E97 Maytag Affinity washing machine will not start. Get error code E97
SOURCE: AFFINITY ERROR CODE
door not close
Posted on Sep 09, 2007
  • 34 Answers
SOURCE: We are getting error code E3. What does this mean
Looks like you have either a stuck drum (does not spin) or an electrical fault that make the washer think the drum is not moving.
From a 2006 Technical Bulletin:
E3: Machine control is attempting to drive the motor but is not seeing any tach response. Visual Check shows motor is not moving. (Locked or Hall Sensor fault.)
Specifically, it could be:
1. Spin drum stuck – Verify that the spinner moves freely to eliminate this cause.
2. Hall Sensor (integral part of motor) fails or is loose – When the Hall Sensor fails or becomes dislodged, the control doesn't recognize that the motor is spinning and shuts down. The result will likely be an “E3” code in the worst case, or “SUdS” if it is only getting a partial rpm reading. Check wire harness connector(s) to motor.
Unless you are really overloading your machine you likely have an electrical fault, or a failure in the drive train--especially if the problem is intermittent. Probably time to call in a technician.
Posted on Aug 13, 2009
milten1
  • 1304 Answers
SOURCE: what does error code 5ud5 mean on m odel MAH
SUDS
IT MEANS YOUR USING WAY TO MUCH SOAP
for that model you should not be using more than 1 tablespoon
let is set for an hour or so then start a full load of towles with no soap
it should be fine after that
Posted on Oct 06, 2009
SOURCE: Maytag Epic Z with error codes F20 and F24
my epic will start & wash & then gets F 20 & won't drain until I hit start again
Posted on Jan 26, 2010
SOURCE: My Frigidaire Affinity washing machine says it
my affinty washer is stuck in pause mode
Posted on May 02, 2010
My brand new dryer has an E97 code. I have never got to use it.
brand new then get a service technician out for a warranty fix
don't touch it your self or the warranty is void
Mar 03, 2016 | Electrolux Dryers
What does error 90 Mean on an Electrolux Ewf 1087
E90 is family error code visible to the customers. It is necessary to read the error in the service mode so please proceed with the following procedure for rapid reading of alarm codes:
Press and hold down START/PAUSE and the option button nearest to the START/PAUSE button for at least two seconds!
After that the display will show one of the following errors that are more precise:
E91, E92 - Communication incongruence between main board and display board (versions not compatible). Posible causes: wirings, main board or control/disply board.
E93 - Incorrect configuration of appliance. Posible causes: Incorrect configuration data; electronic board faulty.
E94 - Incorrect configuration of washing cycle.
E95 - Communication error between microprocessor and
EEPROM. Posible causes: Electronic board faulty.
E97 - Incongruence between programme selector and
cycle configuration. Posible causes: Faulty electronic board (Wrong configuration data).
Considering that this is a complicated fault, my advice is to contact an authorized service center.They have special equipment such as an interface that allows them to upgrade software in your appliance. If you are not doing anything on the appliance before the failure, the only thing you can check is the contacts between wiring and electronics.
Dado
Feb 22, 2016 | Electrolux Washing Machines
AEG L87480 on desplay makers E91 what means
Dado
Jan 11, 2016 | AEG Washing Machines
Hi Ihave an electrolux EWD 1477 washer/ dryer. It keeps showing up an error E90 and starts beeping and stops working? Any ideas how to fix it ? Thanks kindly
Dado
Feb 12, 2015 | Electrolux EW1000i Front Load Washer
We have a LED code showing on the new Intex pure spa. E97 Dry-fire Protection. What does it mean
Aug 03, 2013 | Pool & Spa
Repair heating element feama e97
Are you installing a new element or do you need to get a new one make sure you get an element gasket as well. Element is on right side of machine. Drain water 14mm plug under boiler. There are 4 wires on element two labeled 3, and one labeled 1, the other labeled 2. Element has 4 coils in two loops, top loop and bottom loop. 1 on top loop 2 on bottom loop the 3's on the other side.
Jan 16, 2013 | Faema Smart A2 Automatic Espresso Machine...
Dont no my e codes definition on my 1993 cadillac deville i found codes E26,E32,E70,and E97 but I dont no what problems they represent
E26-shorted throttle signal switch
E32-open MAP sensor signal
E70-Intermittent TPS signal
E97-High RPM P/N to D/R Shift
some could be history codes not currents tho maybe try to clear then drive it and see what comes back.
Press off and high simultaneously to clear codes
and this link may help
http://www.cadillacforums.com/forums/ht4100-4-1-4-5-4/21558-obd-i-codes-4-x-engines.html
Oct 06, 2011 | 1993 Cadillac DeVille
I do not know how to program the shot size on a Faema E97 express can you help please?
Hold down the stop button and the button you are programing until the desired amount is reached the release button and stop button.
Jul 29, 2009 | Coffee Makers & Espresso Machines
Commercial Faema Espresso Machine with 2 heads, model #E97/A-2
It can be many things. If I understand machine start working (pouring water) itself, otherwise not working.
Probably your touch pads is bad, must be replaced. If I now more about problem mighty I can help more.
Mar 14, 2009 | Faema FA60081
23 Error Code.
Listing of Pentax codes E3, E7, E37: These codes often signal a problem with your shutter mechanism. E9, E93-E97: These codes may indicate a problem with your zoom lens. H0-H9: These H codes can also identify a problem with your camera's shutter. U1-U9: These U codes may also indicate a problem with your camera's zoom lens.
Jul 14, 2007 | Pentax IQZoom 60S 35mm Point and Shoot...
Washing Machines Logo
12 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
