Question about Electrical Supplies
When I try to start my kohler rv gererator all I
When I try to start my kohler rv gererator all I get is a click
  • 109 Answers
I would try to charge the battery or replace it.
Posted on Jun 18, 2009
I have a Kohler Confidant 5, model 5ckm21 generator in my RV, serial # 326827, spec# 101228. It worked fine one evening and the next day it wouldnt stay started unless the start button stays depresse
no 14vac coming from generator to control board.--cause can be regulator board on end of generator---dirty brushes or worn out brushes==b1 and b2 winding open that outputs the 14vac--my problem was blown regulator board
Dec 05, 2012 | Kohler Electrical Supplies
Model 5CMZ21-RV
Need more information, won't start, won't crank ???
Better to let a pro take a look
Sep 11, 2012 | Kohler Electrical Supplies
Blown fuse (input fuse) on kohler generator when i push start switch
I have a kohler rv generator voltage shows 15 after starting it blows the fuse why?
Jun 11, 2012 | Electrical Supplies
RV generator Model 4CKM-RV (60 Hz) will not start
if same fuel as RV make sure over 1/4 tank or wont run
Jun 10, 2012 | Kohler Electrical Supplies
Kohler Confidant 4 puts out to much voltage
Are you running the gen and plugging in the RV at the same time? I assume it is wired right and you have a transfer switch? Are you saying the voltage is fine when the RV isn't plugged in?
Apr 15, 2012 | Kohler Electrical Supplies
1982 kohler in rv put in new brushs only putting out 96 volt
Try raising the engine rpm slightly. there should be a adjustment on the piece that hooks to a spring which is connected to the governor arm.
Mar 26, 2011 | Kohler Electrical Supplies
Kohler Confident 7 model 7CCKM22 generator
sounds like a relay should be latching one it has started
Feb 04, 2010 | Kohler 12 kW Emergency Power System -...
Kohler confidant 4 generator will not run.
i got the same gen and with the same problem
mike
Sep 24, 2009 | Kohler Electrical Supplies
Kohler confidant 4 generator service manual and wiring diagram
First thing is to check oil level as low oil pressure will shut it down.
Aug 11, 2009 | Electrical Supplies
Electrical Supplies Logo
126 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
