My Kenmore Oasis washer shuts off just before the spin cycle and flashes the code LF. If I open the washer and shake out the clothes to redistribute the load, and press start again, it will usually finish the cycle. Recently I have had to repeat the process several times. The number of minutes left in the cycle when I press start is 17. This washer seems to spin fast enough to launch itself into orbit! It seems a bit excessive, and likely to cause problems eventually. Just wondering if this problem is the computer or mechanical. Jennifer Mac
  • jen_benoit Jun 18, 2009
    the code was actually LF, not FL.  The load may be unbalanced in the spin cycle.
    Thanks for your prompt reply, I'll let you know if this works.
    Jennifer Mac
    Brigadier General:
  • Washing Mach... Master
  • 3,614 Answers
code FL - means Flood Condition FL flashes if any overfill condition occurs.
This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for FL to be displayed
With an overfill condition, the beeper repeats a warning every 10 seconds with no time-out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit.
Hope this initial info helps.
let me know for further clarifications
Posted on Jun 18, 2009
  • micromaster
    micromaster Jun 18, 2009
    sorry for that first solution:
    here is what the LF error means:;
    Long Fill
    If the water
    fill time exceeds ten minutes, the water valves are turned
    off and "LF" is flashed.
    • Press STOP/CANCEL to clear the display.
    if the Cancel does not solve the issue, try to do the FF;
    1. Check your fill hoses for kinks or obstructions, first.
    2. Then, turn the
      water supply off and remove the hoses from the back of the machine.
    3. Place one end of each hose inside the wash tub and turn both water
      supply lines back on to make sure you have good water flow coming
      through the hoses.
    4. Replace the hoses if they show signs of bulging,
      cracks, leaking and/or restricted water flow.
    5. Turn water back off and
      check the fill valve inlet ports on the back of the washer for
      accumulations of sediments in the screens.
  • micromaster
    It doesn't take much to restrict water flow. You can clean the screens
    with a cotton swab. If you check everything and still have problems
    with the error code popping up, I would replace the fill valve. It's an
    easier fix and less expensive than a control board. If you decide to
    replace the valve, it is located under the console on your washer, I
    believe. It's fairly simple with a couple of screws to remove on the
    console and a couple of connectors and hoses on the valve to remove.
    Make sure you unplug the machine and turn off the water supply before
    attempting. I hope you find this advice helpful. Let me know if this
    works for you.
What is error code LF
LONG FILL. Try cleaning out the screens at the hose connections.
Dec 22, 2014 | Kenmore Elite Oasis 27052 Top Load Washer
UL in digital display coming on during wash cycle. When washer is spinning during wash cycle it is very loud and the washer moves. We have had it repaired a couple of times. It will work for several...
Hi
Thanks for using FixYa. ULis displayed when the machine/motor control detects an off-balance load, and is steady on while the washer runs a mini-cycle to rebalance the load.
• Display clears if mini-cycle successfully rebalanced the load.
• If the mini-cycle is unsuccessful, uL will flash until the door lid is opened, allowing the customer to view and redistribute the load. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 27, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
On spin it show a code uL and sounds lik.e if the tank is lose and hitting the sides of the washer. The sound is very loud and the washer moves from its place a few inches.
Hi
Thanks
Rylee
Aug 26, 2010 | Kenmore Oasis HE 27082 Top Load Washer
Im getting a uL message on my spin cycle and I dont know why.
The "uL" message stands for "unbalanced load." Open the lid to the washer and redistribute the load if the "uL" display appears on the appliance.Redistributing the load should correct any imbalances in the washer and allow the washer to turn freely. Close the lid and press "Start" to restart the washer.
Jul 26, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Excessive noise during the spin cycle. we have owned the washer for 16 months. problem started 1 wk. the machine is level.
It's noisy Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Jan 03, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Constantly off balance
I have a kenmore elite oasis top loading washer about 3 years old. I took it apart and checked the springs and the rods and the plastic ends that hold the rods in place and all of them look fine. I run an empty load in the washer and it still goes unbalanced on the spin cycle. My water bill has tripled due to the fact that every load takes 3 to 4 washings. I need help please!
Jan 02, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Oasis HE shakes violently during spin cycle
Machine legs should be adjusted so that machine is level and standing on all four legs. The load in the machine should be evenly distributed. Utube has an excellent video on washing machine repair.
Nov 20, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Oasis has LF code on and won't reset
The LF code indicates "Long Fill" which means it is taking too long for the water to fill the washer (times out). From the owner's manual:
"LF" (Washer is taking too long to fill)
Check the following:
Are the water inlet hoses kinked or clogged?
Are the water inlet valve screens clear?
Press STOP to clear display.
Here's a suggestion I found that worked for me:
Check your drain hose to see it it's stuffed too far down the standpipe. Another poster had this problem and it gave her LF errors. If the drain hose hangs down too far it can siphon water out of the washer, and then the washer thinks it's taking too long too fill. There's supposed to be a U-shaped plastic bracket that sets the length of the drain hose where it goes into the standpipe. Your installer may have tossed it.
Apr 07, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Sears kenmore elite he4t
Shaking is caused by poor distribution of clothes causing an imbalance. Try the machine empty. If it works well, be aware that you'll have to redistribute your load to stop the shakes.
Dec 31, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
Marvin
Marvin
