Question about Samsung SMH9187 Microwave Oven
Reset over stove microwave - Samsung SMH9187 Microwave Oven
My frigidaire microwave fan turned on by it self. Won't turn off. Blowing air above Microwave
Try unplugging it for a few seconds or turning off the circut breaker to it. This usually resets the unit.
Jan 03, 2015 | Microwave Ovens
My fan for the stove reduces power once the microwave is turned on
you must understand that any manufacturer has the proper design engineering from to save electricity, etc. And they using the new concept of reingeenering.
If the microwaves do not HEAT and working, do not worry.
Mar 06, 2013 | Microwave Ovens
I Have a GE Spacemaker over the stove microwave. I think it is 1000 watts. It's 7 years old. Everything works but it doesn't heat anything. There is 23 volts going to the fan unit in the...
HELLO.
Since there is an amount of volts from the outlet, the fault is from the microwave breaker.
The solution is given below.
Reset the microwave breaker.
Take the back cover of the microwave off with a screwdriver.
Inside you will find a motor.
Most microwave motors have a small red reset button on them. Hit that button.
Your microwave should work again if the breaker was the issue.
Thanks
Sep 21, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Can you put and over-the-counter microwave over a stove?
Yes, that is what they are made for, As long as it has a vent that can be used to vent the smoke from cooking it can be mounted over the stove. Normally the bottom of the microwave should be mounted 16" to 19" above the stove top. The microwave must have a vent with a blower motor in order to be used above a stove top. Most have a thermal switch that will turn the microwave vent on once the temperature reaches a set point.
Jun 12, 2010 | GE Spacemaker 1.7 Cu. Ft. Over-the-Range...
I have a Roper Microwave mounted over my gas stove
Usually you should have at least 12" - 18" AND a fireproof "Barrier" as the "Roof" of the stove "Floor" of the microwave shelf.
Jan 20, 2010 | Roper MHE14XKB Microwave Oven
Kitchenaid Microwave went blank
Is there a reset button or something I am not aware of?
May 20, 2009 | KitchenAid KHMS155LSS 1000 Watts Microwave...
I HAVE A OVER THE STOVE MICROWAVE MODEL JVM1443BK02 WHEN SOME THING IS IN THE STOVE OR ON TOP AND I GET STEAM , IGET A F3 ON THE PANEL I KNOW IT,S THE SMART BOARD BUT I UNPLUG THE MICROWAVE FOR 10 MINUTES...
First of all, be sure the microwave's hood vent exhaust fan is on whenever you cook on the stove top! That's essential to protecting the controls of the microwave.
If this still happens even though you use the fan, then your keypad or controller is likely failing, and we can help you with our $39.95 nationwide repair service.
Please reply back and let us know how it goes.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
May 21, 2008 | GE Microwave Ovens
Samsung SMH9187 Microwave Oven Logo
21 people viewed this question
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Henry  Thomas
Henry Thomas
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
