Question about VOX Jamvox Guitar Practice Tool Jam Vox Proaudiostar
Jamvox not responding - VOX Jamvox Guitar Practice Tool Jam Vox Proaudiostar
Mr. Andrew Taylor
Yes Hettie. That would be 6th April 1956. Usually the tuners will write what they did. The third entry will be fairly close. The first one is usually the date it left the factory, and the second is the first tune at the new owner, or in the shop if it is a display piece. The third would then be in its new home.
Better to keep followups in the original thread. That way all the people who have responded get a notification that you have responded back. Making a new post is hit and miss that I see it. You were lucky I did :>)
Jul 21, 2016 | Taylor Music
Pause when switching channels
in some models there are relays that are slower to respond than others. Contact Crate to see if there is a fix for your model.
http://www.crateamps.com/support/index.php
Jan 29, 2014 | Crate Music
Volume on the piano is less than half the volume it should be. Demo and play along songs play at full volume but keyboard wont no matter how hard the key is pressed, Is there a fix for this...
Pianos do NOT respond to keys pressed hard... they respond to FAST presses. If you have an issue with the piano, first go on record to activate your warranty. Most of these electronics DO have a setting that adjusts the "feel" which affects the loudness versus key velocity... Now here is a secret??? Shh... The manufacturers turn up the demos just like the advertisers turn up the commercials on the TV... I would suggest looking for the adjustment of feel, and if that doesn't get satisfactory results, find another and compare yours to another... if yours is still underperforming, exercise your warranty for repair or replacement.
Jun 11, 2011 | Williams Encore Digital Piano
I connected my Casio CTK 496 to Fruity Loops DAW. I am unable to send CHORDS and note duration information to the DAW. If i press a note, while the Keyboard is connected to my DAW, my DAW outputs the...
Oh, oh... that is often called the "Dreaded MIDI Drone".
There ccan be more than one causes, however two of those are this:
1. The receiving device either does or does not respond to the note off command or only responds to the note on command with zero velocity, which is also now interpreted as note off. Check the MIDI implementation chart to determine this.
2. Two MIDI commands have merged without using a MIDI merger which makes sure ONLY complete MIDI commands are sent. If the commands are mixed, dreaded MIDI drone is assured.
Sep 07, 2010 | Casio Ctk 496 Electronic Keyboard with 61...
Couple of keys dont respond well and I tried cleaning pad under keys
The conductive rubber pill contacts AND the traces oin the circuit board should be cleaned with 99% isoprophyl alcohol, nothing else. Use a Q-Tip moistened with the alcohol.
Jan 28, 2010 | Roland Juno-D
Roland GK-2A pickup. g string does not respond
I have the same problem. Only the 1st, 3rd and 5th strings respond. This is not a sensitivity adjustment. The unit does not see the strings. I called Roland and was able to purchase just the pickup itself rather that the entire GK-3. The pickup was about $35 but took 4 weeks to arrive. When it finally got here I was excited. It was not difficult to remove the old and replace it with the new. I plugged it in. NOTHING CHANGED! I believe and hope it ti the 13-pin cable. I have read where these cables are just poorly made and many users have spent a considerable sum on the cable, most recommending having one in reserve always as they are sure to go out.
Dec 31, 2008 | Music
VOX Jamvox Guitar Practice Tool Jam Vox Proaudiostar Logo
193 people viewed this question
Top VOX Music Experts
rhodesworks
David
David
Are you a VOX Music Expert? Answer questions, earn points and help others
