Question about Sharp EL-738 Scientific Calculator
Coeficient de determination - Sharp EL-738 Scientific Calculator
    Scholar:
  • 74 Answers
To get the coefficient of determination you need to be in STAT mode (press MODE and choose 1 for stat) and then choose 1 for line (it only works for linear data). Type in your coordinate points (type in the x value then press the button next to ENT that says (x,y) and then type in your y value and press ENT. Your screen should then say DATA SET = 1.00.
Enter a few more coordinates.
Then to get your coefficient of determination press ALPHA (the blue green button under 2nd F) and press the ( button (above it in blue you will see r). Press = and there is your coefficient of determination.
Posted on Nov 26, 2014
Mon ecran reste noir meme s'il est ouvert
Hello Nicole Savard,
Tres peu de choses peut etre determinee sur vos ennuis sans votre num?ro de serie et le modele !
Avez-vous essaye de brancher un moniteur externe... ?
Sinon, vous pouvez essayer d'avoir votre technique soutien, connectez-vous A distance... et verifier votre machine pour voir ce qui peut etre determine A partir d'un emplacement distant..
I think(?)
Good luck...
Computer Parts Laptops Electronics and More Newegg com
Apr 01, 2016 | Computers & Internet
Amw528 error5
Microwaves have fault codes to help us determine the problem. Click the link below, it will take you to the Panasonic Combi Microwave site. Look at the manual closely. Either the fuses are blown or the microprocessor board is fried. Good Luck and be careful! Safety first! Commercial Microwave Ovens Large Microwave Commercial Kitchen Appliances...
Feb 05, 2016 | In Microwave Ovens
What makes my 1998 cadillac de ville have acceleration problems
If there is a "service engine soon" light on, have the codes read by an auto parts store and determine the fix. If no light, determine if the lack of acceleration is accompanied by missing like misfiring spark plugs. Bottom line in my opinion is no acceleration is either a lack of fuel, or failure of the spark advance..
May 07, 2014 | Nissan Quest Cars & Trucks
TENGO UN A IMPRESORA LEXMARK 4550 NO ME FUNCIONNA EL CENRO DE SOLUCIONES ME DICE QUE FALTA EL PROGRAMA CUAL ES GRACIAS ?
primero tienes que determiner que sistema de operacion tienes en tu computador, ejemplo: windows xp , vista, o si es apple y despues si corre a 32 o 64 bit esto si es window, una vez que tengas esa informacion puedes ir "http://support.lexmark.com/index?segment=SUPPORT&userlocale=EN_US&locale=en&productCode=LEXMARK_X4550&page=product&frompage=null#1
y bajar los drive ese es para que funcione tu impresora con tu computador, y firmware para que puedas controlar tu computadora. o si aun tienes el cd que dice driver and software que usualmente viene con tu impresora es solo de poner de cd en el tray de tu computadora y seguir instrucciones
Jan 12, 2013 | Office Equipment & Supplies
Which port on Pentair Water # 261152 does the pump connect to?
Thank you for posting your question here on Fixya.com.
This is a tough question because it is hard to find this info on the web and a different port is used for DE filters and sand filters. On sand filters the top port of the filter is the inlet while on DE filters the bottom port is the inlet. With the valve not connected to the DE filter and in the FILTER position determine which port allows water to flow to the bottom outlet of the filter. This can be easily determined by running water from a hose into the bottom port and whichever is the pump port will have water coming out of it. A similar test can be done for the other ports. I hope this helps.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved! Thank you
Aug 28, 2011 | Pentair Pac-Fab 2" DE Filter Multiport...
String trimmer engine starts. head won't turn.
If your trimmer has been used for a long time you probably need to replace the centrifugal clutch. The high friction coeficient ferodo gets warn out and power dose not get transfered to the drive shaft.
Another problem could be the driveshaft itself. If yo overloaded the machine (for example by hiting a tree or rock) the driveshaft or a linckage could have broken
The only solution for this problem could be to disasemble the drive mecanism and see what is wrong.
Jun 29, 2011 | Troy Bilt 17Inch 31cc 2Cycle Gas Powered...
P0735 relacion incorrecta gear 5 vw bora 2006 solucion
P0735 VOLKSWAGEN - Gear 5 Incorrect Ratio
P0735 se detecta cuando A / T no se puede desplazar a la posición 5 ª marcha incluso si el circuito eléctrico es bueno.
Notas técnicas
Empieza por inspeccionar el nivel de líquido de la transmisión y el estado, y el líquido cambia si es necesario.
Este diagnóstico monitores de la posición real del engranaje de control de la relación de deslizamiento del convertidor de par calculado por el Módulo de Control de Transmisión (TCM) de la siguiente manera:
Convertidor de par deslizamiento ratio = A x C / B
R: El eje de salida de la señal revolución de la revolución del sensor
B: Motor de la señal de velocidad del motor del módulo de control (ECM)
C: Relación de cambio fijado en la posición del engranaje que supone la medicina tradicional china
Si la posición real del engranaje es más alto que la posición (5 º) supone por TCM, la proporción de deslizamiento será más de lo normal. En caso de que la relación es superior al valor especificado, los jueces TCM este mal funcionamiento diagnóstico.
Los síntomas:
- A la luz del motor (o motor del servicio pronto luz de advertencia)
- Cambios de la transmisión incorrecta
Posibles causas:
- La transmisión de bajo nivel de líquido
- Dirty líquido de la transmisión
- Turno de solenoides
- Problemas de transmisión mecánica
- Transmisión del circuito de control hidráulico
Espero que esto le ayude. Por si acaso, adjunto el detalle en ingles original.
Suerte.
P0735 is detected when A/T cannot be shifted to the 5th gear position even if electrical circuit is good.
Tech Notes
Start by inspecting the transmission fluid level and condition, and change fluid if necessary.
This diagnosis monitors actual gear position by checking the torque converter slip ratio calculated by Transmission Control Module (TCM) as follows:
Torque converter slip ratio = A x C/B
A: Output shaft revolution signal from revolution sensor
B: Engine speed signal from Engine Control Module (ECM)
C: Gear ratio determined as gear position which TCM supposes
If the actual gear position is higher than the position (5th) supposed by TCM, the slip ratio will be more than normal. In case the ratio exceeds the specified value, TCM judges this diagnosis malfunction.
Symptoms:
- Engine Light ON (or Service Engine Soon Warning Light)
- Incorrect transmission shifting
Possible Causes:
- Low transmission fluid level
- Dirty transmission fluid
- Shift solenoids
- Transmission mechanical problems
- Transmission hydraulic control circuit
Mar 11, 2011 | Volkswagen Passat Cars & Trucks
I'm trying to determine which AC/DC adapter to use with this device. Apparently the VDC should be 5-9V, is there a minimum/maximum current that you are aware of?
500ma (1/2 amp) should be fine.. It's imaterial if amp rating on power supply is higher, as the device will only use what it needs. A higher amp supply will simply run cooler as it not being demanded to run at capacity.
Dec 03, 2010 | D-Link DE 805TP/C (DE-805TP/C) Networking...
DE error in LG washing machine
are the taps turned on and is water pouring into the machine?
Jul 21, 2010 | LG Washing Machines
Sharp EL-738 Scientific Calculator Logo
71 people viewed this question
Top Sharp Office Equipment & Supplies Experts
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
