Question about Maytag Performa PAV2200
Performa PAV3855AAW SPINS OUT OF BALANCE
WASHER SPINNING OUT OF BALANCE WITH ANY SIZE LOAD, TUBE CAN BE MOVED EASILY AND ALOT IN ANY DIRECTION. IS THERE A BELT OR BRACES?
  • 5 Answers
SOURCE: maytag performa washmachine
You could replace the snubber ring and springs,, if you love the machine, and make sure no grease is leaking. It's a lot of labor. These are not the real Maytags of the past.
Posted on Jul 19, 2008
sdmc73
  • 121 Answers
SOURCE: My washer isn't spinning, so i need to "Tighten some Belt", how can i do that?
this washer dose not have belt it uses a moter coupler that sounds like it is broke
Posted on Nov 29, 2008
SOURCE: Maytag Performa Washer spins out of balance
There was a recall on the washer base, which caused the unbalanced problem. Find Technical Buletin TDL-0050B-B issued by Matag.
Posted on Oct 09, 2009
SOURCE: Maytag Performa Washer PAV1000AWW. Shakes when spinning out
My washer doesnt drain in the rinse cycle?? dont kno what to do
Posted on Feb 16, 2010
TheMobilian
  • 8220 Answers
SOURCE: Is the ul error message
Items between tubs can cause the problem Service manual
Posted on Aug 23, 2011
Washing machine balance is off since we moved it.
There are tension springs attached to the tub. They are for the balancing upon spinning. Check and see if one came loose
May 12, 2010 | Maytag EPIC MFW9700S Front Load Washer
Feb 15, 2010 | Maytag Performa PAV2200
Maytag washer tub leans to the right
I have a Mayag Washer and dryer The washer someimes spins of balance. the dryer has no heat, this just started. would it be the element?
Oct 23, 2009 | Maytag Performa PAV2200
Jul 05, 2009 | Maytag Performa PAV2200
Water left in clothes
The shaft was designed to rotate into 2 directions: one for agitation, one for spinning. The spinning direction is controlled by a mechanism from the clutch engagement. When your plastic pulley wears out, it effects the mechanism to spin. The driving force for spinning is slipped, therefore the spin is weak As a matter of fact, the water remaining in clothes n in turn discharges to the bottom tube
Jul 02, 2009 | Maytag Washing Machines
Performa washing machine not spinning
you will most probably find that the inside of the belt that runs on the pulley has been breaking away bit by bit and if the pulley stops where there is a bit missing it may not turn when the pulley starts to turn.
Just a thought as it has happened to me a few times
The odor is most probably burning rubber as the pulley spins on the belt
May 26, 2009 | Maytag Performa PAV2200
"jackhammer" sound coming from my washer
# Balance the load
# Level the machine
# Inspect the water pump for a blockage
# Inspect the coupling
# Inspect the transmission
# Adjust the drive belt tension
# Check the motor bearings
# Check the drum brakes
Jan 09, 2009 | Washing Machines
Maytag performa washmachine
Jul 10, 2008 | Maytag Performa PAV2200
Maytag Performa pav2300 spins slow does not agitate
My performa 2300 makes a loud screech when it stops spinning. What is going on?
Jun 19, 2007 | Maytag PAV2300 Top Load Washer
Washing Machines Logo
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
