Question about Samsung LN40A530 40 in. LCD TV
Samsung smart tv tools menu keeps popping up - Samsung LN40A530 40 in. LCD TV
Samsung smart tv. Menu bar on power right corner occasionally pops up. It doesnt work so I cant get rid of it except to unplugged it. What makes it come on?vwill it huurt anything?
hi don't keep unplugging your tv it will do damage, look in the menu on the tv for osd setting, look for the lowest setting thanks
shaun
Jun 12, 2017 | Samsung Televison & Video
Tip
How to find out the series number and model code of a Samsung Smart TV
1. From your Smart Remote press the Menu button
2. In the menu displayed in the TV , select the support option
3. Select Contact Samsung option in the Menu
This displays the Model number / code, firmware version and other details of the TV. Scroll down the popup menu to view other details of your TV.
on Jan 09, 2015 | Samsung "UN46D6000 46"" LED ""SMART"" TV "
Network issues with Samsung Smart TV UN60JU6500FXZA
You mention two separate issues, WiFi and smart hub. As you know Samsung built in manual is the worst idea ever. There is no picture of the complete rear panel connection for example.
If the smart hub is the actual WiFi antenna then if your system doesn't recognize Smart Hub then you have a bad smart hub.
to test smart hub plug something into hub ( DVD HDMI, video game) If your remote has smart hub button press and see what appears. Otherwise select source on remote see if your attached item appears. (That would indicate smart hub does talk to TV)!
Since you can access your network when hard wired your network password is stored.
Once you have verified Smart Hub is functional then work on WiFi.
i will say my Samsung is 3 ft from my router and hard wired for better streaming speed.
I use Bluetooth access to share photos from IPads.
I would leave TV hard wired.
Sep 20, 2016 | Samsung Televison & Video
How do I get the promo display off my screen on a Samsung PDP TV series 4+ 600hz
For this model, you will need to reset the TV and go through the first time set up again. To do this, use the remote when the TV is turned off and push mute, 1, 8, 2, power in that order. The service menu will come up. Select options, then factory reset. The set will then power off. Turn the set back on and go through the first time set up, making sure you pick home and not store. Hope this helps.
Apr 09, 2016 | Samsung Televison & Video
Is this tv a smart tv?
Good morning Shelly.
My Samsung smart TVs has a remote like the one in the picture.
In the middle, I hope you can see a multicoloured button that is to put on the smart function. It is best to go to menu on the remote, open Support and scroll down to Contact Samsung, go all the way down, there you see the model and make. You can also visit
Electronics Appliances Tablets Laptops Phones TVs Samsung US
Sep 29, 2015 | Samsung Televison & Video
How to cconnect netflix with samsung smart tv
I assume your Samsung TV has Smart features. If that is the case, you may need to do the following..
  1. Connect your TV to your wireless Internet. Using the remote goto Menu -> Networks -> Network Settings -> Wireless
  2. Select your network from the list and enter passwords if required.
  3. You can view the Network status option to see what you are connect to and the signal strength.
  4. Press the Smart feature key (multicolored key in the middle of the remote.
  5. Look for the Netflix icon near the top of the screen. It may take a short while to load so be patient.
  6. Enter your Netflix login account or select the free month option.
Keep in mind you may be asked to consent to some of the Samsung, Yahoo and other policies in order to use some features and they may collect information about what you view, etc. Read the policies found under the Menu. Also, this procedure works for the
May 25, 2014 | Computers & Internet
Security warning keeps popping up
Check for security settings in tv menu
Apr 13, 2014 | Sharp Televison & Video
Menu Keeps Popping Up
There is either a short in the menu button on the TV or it is sticking/dirty.
Jan 30, 2014 | Vizio 60" E601I-A3 Full HD LED-LCD TV
I have a samsung smart tv and a samsung galaxy s .My phone was accidentally denied and now im wondering how i can undeny my phone so i can use samsung smart view and samsung remote. Please Help!
Reset your TV.
With the power off - use the remote and push mute + 1 + 8 + 2 + power button.
When the set turns on, you will see a menu pop up. Just hit enter on the remote and you will see Factory reset. Hit enter again and the TV will reset.
Apr 10, 2012 | Samsung Televison & Video
Samsung LN40A530 40 in. LCD TV Logo
120 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
