Question about Toshiba 72HM195 72" HDTV
Toshiba 72HM196 yellow light blinks 3 times then repeats no other lights are on tv wont power up
premtech
  • 934 Answers
SOURCE: Toshiba 46HM94P
booboo43,
How's the lamp?? Sounds like a lamp failure which is the most likely problem with these units. The lamp for that unit is Toshiba p/n# 23311083x but a better source would be http://www.dlplampsource.com/ and they have it for $199.00 dollars with free shipping...
Posted on Nov 05, 2007
  • 668 Answers
SOURCE: Blinking yellow light ,no picture or sound.
You have done all you can do. If you had a power outage, when the power came back on a it surged and probably caused a Power Supply problem or something in the micro controller to fail. Either way it 's not good. I would call Toshiba and let them guide you to a Service Facility that can check it out. Depending on your Homeowners Insurance, repairs could be coverd or unit be replaced depending on cost to repair.
Sorry I am not able to help further,
skyassoc
Posted on Jun 23, 2009
SOURCE: Blinking Yellow light on a HD 65" DLP Toshiba TV
I have a 56 inch tohiba DLP (56 HM 195). Replaced the bulb for the second time this year. last time only lasted 3 months. TV is tough to turn on. When I get it to turn on, and then shut it down, the yellow light blinks constantly for 5-7 mintues. Then it shuts down completely. Is the set overheating? There is nothing in the manual that speaks to this issue. thank you
Posted on Aug 15, 2009
  • 18 Answers
SOURCE: My toshiba 50HN67 TV won't power on.
I have the same TV and had the same problems. What worked for me. I tuned off the set unbluged the TV, waited about five minutes and replugged and resolved my problem. Hope this works for you.
Posted on Aug 22, 2009
donzaca
  • 273 Answers
SOURCE: Toshiba 72HM196 TV. No picture but sound. Comes
la comvergencia tiene que revusar esa etapa porque es muy important
Posted on Aug 26, 2009
Tv not coming on has a blinking power button
Toshiba CX36F85 36" TV Blink - Questions - Fixya
www.fixya.com > ... > Toshiba > Toshiba CX36F85 36" TV
Toshiba CX36F85 36" TV, blink related issues. ... Every brand TV will have its ownblinking ... stand by light blinks 6 times, wont power on tv is only 4 years old. ...From the number of blinks occur at one time switch ON, you can get an idea ...
Toshiba CX36F85 36" TV Blinks - Questions - Fixya
Toshiba CX36F85 36" TV, blinks related issues. Get free help ... Every brand TV willhave its own blinking codes. From the ... Push power button and it ... and then ... stand by light blinks 6 times, wont power on tv is only 4 years old. Junk! it wont ...
Toshiba power light blinking not turn Standard (CRT ... - Fixya
www.fixya.com > ... > Standard (CRT) Televisions
Jan 10, 2016 | Toshiba CX36F85 36" TV
Wont turn on yellow light blinks 3 times pause and repeats no other lights on
If you can't get it on, you'll have to have a new Ballast assembly. Try unplugging it from the wall outlet. You may have to do this several times. Keep trying. If it won't start, probably the ballast. Always change the lamp with new if ballast gets changed. I got mine from Ebay.
Apr 14, 2014 | Toshiba 72HM196 72" Television
72hm196 toshiba dlp HD 1080. What is the problem of my tv when the yellow led lights is blinking and which parts need to fix it
It should be due to a problem to cooling fan [DLP]. If you wish to get more details about blinking codes, surf the site linked here. http://electronicshelponline.blogspot.com/ Pull up previous posts there, either by type in the model name to your set in its search box, or view it in Timeslide / Mosaic option.
Jul 13, 2013 | Televison & Video
What's your problem? won't turn on..... yellow/orange light continually flashes three times...
Toshiba Regza 37in - 37HL17
TV will not turn on - Yellow power ind. Light blinks three times...
