Question about Whirlpool LGR3624JQ Gas Dryer
Whirlpool LGR8857EQ1 gas dryer
Always starts and heats, but cosistently turns cool before clothes are dry. Excellent airflow at the outside vent. If allowed to set for 10 minutes, it will start up with heat, then cool down at the same point in the cycle again. Thermostat ?
Illeagle
  • 525 Answers
SOURCE: I Have a Whirlpool LGR6620PQ0
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Below is a link to common solutions that will help you with parts and diagnostic procedures that are specifically tuned to your manufacturers data plate information.
It provides exploded view imagery, belt routing diagrams, parts imagery and function, parts ordering and shipping information, error code details, just about anything you need to get your appliance up and running again.
http://www.repairclinic.com/0088_8_1.asp#Level1_16
You may have faulty gas valve solenoids, especially since you've already replaced the other ignition components. Below is an image, (I hope), of the solenoids which can be found and ordered from the link above. A more rare cause can be a lint filter obstruction, i.e. the screen can be coated with an invisible film from using fabric softener sheets. Try running water over the filter screen, horizontally, and if water does not strain through, then replace the filter and stop using fabric sheets.
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jul 04, 2008
mikedurland
  • 481 Answers
SOURCE: I have a whirlpool electric
  • the first thing i would check is the airflow. make sure the vent behind the machine is a smooth rigid 4" duct and not the flexible type.
  • clean out the exhaust pipe and inside wall or wherever the air flows. the reason why the element is not staying on is because the heat is building up too fast without the proper draw of airflow thru the machine.
  • the blower blows air out of the back of the machine creating a vacuum inside the drum where the clothes are and pulling air across the heating element. if the air is blocked behind the machine or anywhere else then the draw of air is reduced or block completely.
  • this will cause a rapid buildup of heat and the thermostat(s) will turn off the element after a few seconds, just like what you are experiencing.
if you already checked this and don't think this is the problem, let me know i will help you figure it out.
Mike
Posted on Jul 10, 2008
onthejob5130
  • 640 Answers
SOURCE: i run the gas dryer,i smell gas...turn off dryer,no smell.....
mostly that after burn,,check vent and vent exhaust reall good,,exhaust coming back in home..
Posted on Dec 26, 2008
Maytag317
  • 1136 Answers
SOURCE: heat cycle stops/goes off
Hi Tony, The next thing I would checnge would be the coils on top the gas valve. The tend to not open after the get hot. This is a very common problem with the newer gas dryers. I hope this helps you. Let me know if I can help you further.
Thanks
Vic
Posted on May 15, 2009
  • 16 Answers
SOURCE: Have to run dryer twice to get clothes dried
also check the exhaust outside of the house, i had birds nest in mine
Posted on Nov 01, 2009
Gas shuts off early on dryer
most heating problems on dryers are caused by restricted airflow. your problem sounds similar. Follow the vent line all the way to the outside vent flapper and make sure that you have a STRONG airflow and no accumulation of lent, reducing the airflow. Verify the problem by disconnecting the vent hose and confirming that the dryer works OK when vent is disconnected.
Jan 31, 2015 | Whirlpool Dryers
My Whirlpool dryer tumbles but no heat. The clothes dry after along period of time and that is when i finally feel some heat.
Probably needs a good cleaning. If it was me I would remove the filter housing and do a through cleanup. make sure the vent going outside is not blocked. The dryer must have adequate airflow to work well.
BEFORE AND AFTER
Oct 03, 2012 | Whirlpool Dryers
Whirlpool gas dryer heats but wont dry the clothes
If your
dryer is not drying like it once did or if you just have not taken the time to give yourself a clean dryer in a long time then you need to do that. At least once a year the dryer cleaning should take place. Lint build up in the dryer duct is one of the main causes for your dryer to fail.
Here is the rest of this tip about
Dryer Maintenance
heatman101
Dec 14, 2010 | Whirlpool LGB6300 Gas Dryer
My LER463rJQ1 dryer is only about 4-5 yrs old and it doesn't seem to be heating as well anymore. I don't know where to start...thermostat? heating element? or what.. What do you suggest.
