Question about Zodiac Pacer Pool Cleaner
My zodiac cleaner keeps climbing the wall and then sucks air
    Problem Solver:
  • 13 Answers
You need to adjust the suction down on the cleaner. This type of cleaner only needs about 10lbs of vacuum pressure
Posted on Feb 11, 2015
    Problem Solver:
  • 10 Answers
Is the weight on the hose that connects to the sweep. Mine are yellow or blue and with out them my sucker won't stay on the bottom.
my zodiac cleaner keeps climbing the wall and then - 9_2_2015_11_19_48_pm.jpg
Posted on Sep 02, 2015
  • 366 Answers
SOURCE: Our Zodiac Barracuda pool cleaner isn't working
you may have a bad diaphragm inside the unit. Unthread the nut between the "wagon wheel" and the lower unit and remove it, push down on the white tube until it comes out of the bottom of the barracuda. Inspect the rubber diaphragm for debris and deformations. If the diaphragm has a large gap inside, it won't work properly. It needs to have only a small uniform gap, they can sometimes even look completely closed when they are new. Replacing the diaphragm will most likely make the unit run like new again.
Posted on Nov 14, 2009
  • 10 Answers
SOURCE: Zodiac Baracuda Zippy Pool Cleaner hose tear
I haven't seen any bulletins on the Zippy hoses. You might adjust the flow to the cleaner. You can find the Manual for the zippy cleaner on this page beneith the diagram. It shows how the star control works. You can also contact the Mfg Technical Support at Phone: 800-822-7933 They might be able to warranty a hose or two for you.
Posted on Nov 05, 2009
  • 106 Answers
SOURCE: Zodiac Pacer pool cleaner not sucking water or moving
Remove diaphragm and check for rips or tears in plastic.
Posted on Jan 14, 2010
macdirk
  • 116 Answers
SOURCE: Cleaner does not climb walls
First of all do you have enough suction? The cleaner originally should have come with a suction gauge. If not the local pool store will have one. How old is your cleaner? When the G3 and G4 cleaners gets over a year or two a number of things wear out and effect the performance. Inspect the diaphragm especially next to and under the small retaining ring and make sure there are no holes or tears. If the diaphragm is over a year old they sometimes get too spongy and effect performance. Also the small rubber pad that holds the large pad can get worn down and stick to the floor and wall. As parts wear down you can get play or slop between the large disc, the small pad, and the foot plate that snaps all the disc to the body. Also the rear cassette where the hose connects gets slop there as well. all of this slop, especially when combined can make the cleaner performance lack greatly. very common to have a cleaner not climb the walls or reach the far end of pool as it once did
Posted on Sep 18, 2010
SOURCE: my zodiac pool cleaner keeps comming out of the
Put more water in the pool
Posted on Feb 03, 2011
Why is the zodiac hanging upside down
air trapped in hose or "Hose memory too high" plastic has a memory from its mfg that needs to be relaxed or will cause cleaners to flip over and stay high on walls leave hose straigh out and roll over several times to relax the hose, helps if it's a warm day .
Oct 16, 2014 | Zodiac Pacer Pool Cleaner
G4 keeps heading for and climbing the sides of the pool, always making a long run along the side walls of the pool. The bottom is not being cleaned. Have adequate lenght of hose. Diaphram has no holes....
If these pool cleaners are staying on the edge on the pool, there are two things that you can do to correct the problem. First, reduce the flow through the cleaner to the low side of the ideal range. Second, add a hose weight about 3 feet from the cleaner's head. That should correct the issue.
Apr 15, 2011 | Zodiac Baracuda G4 Automatic Pool Cleaner...
Barracuda climbing walls almost to be out of the pool. Sometimes I think it is high enough to **** air.
There are several adapters on the market to allow more water to bypass the cleaner. One is called the Vac-Mate, another is the Hayward skimmer adapter. I personally like the vac-mate. but it's only compatible with most skimmers.
Apr 03, 2011 | Zodiac Baracuda G4 Automatic Pool Cleaner...
Having problems with my KK keeps climbing the pool wall and sucking air, I've tried changing the length of the suction tube but it still wall walks. Any ideas ?
Check to ensure the pool cleaners dive float mechanism is operating freely and the dive float restrictor is installed. Check the automatic regulator valve for its proper installation and ensure it is not clogged
with debris. Make sure the water level is at least 3 inches below the pool deck. Finally, be sure that the cleaner is operating at the proper speed of 8-12 feet per minute..
Feb 10, 2011 | Universal Kreepy Krauly In-Ground Pool...
My cleaner works for a few minutes, climbs a wall and rolls over onto it's head.
If the problem always occurs when the pool cleaner starts to climb walls, there are a few things that you will want to check. First of all, if your pool has a vinyl liner, this pool cleaner has limited climbing ability. You need to check the flow of water through the cleaner with your flow gauge. It might be low. If it is, increase the water flow. Also, make sure that your hose weight positioning is correct. The cleaner should sit at a 45 degree angle at the bottom of the pool when resting when the weights are right.
Nov 08, 2010 | Zodiac Baracuda G3 Automatic In Ground...
Sep 12, 2010 | Zodiac Baracuda G4 Automatic Pool Cleaner...
The barracuda just returns to the deep end of the pool and stays there, how can I get the cuda to sweep the whole pool?
The Barracuda Zippy is an Above Ground pool cleaner and is not designed for a pool that does not have a flat bottom. They are generally not capable of climbing slopes, walls, etc.
Apr 19, 2010 | Zodiac Baracuda Zippy Pool Cleaner
Barracuda Pacer comes right up the side and above waterline then sucks so much air, pump has to be reprimed. Really annoying
You just need to slow the cleaner down and dirvert some suction away from it. It should never really come anymore than 1/3 the way up the wall.
Mar 29, 2010 | Zodiac Pacer Pool Cleaner
May 31, 2009 | Zodiac Pacer Pool Cleaner
Zodiac Pacer Pool Cleaner Logo
211 people viewed this question
Top Zodiac Pool & Spa Experts
Colin Stickland
Colin Stickland
john h
Jay Finke
Jay Finke
Are you a Zodiac Pool and Spa Expert? Answer questions, earn points and help others
