will restart in Online mode, and eventually will ask if to switch into flight mode.
If the phone does not go online, that means that the SIM card is faulty, that the phone is not unlocked, or that there is no network where you are using the phone.
Try replacing the SIM card with one for what the phone wa originally locked. If that works, then take phone to a shop to unlock.
Nov 19, 2009 | Nokia E71 Smartphone
Hi, I have a Sony DSC-W100 cybershot camera that the mode switch has gotten flaky. If you just touch it, it switches modes and if you rapidly change modes back and forth from one end of the control to the...
Hi!
A common problem with the W100. It can be taken apart and cleaned, but unless you have experience in things like these, I would recommend you getting a new mode switch. You can get one from here http://hop.02.lv/UQ
I work for Sony.
Tom
Sep 26, 2009 | Cameras
Sunpentown WA-1310E Portable Air Conditioner Logo
13 people viewed this question
Top Sunpentown Heating & Cooling Experts
Steve F
Pete Norton
Michael Youngman
Michael Youngman
Are you a Sunpentown Heating and Cooling Expert? Answer questions, earn points and help others
