Question about LG 32LC2D Television
Check ir sensor on lcd - LG 32LC2D Television
My TV is not responding to my remote, How can I fix this?
Check and replace its remote control sensor [IR sensor], inside the TV. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Sep 01, 2015 | Polaroid 1913TDXB 19 in. LCD TV/DVD Combo
What is the cost of a sensor and is it hard to replace
No most of ir sensors are very cheap and the replacement is very easy but make sure that this is tha faulty one because ir sensors are very difficult to malfunction
May 20, 2014 | LG 42LC2D 42 in. LCD HDTV
Ir sensor may be defective
It may be a defective remore control,They are infrared light to test one get a digital camera aim the remote directly at the cameras lens push remotes buttons you should see the pulses on the cameras lcd screen,the human eye can't see IR light but the cameras sensor can,quick test ,
Mar 06, 2014 | Vizio M550SL - 55" Class 54.64" viewable...
Ir sensor is not working
check to see if your remote is actually working, If you have a digital camera with an lcd display point the remote at the camera and push a button on the remote, if the remote IR light is working you should see it light up thru the camera when you press the buttons.
Dec 20, 2013 | Vizio M420SL 42 in. HDTV
Does the power board on a tv control the buttons on tv and remote sensor
no i would suspect the the IR board or main board ..also check remote with a ir remote tester to make sure it works
Jan 07, 2013 | Toshiba 46SL417U LCD TV
Remote sensor is bad on my Philips 42PFL3603D/F7 LCD TV. Can I fix it?
Yes just replace the IR sensor board very easy to do. You can get the repacement IR board from www.tvcircuitboards.com
Dec 13, 2012 | Televison & Video
My remote wont work rca 40 inch lcd
Check the remote by looking through a digital camera at the remotes light while pressing the remote buttons if you see the light then the remotes working and you most likely need to replace the IR sensor. You can get the remote and the IR sensor from www.tvrepairworld.com
Nov 09, 2012 | RCA Televison & Video
KDL32L5000 IR SENSOR NEEDED
Contact the nearest Sony Authorised Service center.
Apr 02, 2012 | Sony KDL32L5000 32 in. LCD HDTV
Televison & Video Logo
21 people viewed this question
Computer Repairing
Computer Repairing
