Question about Car Audio & Video
I have a sony tx-30 tuner unit and sony rm-x2 remote commander and sony cdx-a30 disk changer that im trying to hook up but not sure of how the wires hook up
  • 78 Answers
SOURCE: Sound only coming from one side
you should have 3 leads going into you multi changer, two rca's and one bus lead. power up the unit and remove the first rca cable if the music goes off unplug the second rca and plug the first rca where the second was plugged in, if the music comes back on then the multiloader is working fine and you need to check the radio controller and its connections
Posted on Dec 10, 2007
  • 23 Answers
SOURCE: it is broken. I have sony integrated remote commander RM-AV3000 .Need codes
what is a mySTR-DE698? but more generic, like brand and what it does. TV or DVD etc...
Posted on Oct 15, 2008
  • 152 Answers
SOURCE: I need a color code for a Sony Xplod CDX-GT23W.
Guessing that you don't still have the owners/install manual.
On the back of the head unit there should be a group of unused/unconnected wires (with any luck they will be marked), one or more might be an amp turn-on or power antenna lead, so I suggest (with the unit turned on) testing each wire with a DC voltage tester so as to identify and separate any leads supplying 12+ volts. the remaining group will consist of speaker leads. Trial and error testing will determine the proper L & R rear speaker leads.
Good luck
Aduz
Posted on Mar 30, 2009
  • 3 Answers
SOURCE: Hooking up a sony cd changer cdx-434rf I am not
hey, i just found one of these in my garage and im trying to connect mine too.. I found out what the wires do...
black(ground) - any metal part of the car
red (remote) - to a wire that gives 12v+ when ignition is on.
Yello (power) - 12v+ source, just connect this wire straight from + on the battery.
Read this manual for more info....
http://safemanuals.com/fullswf-SONY.php?type=.SWF&file=SWF/SONY/15-01-08-13-09-05-614&langue=en&img_width=839&img_height=1191&cat=vide
Posted on Apr 24, 2009
welcomejee
  • 10594 Answers
SOURCE: need a wiring diagram for sony cdx-gt41ou head
Click Sony Support to download wiring . connection manual of CDX-GT410U
Posted on May 17, 2009
I hooked up my Sony cdx m-600, all works fine but radio does not work. at all. Why?
make sure the unit is hooked to the antenna correctly. This unit will not play the radio and will disable the static noise on the radio. So ensure the antenna is properly hooked in. For more info on how to use the deck click here for the manual. got this directly off sony's website for model cdx m-600. So let me know if that it is properly hooked up and we can figure out where to go from there.
Aug 31, 2010 | Sony CDX-M600 CD Changer
Sony CDX-CA810X / CD-playback drops aux amplifier
Do you have the remote turn on lead hooked up to solid blue wire from the back of the deck? Your amp shoild be hooked up to Bluw w/ white strip as the solid blue wire shuts off when the tuner is off, its used only for the power antenna.
Use Blu w/ Wht strip for amps
Jun 03, 2009 | Sony CDX-CA810X CD Player
Apr 11, 2009 | Sony Car Audio & Video
Sony STR-VX550 does not obey remote commands from "optional" Sony RM-S750 remote commander. RM-S750 is working properly and communicates all commands to my other STR-VX550. Receiver appears to be...
You appear to have reprogrammed your remote. Remotes can work with other units made by the same company. But the keys will pass out different signals to each unit. You need to find the correct code for your unit.
This could involve selecting a combination of keys on the remote and possibly some controls on the unit. Then entering a numbers on the remote.
It could be that the unit has the option of selecting a remote mode 2 also. So you will need to select it back to one or whatever it is supposed to be.
Jul 09, 2017 | Sony Audio Players & Recorders
Will one of these disc changers hook up to the new decks?
According to the manual at sony's web site, the sony cdx gt520 deck does indeed use RCA style hook up cables.
May 15, 2008 | Sony CDX-646 10-Disc CD Changer
Sony cd changer cdx-646...no card remote commander to release security code
Hi the CDX-646 is not coded. it must be your head unit thats coded.what model is the head unit?
you can get your code @ www.carradiocode.co.uk
for 33.50 if its one of the models listed you will nedd the remote comander tho.
Mark
www.blueice-electronics.co.uk
Feb 24, 2008 | Sony CDX-646 10-Disc CD Changer
Nov 06, 2007 | Sony CDX-646 10-Disc CD Changer
Pioneer cdx fm653 6 disk changer won't power up
first try to get another display, maybe it's broken (could be the cable cutted), the changer with a motor noise in the moment you plug it, tell me that its ok (95%).
Sep 12, 2007 | Pioneer CDX-FM653 6-Disc CD Changer
Car Audio & Video Logo
48 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
