Question about La Crosse Radio Controlled Atomic Clock
How do you set time on Timex T065S Solar Powered clock?
Timex number t235 clock radio, how do I set the time
easiest way to set clock time. Remove AA battery's if installed.
Unplug Clock from AC. Wait a few seconds. Then replug clock into AC power. Clock will now flash 12:00. Press hours button until correct time is set PM has led on AM has Led off. Set minutes to correct minutes. Then press alarm reset / power/mode button. Wait a few seconds and display will show correct time. Now you can put the AA batteries back in.
Apr 30, 2014 | Timex T065s Solar Powered- Radio...
How do you set the time zone on a Timex T065s alarm clock?
Press and hold the "UP" button for three seconds. Repeat until you hit your zone.
Feb 24, 2013 | Timex T065s Solar Powered- Radio...
I have a timex solar and the indiglo stoped and the wach is losing time the bat. Is new
your Timex watch is solar which means it gets power from light, you have to expose it on direct light to recharge your battery but if it not works you had to bring it to timex service center. i hope this will help you.
Aug 12, 2011 | Timex Watches
I need help setting the alarm on my radio controlled digital clock.
1- Turn over your Seth Thomas digital clock. Use your finger to remove the cover to the unit's battery compartment. Insert two AA-size alkaline batteries into the battery compartment and replace the cover. Certain Seth Thomas digital clock units will also have an optional alternate power source in the form of a standard AC power cable that plugs into a wall outlet in your home.
  • 2 Place your Seth Thomas solar-powered digital clock in front of a light source, such as on a window sill or beneath a lamp. The black strip on the top of the unit is the solar sensor, so as long as light is shining down on that strip, your clock will be powered on and ready to use. The sensor stores energy throughout the day so that it can work at night with no direct light contact on the sensor.
  • 3 Press the time zone button that indicates your current time zone. These buttons are located on the back of the unit. For example, if you are in the eastern time zone select the "EST" button. Turn the unit back over. It will now be displaying the correct time on its digital screen.
  • 4 Use the "Alarm" switch (if applicable) to enable and disable the clock's alarm. Press the "Alarm" button, followed by the "Hour" and "Minute" buttons, to set the appropriate alarm time based on your needs. Use the "Alarm HI LO" switch to set the volume for the alarm.
  • 5 Press the "Weather" button to tune your Seth Thomas digital clock to its built-in local weather radio station (if applicable). Certain Seth Thomas clocks have this radio weather functionality built in, while others don't. If yours does, the aforementioned "Weather" button will be located on the front of the unit.
  • May 28, 2011 | Seth Thomas Radio-Controlled Howard Wall...
    How do you set the digital time on the Timex Ironman Triathlon Solar Dual-Tech watch?
    There are two ways to find the user manual for your Timex watch.
    1. Find your watch on the list below and click on the language link for your manual.
    2. Find the 3-digit module number located on the caseback of most Timex products and click on the corresponding language link for that number in the Module Table.
    If you are still unable to locate your user manual, you may emailTimex Customer Service or call us toll-free at 1-800-448-4639.
    http://www.timex.com/info/Product_Instruction_Guides_Downloads
    Nov 20, 2010 | Timex Ironman Triathlon Solar Watch T5G691
    How do i change from the time after daylight savings
    Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all TIMEX watch manuals. Rate me, please .
    Apr 07, 2010 | Timex 5J261 Solar Powered Ironman...
    How do i set the time on my timex clock? its the nature sounds alarm clock pleas help
    press the time button and hold until the time starts to blink then use the < > to change the time then press Enter to set the time.
    Nov 13, 2009 | Timex Nature Sounds LED Clock Radio
    Operating instructions for timex t311t radio/alarm clock
    You can acces a PDF file of the manual at the following site: http://timexaudio.com/media/uploads/product/files/T311IB57574_35.pdf
    May 20, 2007 | Timex T311T Clock Radio
    Set CD Clock Radio for Daylight Savings Time
    just found a manual for another radio..timex website worthless but you hold the time or time set button down till the display starts flashing..then push the >>
    Mar 11, 2007 | Timex T309TT Clock Radio
    La Crosse Radio Controlled Atomic Clock Logo
    24 people viewed this question
    Top La Crosse Home Experts
    John
    John
    Are you a La Crosse Home Expert? Answer questions, earn points and help others