Fixed with a firmware update (hard to believe, but true). Search Google for a file named: 2007SEN069.zip (don't worry if the page you find it on doesn't mention the 37HL17 - it worked fine). Unzip the file, and copy the 3 folders and 3 files to the root of a small SD card. The SD card MUST be 2GB or less in size (I used a 1GB card), and it MUST be formatted with FAT-16 (not FAT-32). Mine was pre-formatted as FAT (FAT-16). The SD port is on the back of the TV behind a cover plate near the power cable. You do NOT need to remove the back cover of the TV, just the small cover plate (1 screw). UNPLUG the TV; remove the cover plate; insert the SD card (prepped as explained above); Plug in the TV; Watch the yellow lights blink, then turn blue, then go dark; UNPLUG the TV; remove the SD Card and replace the cover; Plug in the TV; Yellow lights will blink a few times (this is normal); when blinking stops, turn on the TV and you should be good to go. :-)
Pictures attached are from a Toshiba software upgrade bulletin I found online.
09adb97e-8925-4d59-b218-7443a6e64989.png 82ea33aa-2353-4e13-a5db-8be13ba85711.png
Aug 06, 2012 | Toshiba Regza 37HL17 37 in. LCD TV
Yellowlight blinks 3 times on my toshiba 62hm116
If you are refering to the 3 yellow blinks repeated over and over the
boot data is corrupted. Download the firmware update(link below)from Toshiba and unzip the files and folders,copy the unzipped files & folders to a SD card (like a camera uses,I used a 2 gig). Unplug the tv and insert the card into the slot hidden behind the cover above the HDMI inputs. Plug in the tv and watch the yellow blinking stop and a solid blue will light when done. Unplug the tv, remove the card,plug in the tv and all will be good. You could now install the update per it's instructions.
Jul 04, 2012 | Toshiba 65HM167 65" Projection Television
My toshiba 65hm 167 wont come on
boot data is corrupted. Download the firmware update(link below)from Toshiba and unzip the files and folders,copy the unzipped files & folders to a SD card (like a camera uses, don't use bigger than a 2 gig). Unplug the tv and insert the card into the slot hidden behind the cover above the HDMI inputs. Plug in the tv and watch the yellow blinking stop and a solid blue will light when done. Unplug the tv, remove the card,plug in the tv and all will be good.
Jul 01, 2012 | Toshiba 65HM167 65" Projection Television
Wont turn on but yellow light is flashing
I followed the steps at the following link and it worked for me. I have a 2007 Toshiba Regza 42HL67, but the firmware applies to many models as documented in the readme file at the location found via the link below. I used a 1gb SD card formatted FAT16, copied the unzipped files and folder to the card (wasn't sure if it required the top level folder or only the files under the top level folder so I copied both to the root of the SD card), unplugged the TV, inserted the card, plugged in the TV, waited 2.5 minutes, unplugged the TV, removed the card, plugged in the TV, yellow light flashed 3 times and went out. I turned on the TV and it has worked normally since last night.
http://www.benjammin.net/www/pages/techtips/Toshiba-Regza-42HL167.html
Jul 23, 2010 | Toshiba REGZA 47HL167 TV
I have a toshiba 42HL167. Love it but recently when the power is off iget a repeating blinking yellow light. Blinks 3 times pauses blinks 3 time pauses blinks either 2 or 3 times then stops for 25 seconds...
Yes. The Yellow LED blinking 3 times is a normal boot-up, but if it keeps doing it -- it needs the firmware "update" (which is more like a reload because it got corrupted.) The problem is, no one talks about how to do that. (there is a PDF and firmware on toshiba's website, but it lacks some crucial details.)
My friend gave me his 42HL167 after this problem started after a power event during a storm and I managed to fix it by reloading the firmware.
I posted instructions on my website at:
Once I figured out some of the facts, it was a breeze...
Nov 06, 2009 | Toshiba 42HL167 42 in. LCD Television
Toshiba 72HM195 72" HDTV Logo
91 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
