Question about Zodiac Pacer Pool Cleaner
How to fix the hose weight - Zodiac Pacer Pool Cleaner
How can I fix my pool cleaner from flipping upside down during the cleaning process?
Remove weights, Thoroughly clean cleaner, backwash filter system to get optimum suction. Check filter system for optimal suction..., ie. leaks, excess debris, clogged baskets, strainers, etc..
Apr 11, 2016 | Pool & Spa
What section do I put pool hose weights
shallow pool, one weight 4" to 12" from the head. as deep as 7', add 1 weight 6' from the head. deeper than 7', add 1 weight 10' from the head. If deeper than 12', add one more weight 12' from the head.
Apr 03, 2014 | Universal Kreepy Krauly In-Ground Pool...
The hose head keeps falling away from the unit. It should stay pushed in
Has no hose weight or not heavy enough weight on hose under sink. either buy a weight and install on hose about 18" from the bottom of sink. or you can use a 3 ounce fishing sinker with bread tie and tie it around hose aprroximately 18" from bottom of sink. It needs the weight to keep the faucet head in.
Aug 31, 2011 | Grohe Plumbing
My Hansgrohe e high arc 2-spray pull down faucet #06697860 - the pull down sprayer continues to slip out of the faucet when I turn the faucet on. How do I fix this?
The faucet is "pulled" back into its holder by the force of a small weight which is attached to the hose. Either the weight has slipped down the hose or it's getting hung-up on something under the sink.
If it has slipped, loosen the phillips-head screws which hold it in place and slide it up toward the faucet. Tighten the screws and check to see if it holds. If it doesn't, something like electrical tape, or a thin nylon zip-tie will hold it there. Just wrap the hose underneath the weigh so that it can't slide down.
If the weight is hanging up on something, you'll have to figure out how to stop it from happening. Moving the weight up a bit usually wont make the faucet difficult to use. People don't usually pull it out all the way.
Hope this helps.
Aug 24, 2011 | Hansgrohe 06042 Tango Widespread Bathroom...
My pool cleaner only sweeps the deep water zone. It never comes up to the shallow half part of the pool. By the way, the approximate size of my pool is 18 ft x 36 ft.
This should be an easy problem to fix with this type of automatic pool cleaner. Add return diverters or divert return inlets downward. This will use flow to move cleaner to opposite end. Move hose weight away from cleaner head slightly. You might also have to add additional hose weights.
Apr 17, 2011 | Zodiac BARRACUDA G3 IN-GRND CLEANER
Why does my pool cleaner turn upside down? how can i fix it?
Try adjusting your hose weights to see if that corrects the problem. When your cleaner is resting on the bottom of the pool, it should be at 45 degree angle. If it is tilting back toward the hose, try moving the weights closer to the cleaner. If it is tilting forward, try moving the weights away from the cleaner. You might also need to add more hose weight. If the pool cleaner does not have enough weight to hold it down, it will float. You will also want to make sure that you have adequate water flow through the cleaner.
Dec 29, 2010 | Zodiac BARRACUDA G3 IN-GRND CLEANER
Won't go in the shallow end. How to adjust
The hose weights for these pool cleaners just snap on to the hose. If you need to know where to put them, follow the following recommendations from the users manual. The pool cleaner should site at a 45 degree angle for the pools floor while resting. In general, if you have model# W03000, you will probably need one hose weight in the middle of the first section of hose. If you have model #W83215 or W83216, put two weights onto the middle of the second hose section. You may need to adjust the weights slightly to make sure that you get the cleaner to the desired 45 degree angle.
Jul 21, 2010 | Zodiac Baracuda G4 Automatic Pool Cleaner...
My kreepy won't move about. Even though the hose is vibrating, it doesn't move about. I just bought new hose so that isn't the problem. I have an 18x36 inground pool. Where should the ring weights be...
With these pool cleaners, there is a simple test you can do to see if your cleaner is weighted correctly. Turn the pump off and observe. The hose balance is correct when the cleaner's seal rests flat on the pool floor and the drive tube makes a 45 degree angle with the floor. Adjust the hose weights one inch at a time as needed until the proper balance is achieved. If the hose is too light, or rises toward the furface at an angle greater than 45 degrees, move the weights closer to the cleaner or move the first two weights closer to each other. If the hose is too heavy, less than 45 degree angle, move the weights away from each other.
Jun 08, 2010 | Universal Kreepy Krauly In-Ground Pool...
Krauly gets tangled in the hose constantly and will not untangle
With these pool cleaners, that is almost always going to be a problem with your hose balance. To determine if your balance is correct, turn off the pump and observe the cleaner. Hose balance is correct if the cleaner's seal rests flat on the pool floor and drive tubes make a 45 degree angle with the floor. If the hose rises toward the surface at an angle greater than 45 degrees, move the weights closer to the cleaner or move the first two weights closer to each other. If the hose sags at less than a 45 degree angle, move the weights away from the Kreepy Krauly or separate the first two weights away from each other.
May 16, 2010 | Universal Kreepy Krauly In-Ground Pool...
Can't adjust the weight on Hayward King Ray pool cleaner.
just tug on the weight straight off the hose itll come off and you wont hurt it
May 10, 2009 | Hayward Navigator Pool Cleaner
Zodiac Pacer Pool Cleaner Logo
91 people viewed this question
Top Zodiac Pool & Spa Experts
Colin Stickland
Colin Stickland
john h
Jay Finke
Jay Finke
Are you a Zodiac Pool and Spa Expert? Answer questions, earn points and help others
