Question about Epson LQ-2180 Dot Matrix Printer
Lq2180 continuous printing problem - Epson LQ-2180 Dot Matrix Printer
Printer Epson LQ2180.prints fine on the first page but it starts printing in awrong position in 2nd page and so
Hello dear
pls clean your rod on which the carige moves with thinner dont use the oil, check for the play if there is play then replace the cr unit, one more thing you will see a sencor on mask satuated infront of head also clean them with thinner or iso propyle your problem will be resolved.
Sep 27, 2010 | Epson LQ-2180 Dot Matrix Printer
LQ-2180 hasil print putus-putus & ketika sedang print bisa berhenti sendiri, apa solusinya bosss..??
TOLONG,,, BAGAIMANA CARA MENGATASI PRINTER EPSON LQ2180 YG HASILNYA PUTUS-PUTUS DAN BURAM,,MOHON BANTUANNYA
Dec 25, 2009 | Epson LQ 2170 Matrix Printer
Lq2180 when print few lines, the printer pause light on, press pause button print again, than pause again, need to stand there and keep pressing pause light
its may be heaving problem with the control panel clean replace the buttons or replace the control panel and check it ................
Dec 22, 2009 | Epson LQ-2180 Dot Matrix Printer
Epson LQ2180 Line not printing
heres is a reason and a tips, maybe you are using a driver of your printer, then check it on your control panel in Printer, number 2 is it might the printer head ribbon have a problem... this time you are going to check the printer physically inside... and have some self test print to recognize that the problem in the printer not the computer...
Jun 23, 2009 | Epson LQ-2180 Dot Matrix Printer
Paper out
Have you considered buying an ink jet printer? You will find your money will be well spent. Epson all-in-one printers can be bought for less than $100.00 when they are on sale.
May 27, 2009 | Epson LQ-2180 Dot Matrix Printer
A continous pink light
Please read through these instructions first and then follow the steps below:
1. Please power the printer OFF.
2. Remove the printer cable from the back of the printer and remove all the paper as well.
3. Hold down the "FONT" and "TEAR OFF" buttons and turn the printer on.
4. Continue holding the "FONT" and "TEAR OFF" buttons down for five (5) seconds and then release both at the same time.
5. Power the printer OFF.
6. Reconnect the printer cable.
7. Reinstall paper and ensure the thickness selector is in the correct position and that the path selector is also correct.
Jul 30, 2008 | Epson LQ-2180 Dot Matrix Printer
Printing
I can not print with Epson printer Lq-2180 , wheras I install driver into windows2000 And add printer, when i send command print ,the printer do not reflex.
Oct 31, 2007 | Epson LQ-2180 Matrix Printer
Epson LQ-2180 Dot Matrix Printer Logo
59 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
