Question about Canon PowerShot SD850 IS Digital Camera
My Cannon power shot SD850 is zoom lens grinds when it moves
Grinding noise while zooming
philipp
  • 217 Answers
SOURCE: lens will not close
Defective mechanism, a stucked mechanism is present. camcorder are smart it can detects error and shuts down itself for safety. earlier models dominoes the defect if the user is not quick enough to react when something goes wrong with the camera. You need professional service to fix it.
Posted on Nov 12, 2007
camerawes
  • 36 Answers
SOURCE: Canon SD 850 says lens error,
There could be a number of reasons for the lens error. ie. . sand in camera, impact damage etc. Typically the lens can be dissasembled and repaired by a competent camera repair technician. If you are certain that you did not damage the camera in any way I would send it back to canon for a warranty repair. If you however think you could have damaged it you are probably looking at around $100 to repair the camera. Hope this helps!
Posted on Jun 10, 2008
SOURCE: zoom browser ex for Cannon 350 D and Windows Vista
Use IrfanView (free) with the "Aquire/Batch scanning" option and you will be able to download the photos in batches, instead of one-by-one.
Posted on Aug 09, 2008
mcomijohns
  • 477 Answers
SOURCE: Canon g9 Camera was dropped. Now lens will open
Yes it is the lens is exspencive but it canbe replaced. cost on the lens is about 150.00 for parts and labor. could be more or less at other digital camera repair shops.
Posted on Jun 26, 2009
  • 11967 Answers
SOURCE: Canon E25 camera error
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Jul 10, 2010
Nikon AF-S DX 12-24mm grinding noise
sand or dirt may get inside your lens or may be you or or someone drop it. send to nikon for cleaning cost 50-70 bucks.
Mar 18, 2010 | Nikon AF-S DX 12-24mm f/4G IF-ED Lens
I bought a brand new 580 ex 11 flash unit. When I turn it on it makes a grinding type of noise and then the zoom in the upper right coner continues to flash. I can't test fire it but the pilot light is...
The grinding noise is the zoom head trying to match the focal length of your lens. A brand new one should NOT grind. It should be silent. It sounds like you got the one that fell off the pallet during shipping. Exchange it for another one.
Oct 28, 2009 | Canon Speedlite 580EX II TTL Flash
Lens makes grinding noise
yes dust in mechanism or broken gear but ti not easy
Oct 12, 2009 | Panasonic Lumix DMC-FZ5 Digital Camera
Grinding sound when camera is turned on
send to repair center...lens is off track
Aug 12, 2008 | Olympus FE-230 Digital Camera
I need help with my FE-230's focusing
in any case where the lens makes a grinding noise, something is in the channel and causing the lens to not extend all the way... you will need to send to a repair shop
Jul 31, 2008 | Olympus FE-230 Digital Camera
Zoom mechanism making noise
well i had the same issue and i just slammed it (carefully of course) on the desk and it started working.... does it still zoom or does it just click and grind? also try zooming in and turning the lens faster outward or the oppsite direction to see if you can jump it back into the correct place on the gears.... my best guess is that it got dropped or the kids sat on it... and it made the gears slip into a bad place....
Lee
Founder Of Free Tech Associates
www.whypayforhelp.org
May 27, 2008 | Nikon 18-70mm f/3.5-4.5G ED-IF AF-S DX...
Zoom
Lens probably got off its track. you need to take the front case apart and pull out the 3 lugs at the base of the outer lens. YOu should ba able to manage to get the outer lens off, dont worry about breakin git as the stuff is made of heavy plastic. If you get it off, see if the inner barrel rotates smoothly. YOu will be actig on a small motor so youll feel a little resistance, but it should be fairly easy to rotate. Lube the helical tracks with heavy white lithium grease and put the outer lens back on making sure to align the tracks, press the lugs back in and reassemble. worth a shot. I did mine and was successful. See my folder on the C8080 http://picasaweb.google.com/pishta68/8080lens/photo#5199141246863292738
Apr 24, 2008 | Olympus Camedia C-8080 Wide Zoom Digital...
Noise while zooming with sb-600
sb-600/800 make a distinct motor-spinning noise when zooming, this is normal. Any grinding/clicking noises are not normal.
Jan 25, 2008 | Nikon Speedlight SB-600 TTL Flash
Broken Zoom on Fuji Finepix F470
Try turning the power on and gently pulling the lens outward as it powers up. This may force the gears to re-align themselves. Use "fingertip" pressure only. Don't force it excessively. Also try turning on, and then applying slight pressure to the front of the lens while you power it off. You can also try rotating the lens barrel segments while it powers up or shuts off. Sometimes either can get the lens back on track.
Jan 20, 2008 | Fuji FinePix F470 Digital Camera
Soft clicking-grinding noise
i think that you have the full-time auto focus on.
go into the menu and turn it of and all should be fine.
seekreep from Edinburgh - Scotland.
Jun 10, 2007 | Olympus C-7000 Zoom Digital Camera
Canon PowerShot SD850 IS Digital Camera Logo
32 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
