Question about Eureka 4700A Maxima Bagless Upright Vacuum
Wheels won't go down - Eureka 4700A Maxima Bagless Upright Vacuum
Drive belt won't turn
hi try w,d 4o spray on wheels each side
Apr 09, 2013 | Hoover U6437-900 / U6439-900 Windtunnel...
Robo sweeper
ARE THEY CLOGGED AROUND WHEELS WITH HAIR ,AND TRY SOME W D FORTY OIL ,
Apr 09, 2013 | As Seen On TV Robo Sweeper
DC18 won't stan up
here is dc18 foot repair video
Nov 22, 2012 | Dyson DC14 All Floors Upright Vacuum...
My Miele S3141 canister began acting strange this morning. No suction...so I took off the hose and checked for blockage, (nothing). Now I can't get the hose back on the canister. It just slips ar
see this causes and fix it. God bless you
Air filter:
If the vacuum cleaner won't pick up dirt and has no suction the air filter might be clogged. Remove the filter and either clean or replace it as needed.
Exhaust Filter If the vacuum cleaner won't pick up and has no suction the exhaust filter might be clogged. Remove and clean the filter, replace it if its torn or damaged.
Vacuum Hose If the vacuum cleaner won't pick up and has no suction the vacuum hose might be clogged. Remove the hose from the vacuum cleaner, stretch it out straight, shine a bright flashlight in one end and try to see light through it. If no light can be seen, use something to run through the hose and free up the obstruction.
Vacuum Bag If the vacuum cleaner won't pick up and has no suction the vacuum bag might be full. Clean or replace the bag as recommended by the manufacturer.
Dust Cup AssemblyIf the vacuum cleaner won't pick up and has no suction the dust cup assembly might not be installed tightly, or it might be cracked or broken. The dust cup must seal tightly in order to produce the right amount of suction. If it is cracked or broken, replace it. Most glues and adhesives will not successfully seal the crack.
Blower Wheel If the vacuum cleaner won't pick up and there is no suction, the blower wheel might be jammed or broken. Check the blower wheel to be certain it turns freely. If it doesn't, check to see if there is anything rubbing against it. If not, but it's hard to turn, the motor is most likely the problem.
Sep 27, 2012 | Vacuums
Small wheels missing scratches floor
http://www.ereplacementparts.com/hoover-s3765-windtunnel-bagless-vacuum-parts-c-37315_37445_37456.html
Here is a link I found. Since you listed the Product being an s, it won't be compatible with anything else other than an s.
Jul 28, 2012 | Vacuums
Sears canister vacuum rear wheel won't stay on
1) test the power cord for open, defective, or break use the VOM
2) test the fuse for open, loose wire use the VOM
3( tes the motor, for open, short, or defective, need repair.
4)test the switch, for open, or loose wires, or short.
see how to do it.
God bless you
Jul 10, 2012 | Kenmore 23612 Progressive PowerMate Bagged...
How do I put the rear wheel back on? Is there a diagram? I won't stay on any longer.
see the diagram.however you can download from www . retrevo.com or www.fitness.manualsonline.com God bless you-------------------------------------------------------------------------------------------------
Jul 10, 2012 | Vacuums
Hard to push
There may be a dial or something to set your unit to "floor" or low, and "High", all for the type of carpet or flooring you are vacuuming... change the setting to the middle or "floor"/ low.
On the other hand, here is a silly experience we may be sharing- sometime these units have wheels set so that, when the unit is "parked" or upright, wheels come down in the back, thus pushing the front down. You can turn it on, but the wheels won't go back into the unit until you move the handle from the upright position... My ex spent 15 minutes trying to get the vacuum to be normal- and all she had to do was just get the handle back at 2 or 4 o'clock position, and it worked fine...
if that's what you did- you aren't the only one! :-)
Good luck.
May 26, 2012 | Dyson DC33 Multi-Floor Upright Bagless...
Wheel won't stay on the vacuum hose
see the schematic and proceed according:
God bless you
May 09, 2012 | VAX Appliances Vacuums
My back wheel won't roll on my electrolux 2100. If I turn the cannister over, I can spin the wheel, but when I place it right side down, it just drags on the floor. How do I replace it?
Hi you need to find a local Vacuum repair place one that deals in Electrolux, and go there and take the vacuum or the make and model, and ask for a replacement part, that is the only way that you would be able to obtain spare parts, in fact while you are there, perhaps even inquire as to how much it may cost to do it? ask for a "Quote" and go from there.
Oct 07, 2011 | Electrolux UltraLux 2000 Bagged Canister...
Eureka 4700A Maxima Bagless Upright Vacuum Logo
21 people viewed this question
Top Eureka Vacuums Experts
JoeVacs
Alan Matzke
Alan Matzke
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
