Question about Canon Cameras
Zoom lens makes grinding noise when zooming in a Cannon power shot SD850 is
  • 374 Answers
SOURCE: My Casio EX-600 makes clicking noises when the lens comesout.
Lens error. send into casio repairs and they will fix it for you.
Posted on Nov 26, 2007
  • 28 Answers
SOURCE: finepix A400
If the "!ZOOM ERROR" message is displayed on the digital camera, switch the camera off and on again 2 or 3 times.
If this does not clear the error, take the camera to your nearest FUJIFILM Service Station for testing and repairs. Problem may caused by lens zooming gears stuck.
Posted on Apr 04, 2008
FreeTech
  • 426 Answers
SOURCE: zoom mechanism making noise
well i had the same issue and i just slammed it (carefully of course) on the desk and it started working.... does it still zoom or does it just click and grind? also try zooming in and turning the lens faster outward or the oppsite direction to see if you can jump it back into the correct place on the gears.... my best guess is that it got dropped or the kids sat on it... and it made the gears slip into a bad place....
Lee
Founder Of Free Tech Associates
www.whypayforhelp.org
Posted on May 27, 2008
  • 64 Answers
SOURCE: 18-55mm lens won't zoom
I fix it!
This problem is due to bad design (I think)
The problem is cause of the guards/holder/stand bends a little the you turn the zoom.
I bend the guards just a little to the left.
This get the guards to stand straight then you "zooming".
Perhaps a little grease can help too, but what kind do you use inside a kamera?
Posted on Sep 22, 2008
darntoothysa
  • 489 Answers
SOURCE: lens will not close
Hi
Your camera is still under warranty, and what you are seeing is a generic message that means there is an error with the lens operation. Please call Canon and have them fix it for you for free!
For others who's cameras are not under warranty, you will need to have your lens repaired or replaced if you get the error messages mentioned above.
A couple solutions would be to either buy a defective camera online and make one good camera from the two if you can do that sort of thing yourself, or secondly have it repaired by somebody.
Don't bother trying to send the camera to Canon (though you can call them and verify what I'm about to say) because they will want $150+ to do the repair for you. Parts are not cheap to buy from them.
I know of one very affordable digital camera repair business... because I own it. The name is Darntoothysam, feel free to check us out, we are on that big auction website also (I don't plug their name for free), our seller ID is 'darntoothysam'. If you Google "darntoothysam" you will find us.
We have your repair listed as a package in our store for about $70. This covers a new lens, and return shipping of your camera! We even give a 45 day warranty on parts and labor. If you think you can use us then please check us out, even if you need to ask more questions then please feel free to contact me.
Hope this helps,
Thomas
Darntoothysam com
Posted on Oct 15, 2008
On digital zoom or any zoom the picture is out of
Make sure its not set on Macro thats the flower ( tulip) icon no zoom will be in focus on this setting for average or long range shots
please rate my help++++Thanks for using FIXYA
May 08, 2010 | Canon PowerShot SD850 IS / IXUS 950 IS...
Lens makes grinding noise
yes dust in mechanism or broken gear but ti not easy
Oct 12, 2009 | Panasonic Lumix DMC-FZ5 Digital Camera
I need help with my FE-230's focusing
in any case where the lens makes a grinding noise, something is in the channel and causing the lens to not extend all the way... you will need to send to a repair shop
Jul 31, 2008 | Olympus FE-230 Digital Camera
Zoom mechanism making noise
Lee
May 27, 2008 | Nikon 18-70mm f/3.5-4.5G ED-IF AF-S DX...
Zoom
Lens probably got off its track. you need to take the front case apart and pull out the 3 lugs at the base of the outer lens. YOu should ba able to manage to get the outer lens off, dont worry about breakin git as the stuff is made of heavy plastic. If you get it off, see if the inner barrel rotates smoothly. YOu will be actig on a small motor so youll feel a little resistance, but it should be fairly easy to rotate. Lube the helical tracks with heavy white lithium grease and put the outer lens back on making sure to align the tracks, press the lugs back in and reassemble. worth a shot. I did mine and was successful. See my folder on the C8080 http://picasaweb.google.com/pishta68/8080lens/photo#5199141246863292738
Apr 24, 2008 | Olympus Camedia C-8080 Wide Zoom Digital...
Broken Zoom on Fuji Finepix F470
Try turning the power on and gently pulling the lens outward as it powers up. This may force the gears to re-align themselves. Use "fingertip" pressure only. Don't force it excessively. Also try turning on, and then applying slight pressure to the front of the lens while you power it off. You can also try rotating the lens barrel segments while it powers up or shuts off. Sometimes either can get the lens back on track.
Jan 20, 2008 | Fuji FinePix F470 Digital Camera
Zoom lens won't retract and stays out
check to make sure the battery is in right. also make sure the memory card slot is closed.
Dec 04, 2007 | Canon PowerShot SD850 IS Digital Camera
Lenses
Your camera's problem is with the zooming mechanism (lens would not retract or extended) Press the power button on and hold it down while extending and twisting the telescopic zoom lens. It might fix your problem. In any case it could not make it worse Good luck!
Aug 15, 2007 | Canon PowerShot SD850 IS Digital Camera
Cameras Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
