Question about Boating
1998 evinrude intruder 150 starving for fuel
Starving for fuel won't run unless you pump the bulb
  • 99 Answers
SOURCE: 1997 Pontian Grand Prix Seems like its starving for fuel, pump has been replaced
try the injectors and email me at meanness628@aim.com with any other info or questions
Posted on Sep 30, 2008
  • 376 Answers
SOURCE: 7 hp craftsman Briggs/stratton lawmnower stalls
Your engine model # 128602 Type 0212-E1. Forget about ordering from Sears and paying shipping and waiting a week. Go to your local Briggs and Stratton dealer (most shops are) and buy part # 694395. Should cost about $3.00
Posted on May 31, 2009
  • 33 Answers
SOURCE: Starving for fuel?
my car juzt recentl;y had the same problem.. i went through every fuel method possible.. the caddeltic converter... the fuel ignition... fuel pump.... fuel sensor...... it ended up being the fuel pump in the end but it could be any of these... the 300zx 88 has a recall for the fuel injectors from nissan. if ur car is elible you can take it to nissan for free to be fixed.. try to take it to a mechanic and have them put it onn the computer. like i said it could be many thing so no one can just know what it is from discription. have to get it checked out
Posted on Jun 01, 2009
  • 3 Answers
SOURCE: engine won't run unless primer bulb is being pumped
I have the same problem and may have a solution. I looked at the primer pump and it was cracked letting air into the system. When I pumped it my finger was over the crack and it worked fine. When I stopped the crack was able to **** air again. Take a look.
Posted on Jun 20, 2009
  • 14 Answers
SOURCE: engine will not stay running unless i pump the ball...
Going to sound silly, but is the fuel filter properly installed? I've seen this happen when the fuel filter was installed upside down. In other words, the arrow showing flow of fuel was pointed in the wrong direction. If the fuel ball is collapsing, it could be a vacuum lock problem. Try it with the gas cap loosened and see if that helps - it could be 'too airtight' and creating a vacuum, which cuts off fuel supply.
Posted on Aug 10, 2009
Changed the fuel pump &fuel filter and the fuel relay starts up wont stay running.
Check the air filter and the duct that goes to it. starving a car for air is as bad as starving it for fuel.
Jun 13, 2014 | Cars & Trucks
Won't stay running
Have you checked base fuel pressure with a gauge ? Does it have a pump in the tank and also on the frame ?
Mar 12, 2014 | 1989 Ford F 150
Chugs
fuel filter or a fuel pump could also be plugs, wires, cap and rotor I would try fuel filter first then take a plug off a cylinder and hold it close to screw driver or something(dont hold unless have rubber to grip to please dont get shocked) if it doesnt spark your not getting spark and try plugs wires cap and rotor if it does spark then open gas lid have someone turn ignition switch on and listen if you here the fuel pump is still good if not replace it. It does sound like a fuel pump
May 31, 2013 | 1995 Chevrolet Monte Carlo
Starts perfectly but won't idle
are their any codes either stored or open might be a fuel supply issue is it starving out or just stopping if just stopping check all related fuses if starving for fuel check fuel lines fuel filter back to the fuel pump. also it could be an injector issye
Jul 07, 2012 | 1989 Mazda 626
McCulloch mcc1635a chainsaw won't run. Acts like it is starving for fuel.
take off the muffler and try it there is a screen inside that get plugged up with carbon you can open the muffler to clean it
Jun 03, 2012 | McCulloch Mcc1635a 16-inch 35cc 2-cycle...
Won't stay running. its like its starving for fuel
REPLACE FUEL FILTER AND AIR FILTER, FIRST.IF ENGINE STILL WONT STAY RUNNING COULD BE FAULTY FUEL PUMP.CLOGGED FUEL INJECTORS.
Jul 10, 2011 | 1990 Chrysler New Yorker
My bike will idel but won t rev. just cuts off
Starving for fuel.
Make sure carbs are getting fuel.
Make sure fuel filters are clean,
make sure fuel pump is working.
If carbs are getting fuel but wont rev, you need to clean your carbs because your jets are clogged
Dec 03, 2010 | 2000 Suzuki GSX 750
I have a 1991 ford f-150 starving for fuel. obd 1 scanned a code 95. replaced in tankfuel pump. still starving for fuel?
code 95 refers to secondary pump that is located on the frame rail. Could be bad pump could be wiring to pump.
Sep 22, 2010 | Ford F-150 Cars & Trucks
After replacement of fuel pump, now fuel filter & won't run......
try running the car without the filler cap fitted..you may get your answer(hope so )
Apr 21, 2010 | 1999 Chevrolet S-10 Pickup
May 30, 2009 | Craftsman Garden
Boating Logo
44 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
