Question about Ariens Garden
Ariens model 935335 hydro tractor
Leaking what looks like grease around seal on axles also how to check fluid in transaxle model 935335 ariens hydro tractor
SOURCE: I have a 25 hp -50 Filling transaxle with fluid?
Hi, I will try to help you. In the rear of the tractor on the right hand side as you stand behind the mower if you get down and look at right over the axle you will see a small hose with a plug in the end of it and that is where you put fluid in. Hope this helps. George
Posted on Apr 20, 2009
riceski
  • 1851 Answers
SOURCE: 2007 craftsman dys 4500 model
Call your local sears company parts house they will fix you up.
Best of it
Posted on Nov 03, 2010
  • 153 Answers
SOURCE: looking for an owners manual/parts manual for
Hello, The top link is to Ariens directly and they should be able to help you, if you still need help please contact me. Thank you. http://www.ariens.com/corporate/Pages/OwnerManuals.aspxhttp://lawnandgarden.manualsonline.com/manuals/mfg/ariens/ariens_lawn_mower_product_list.html
Posted on Jun 06, 2011
SOURCE: I have a Husqvarna YTH 150 lawn tractor and the left axle from my transaxle twisted off.
Typically the axle is part of the transmission. Unless you have knowledge or experience in disassembling them you might want to just find another transmission and install it.
Posted on Dec 15, 2011
bahama_mama0
  • 7 Answers
SOURCE: Blown Tranaxle.
if it is still under warranty and it was from normal wear they will replace it but if not under warranty you'll have to buy a new one,and they can be costly.
Posted on Oct 06, 2012
LEAKING OIL right transaxle
Johnny, Transaxle needs a new seal. you can get or order your seal from any local small engine repair shop. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
TORO Wheel Horse Hub Removal and Transaxle Seal Replacement
Replacing oil seal on rear axle of Lawn Tractor 917 288250 ShopYourWay
2007 Craftsman 917 287210 Lawn Tractor with leaking Transaxle
Rebuilding lawn tractor transaxle Part 1 of 2
lawntractor transaxle seal Google Search Ord
Aug 25, 2016 | Garden
Ariens model 935335 hydro tractor leaking what appears to be grease or oil out of seal around the axle where it comes out of the transaxle also how to check fluid in the transaxle
look for a dip stick it may be color coded with a yellow end or their may be a tag directing you to were it is located the seal may be bad
Apr 14, 2014 | Ariens Garden
Axle seal
There is a plug about halfway up in the transaxle, fill till lube runs out. You will need a new seal in the unit eventually, but if leakage is not real bad you can just add the oil recommended by the manufacturer. Hope this helps, plese post solved on fixya.com. So I get credit for a solved problem if it does. If not, check back and give me more info.
Ariens mod 93604200 hydro tractor won't shift
Check all of your hydraulic fluid levels - if OK, look at the fluid - is it dirty? If so, you're filter is plugged and needs to be changed. Then find out how/why the fluid is getting contaminated.
Nov 16, 2013 | Ariens Garden
BAD TRANSMISSUION LEAK
Check the axle shaft seals where the two drive axles enter the transaxle. If leaking there the axle will have to be removed to replace the seal.
Look at the bottom pan of transaxle. If leaking from pan gasket, the pan will have to be removed and transmission drained to replace pan gasket.
There is a transaxle main shaft seal on the front of transaxle, hidden by the bellhousing that mounts to rear of engine.. If the shaft seal is leaking, fluid will be dripping from bottom of bellhousing, and when inspection cover is removed, fluid will be evident inside the bellhousing.
Check also the transmission fluid cooling lines, where the two lines exit the transaxle case, and go to front of car to an external cooler mounted in front of radiator, or going into a separate reservoir in the radiator.
Jan 18, 2013 | 2000 Chrysler Concorde
Hydraulics get were they won't lift anything like round hay bales etc.
can be a lot of different problems-check fluid level if low fill to proper level --leak in hydro line-check all lines for leak--air in system -bleed system -wrong hydro fluid in system-check for correct fluid---seal at pump leaking-check around pump--controls leaking not holding allowing back pressure--test controls for internal leaks repair or replace if necessary--hydro pump internal malfunction/valves/piston/gears-pressure test repair or replace if necessary
Feb 01, 2010 | Diesel Allis Chalmers 190xt Tractor...
2008 Husqvarna YTH 2348 is loosing power...
it has a leak from the head gasket,ive done many with the same problem.pop the head off and change the gasket,also check the rings ect while apart
Dec 30, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Tractor moves but buck and learches
If it is a hydrostatic transaxle check to see if it is leaking,if it is then there really is no economical repair to transaxle. If it isn't leaking then It sounds like the oil in transaxle is degraded.The transaxle is supposed to be a sealed unit requiring no service but over time the oil will get dirty enough to cause problems like you are describing.Remove the back hitch plate and look at the transaxle it will have a rubber vent hose or a 1/4 Allen wrench fitting on top. You will need to purchase a battery suction bulb from sears automotive and use it to remove as much oil from transaxle as possible. Warm the transaxle up first by running it around,then suction the oil out.Refill with a good synthetic motor oil 15w-50 or 20w-50 like Amsoil or Mobil 1.Do not use transmission fluid or hydraulic fluid. When adding the new oil back fill it to within 1.5 in from the top,be sure to allow this amount of air space in top of transaxle for expansion.
Aug 06, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have a 20 hp craftsman lawn( hydro gear transaxle ) tractor in terrific shape that losses drive on a grade. I replaced the worn drive belt and it was good for the first few mows, Now Im right back to...
It sounds like the oil in transaxle is degraded.The transaxle is supposed to be a sealed unit requiring no service but over time the oil will get dirty enough to cause problems like you are describing.Remove the back hitch plate and look at the transaxle it will have a rubber vent hose or a 1/4 alllen wrench fitting on top. You will need to purchase a battery suction bulb from sears automotive and use it to remove as much oil from transaxle as possible. Warm the transaxle up first by running it around,then suction the oil out.Refill with a good synthetic motor oil 15w-50 or 20w-50 like Amsoil or Mobil 1.Do not use transmission fluid or hydraulic fluid. When adding the new oil back fill it to within 1.5 in from the top,be sure to allow this amount of air space in top of transaxle for expansion.
Jul 15, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Apr 06, 2009 | Craftsman 26 Hp 54" Deck Yard Tractor
Garden Logo
Top Ariens Garden Experts
Phil Walker
Phil Walker
Matt Olenzek
Matt Olenzek
enb54
Level 1 Expert
Are you an Ariens Garden Expert? Answer questions, earn points and help others
