Question about LG 32LX4DC 32 in. LCD Television
Control boix control box is already removed?
Is it posable to bypass immobilizer the car has a siemens comp box 5wk46922 the immobilizer has been removed and is now lost please any help will be much apreshiated
If the immobilizer has already been removed, the only parts that the box controls are the door lock solenoids. The indicator wiring may also be connected but the box is not needed for them to operate.
Jun 08, 2015 | Cars & Trucks
2001 fiesta my horn isn't working, would it be the fuse?
could be fuse , horn switch, horn itself or wiring. if you have a multimeter place across the horn terminals on dc volts and have a friend sound the horn, do you get 12 volts on multimeter, if not then your horn is ok . check your fuse box for any blown fuses. most fuse boixs have detail on lid of which fuse does what.
Feb 17, 2015 | Ford Fiesta Cars & Trucks
I cant find the heater resistor in my 2007 ford freestyle. have the glovebox out already
Do you manual or automatic heating control ? manual has resistor ,automatic has blower motor speed controller ! You did not need to pull glove box. You have to pull the lower panel under glove box .
  1. Remove the RH lower instrument panel insulator.
  1. Disconnect the blower motor speed control electrical connector.
  1. Remove the 2 blower motor speed control screws.
  1. Remove the blower motor speed control.
  1. To install, reverse the removal procedure.
Feb 14, 2015 | Ford Cars & Trucks
Why does the remote control for the converter box no longer work?
just get another remote for cable box, it may be bad.
Jan 23, 2012 | Televison & Video
When I attempt to watch a video, the video box tells me I need to download Adobe Flash Player, and it is already installed.It quit suddenly.
Go to your control panel select performance and maintenance select system then the hardware tab go to device manager and roll back the driver if this does not work go to your control panel and select add or remove programs. remove the program and reinstall it, this should solve the problem. Thank you for using fixya.com
May 09, 2011 | Computers & Internet
How can I get a single product of microsoft office Word 2000, if so how.
To install product Help in one of the Office programs, follow these steps:
  1. Quit all Office programs. Click the Start button, point to Settings, and then click Control Panel.
  2. In Control Panel, double-click the Add/Remove Programs icon.
  3. For Microsoft Windows 95 or Microsoft Windows 98:
    1. On the Install/Uninstall tab, click to select Microsoft Office 2000 product, where Office 2000 product is the name of the specific Office product being used.
    2. If you are using a standalone version of one of the Office programs, click to select the appropriate product in the list.
    3. Click Add/Remove.
    For Microsoft Windows 2000:
    1. Click the Change or Remove Programs button in the Add/Remove Programs dialog box, and then click to select Microsoft Office 2000 product, where Office 2000 product is the name of the specific Office product being used.
    3. Click Change/Remove.
  4. In the Setup dialog box, click Add or Remove Features.
  5. In the Microsoft Office 2000: Update Features dialog box, click the plus sign (+) to expand the features list next to the program that requires product Help. If the sign is already a minus sign (-) the features list is already expanded.
  6. Click the symbol next to Help, and then click Run from My Computer in the list that appears. Click Update Now.
Please post your feedback as well.
May 19, 2010 | Microsoft Word 2000 for PC
Can't move the climate control knob to hot of my 2003 Lancer Mitsubishi and please tell me how to get under dashboard.
remove the knob and check it...sometimes the inner metal part breaks...use a plier to turn it...if it does work....replace the knob
Nov 14, 2009 | 2003 Mitsubishi Lancer
MOD: REX4635EW2 SER: MJ0922226 Type: D433-ELE-2406028-FM54 Won't turn on just buzzes when hit the start button. Have already checked plug in and braker box?
Remove the back panel from the control panel to access the start switch. If there are 4 wires on the start switch,replace the start switch.
Aug 18, 2009 | Roper Dryers
Volume very low won't go up
After I posted my problem, I browsed a bit further through the other posts and solutions, until I came across the solution of TrickyTrev34 and gave it a try. However, I did not slice the cable, but did it as follows: 1. Switch off power of the sound system on the subwoofer box. Disconnect the Front Right (FR) speaker box (the one with the volume control) from the subwoofer box.
2. Remove the silver coloured metal oval on which the speaker box stands. Now you'll see a small screw at the bottom of the speaker box. remove it. 3. Carefully remove the silver coloured metal protection plate (with all the little holes) from the front of the FR speaker box by wedging it from the top with a flathead screwdriver or other thin blunt object. Now you'll see the speaker and 4 holes with screws inside. Remove screws and speaker box opens up. 4. Inside you should see six wires (Red, Blue, Yellow, White, Green & Black). Carefully cut the GREEN wire only.
Insulate the both ends of the GREEN wire with electrical tape or heatshrink or similar.
5. Put the FR speaker box back together in reversed order. 6. Connect FR speaker back to the subwoofer box. Make sure the volume setting on your PC is very low, because when you switch back on the power of the subwoofer, you should be blasting again. As TrickyTrev34 already mentioned, the only downside of this procedure is that it will disable the volume control on the FR speaker, but who cares, your sound system works again, and you can still control the volume via the PC playback control panel and/or the multi-media keyboard if you have one.
Aug 08, 2008 | Altec Lansing Multimedia Computer Speakers
LG 32LX4DC 32 in. LCD Television Logo
23 people viewed this question
Computer Repairing
Computer Repairing