I assume you mean the clothes are not drying as well or as quickly as they use to.? If so I would start with the Vent system ,85% of extended dry times are vent issues. Start by running the unit and going outside to the dryer vent and check for a good flow of warm air,if very little air is coming out of the vent you need to clean or have the entire exhaust system cleaned out.. With out good airflow you will just end up with warm moist clothing the airflow helps remove the moisture.. If not a airflow problem it may have a thermostat issue not letting it get hot enough or not staying hot long enough,,Hope this helps GOOD LUCK
Aug 27, 2010 | Whirlpool LER4634J Electric Dryer
Dryer will not dry clothes after 60 minutes in the dryer clothes still wet just like they had just come out of the washer.
The reason you are not getting the cloths dry after 60 minutes and are just as wet is airflow or rather the lack thereof.
First verify that you dryer is actually starting, (I know... you're thinking, duh!) but simple things first. Let the dryer run on high heat for about 2 minutes and open the door. See if there's actually heat coming out of the door. If there is, that's a good sign. Did the drum seem to be tumbling? if yes, this also is a good sign.
Next turn the dryer to fluff/no heat and turn it on. Go outside and check the dryer vent (if possible) and see if there is a reasonable amount of airflow coming out. Most likely it will be weak (since your cloths aren't drying.) Now that you have checked that, go inside, disconnect the dryer hose on the back of the dryer. Compare the airflow from the outside vent. If it is considerably stronger than outside, your ducting needs cleaned. If it is about the same and still weak, something is blocking airflow in your dryer.
Here's a decision point. If you feel you don't want to try to fix the dryer yourself, get someone qualified or take it to a qualified maintenance shot for the dryer. If you feel up to the task, FIRST unplug the dryer, then you'll have to disassemble the dryer (can't give you specifics without the model number) and find the clog and remove it. Once the clog is removed (very likely lots of lint and maybe even a sock or two) reassemble the dryer, hook the vent hose back up, plug it in, try to dry your cloths.
Hope that helps
Nov 14, 2009 | Whirlpool Dryers
I run the gas dryer,i smell gas...turn off dryer,no smell.....
Dec 08, 2008 | Whirlpool LER5636P Electric Dryer
My kenmore gas dryer heats up but cools down too fast without completely drying my cloths
check you vent hose all the way to outside. make sure not blocked or kinked.
Nov 02, 2008 | Dryers
Dryer not drying
Sounds like you have a ventalation problem. The clothes heat up, but without airflow, the moisture remains. First check the hose from the back of the dryer to the wall. Is it plugged, kinked, or restricted? No? Turn your dryer on and remove the hose. Do you feel pressure coming from the back of the unit? No? You need to take it apart and clean the internal airway. If you do feel pressure, reconnect it to the wall and start your dryer. Walk to the outside of the house. Do you feel a fair amount of air coming out? No? There are companies that will clean your vent in the phone book. There are also vent cleaning brushes you can buy at hardware and appliance part stores.
Jun 26, 2008 | Whirlpool GGW9200L Gas Dryer
Does not dry clothes. I can run it for three hours before they get dry. The outside of the machine is very hot to the touch. Vent seems to open as I can feel the exhaust outside.
Although you may feel the exhaust, the airflow my not be sufficient to dry your clothes efficiently and costing alot of money on your utility bill. A hot machine is a good indicator that this is the case. Proper airflow across the heater is important to maintain heater efficiency. If airflow is poor, the heater will overheat and eventually fail. If the vent system goes through the roof, the vent screen is probably blocked. If the vent system is longer than 10ft, there is probably lint accumulated in the pipe. Check out this site http://www.linteater.com/.
Remember..the purpose of the dryer vent is to get rid of moisture. If the moisture can't be removed quickly....the clothes will take a long time to dry, no matter how much heat there is....
Jun 19, 2008 | Whirlpool Dryers
Dryer won't dry
hi BethandRoss,
You have a loss of airflow from the dryer. Two things can casue this.
1. You vent going outside is blocked off with lint, bird nest or something.
2. your blower wheel is broken.
for problem 1. pull the dryer out and take the vent off. Start the dryer and feel the amount of airflow coming out. If you have none then go to problem 2. If airflow is good take a look in your vent going outside. Somewhere between that vent and outside you have a blockage. Clear it out or replace it if needed.
for problem 2. I would need your model number to give the exact direction to replace it. Since all dryer come apart abit different, and all dryers have different blowers, I would have to know the brand or model to help you further.
I really hope this will FixYa.
Have a nice night Mike Anderson
Jun 04, 2008 | Whirlpool LEB6200 Electric Dryer
Whirlpool LGR3624JQ Gas Dryer Logo
23 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
