Question about Samsung WF328AAW Front Load Washer
SAMSUNG WASHER DIAGNOSTIC TEST - Samsung WF328AAW Front Load Washer
How to run diagnostic
Maytag Bravos MTW6600T Top Load Washer Run ... - Fixya
www.fixya.com > ... > Maytag Bravos MTW6600T Top Load Washer
Maytag Bravos MTW6600T Top Load Washer, run diagnostic test cycle related issues. Get free help, solutions & advice from top Maytag experts.
Maytag Bravos MTW6600T Top Load Washer, run diagnostic test ccu related issues. Get free help, solutions & advice from top Maytag experts.
Maytag Bravos MTW6600T Top Load Washer Diagnostic ...
Dec 02, 2015 | Maytag Bravos MTW6600T Top Load Washer
D3 ERROR CODE
1) this error indicate error with the door swtich, test the switch for open or defective see the video + diagram and troubleshooting.
However run the test diagnostic.
2) test the timer, contacts dirty, loose wires, break or burn repair wires.
3) the motor can be faulty, for winding burn or overheating need repair or replace
Jun 19, 2012 | Samsung WF203ANW Front Load Washer
Samsung WF209ANW front load washer -- ND error code. I cleaned debris filter and all hoses, however it still will not drain. How can I tell if the drain pump needs to be replaced? Is there a diagnostic...
Hello & Welcome to FixYa
ND error in your Samsung Front Load washer indicates no drain issue. To start with check the drain hose for any clogs and try cleaning it, then check restriction in drain pump assembly or loose wire at the pump. Please get back to me if you have any other questions.
Kevin
Sep 25, 2011 | Samsung WF328AA Front Load Washer
Washer shuts down showing F1. after 4 or 5 tries washer continues to work but clothes are very clean
Keypad/User Interface Failure
F then 2 flashes when in:
Diagnostics Test mode if a stuck key is detected.
Standby mode if there is a user interface mismatch.
DISPLAY (Saved Code) EXPLANATION AND RECOMMENDED PROCEDURE
Console and Indicators
This test is performed when any of the following situations occurs during the Console and Indicators Diagnostic Test:
None of the indicators light up No beep sound is heard Some buttons do not light indicators None of the indicators light up:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P11 connector is inserted all the way into the machine/motor control.
2. Visually check that the user interface assembly is properly inserted in the console assembly
3. If both visual checks pass, replace the user interface assembly.
4. Plug in washer or reconnect power.
5. Activate the Console and Indicators Diagnostic Test mode to verify repair.
6. If indicators still do not light, the machine/ motor control has failed: Unplug washer or disconnect power. Replace the machine/motor control assembly.
Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
No beep sound is heard:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P5 connector is inserted all the way into the machine/motor control. If visual check passes, replace the user interface assembly.
2. Plug in washer or reconnect power.
3. Activate the Console and Indicators Diagnostic Test mode to verify repair.
4. If replacing the user interface assembly failed: Unplug washer or disconnect power. Replace the machine/motor control assembly. Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
Some buttons do not light indicators:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the console electronics and housing assembly is properly inserted
into the front console. If visual check passes, replace the user interface assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.&^#$
Jun 24, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
What does f1 mean on a cabrio washer
Apr 24, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
My washer comes up with f1 code
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.*(@#$%
Apr 06, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Our washer flashes acode f1
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!#%^
Mar 19, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Error code f1/f2 --washer turns off
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.*$%^
Mar 03, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
When washer starts get F1 error
Nov 28, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Samsung WF328AAW Front Load Washer Logo
49 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
