Question about Maytag MSD2732GR Side by Side Refrigerator
Ice in cube maker but won't drop? - Maytag MSD2732GR Side by Side Refrigerator
SolutionGuy
  • 331 Answers
SOURCE: GE 25 side by side refrigerator ice maker problem
Assuming the temp inside the freezer is at around 0 or -2 degrees, it should dump ice every ~50 minutes or so. Again, depending on temp's, an Ice Bin should fill within 24 to 48 hours. If your freezer temp is running at around 10 degrees, everything will obviously still be frozen (below 32), but the ice maker will take longer to freeze the water than it would if it were at 0 degrees. Open both doors and place the palm of your hand on the partition between the freezer and Fresh Food compartments... (where the door gaskets seat when they're closed). The temp of the partition should be about 5 or 10 degrees warmer than body temp., If it's hotter than that, you found the problem. Either the condenser coils are dirty and need a good cleaning OR your condenser fan motor (the fan in back, near the floor in the compressor area) is failed or about to fail.
Posted on Jul 29, 2007
  • 52 Answers
SOURCE: ice maker
There is something called a crusher control rod located on your icemaker bin. If you pull the bin out, you'll see it protruding from the backside of the bin. That rod inserts into the solenoid, which looks like a hole usually when looking in the freezer with the ice bin removed, it's toward the left side behind the bin.
This solenoid and rod work together to give you either crushed or cubed ice. See if the solenoid is stuck or iced up. You should be able to remove the ice and push it up and down to break it free.
Posted on Mar 26, 2008
  • 1073 Answers
SOURCE: Ice Maker problem
remove the cover on the frount of the icemaker and on the right side of the module there is a little and i mean little white adjusting screw, turn it clockwise 1/2 half of a turn clockwise and this is what adjusts the fill time of the ice maker, you may need to adjest back and forth to get the desired size of cubes but do not go more that one complet turn of the screw to get the size
if you can not get it by doing this then the frount module will ned to be replaced
Posted on Apr 20, 2008
  • 3 Answers
SOURCE: ice maker not working
make sure the wire rod on the ice maker is in the down position in order for it to make and release the ice
Posted on Dec 19, 2008
ginko
  • 19396 Answers
SOURCE: Ice Maker will not release the frozen ice cubes from tray
The icemaker use an avaporator system with an heatinc coil and a fan to release cubes.
In your case either the heating coil or the fan in the icemaker must be replaced.
parts can be purchased from partselect.com.
Posted on May 31, 2009
WHY DOES MY ICE MAKER ONLY MAKES ICE SOMETIME
Are the cubes normal - the right size, not hollow? Once frozen and the harvest cycle begins, does it take longer than a couple minutes for the cubes to drop? After the ice drops does it fill with water each time?
If everything checks OK the last thing is very important. The rate at which an ice maker produces cubes depends on the temperature of the freezer - the colder it is the quicker the cycle. Try nudging the controls up a bit and wait 24 hours.
May 31, 2014 | Frigidaire 20.6 cu. ft. Top Freezer...
Ge profile PFSF6PKXEWW AFTER POWER OUTAGE ICE MAKER DOESMN'T WORK
If the ice maker is not filling with water after dropping the last harvest of ice cubes it will indicate a defective WR57X10091 Water Inlet Valve If you would like to try self diagnostics on your model click HERE and go to page 78, I will be here should you have questions, Thanks Sea Breeze
Jun 12, 2013 | Refrigerators
No ice
If ice is formed but will not drop just pour hot water over the cubes. Or the teeth that push out the ice are getting stuck, in that case hold down the on switch to advance the teeth manually.
Apr 27, 2013 | Freezers
Freezer won't make ice cubes, but does provide cold water.
The water and ice maker are two seperate water control valves built onto the same. Your water control valve for the ice maker may be defective and require that you change the set. Fill ice maker with tap water and allow the water to freeze. If the ice maker dumps the ice into ice bin and then does not refill then this points to the water control valve. If the ice maker does nothing after water freezes then the problem is the ice maker. Send me a model number and I will look up the part numbers for you, Thanks, Sea Breeze
Jul 08, 2012 | Frigidaire Refrigerators
Not making ice cubes
Here are some basic tips for ice maker troubleshooting2_bing.gif...
Ice Maker Problems and Ice Maker Troubleshooting
http://www.fixya.com/support/r3876071-ice_maker_problems_ice_maker
heatman101
Jun 08, 2010 | GE 25.0 Cu. Ft. Side-by-Side Refrigerator...
No water in automatic ice maker, therefore no ice cubes.
Do you get water at the front dispensor, if present? If not check the refrigerator water filter. If you have an RO system feeding filtered water to the fridge, check it's filter. Also there is a solenoid that lets water into the ice cube maker, have a professional check it to make sure its working correctly. Lastly I have had to replace the entire ice cube maker, sometimes they do fail. Replacements can be found fairly easy on the internet.
Feb 21, 2010 | KitchenAid KUIS18NNT 18" Automatic Ice...
Ice maker dripping water fusing ice cubes
The dual water valve (solenoid) that open and let the water from the line when the ice maker calls for it, is leaking and needs to be replaced.
Aug 17, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice Maker frost and freeze where ice drops into refrigerator door
You need a service guy to look at it. It could be water leaking or a simple case that the flap isnt sealing and the ice melts and then freezes the flap open
May 14, 2009 | U-Line CO2075F-B Echelon Refrigerator Ice...
Ice maker
check the ice dispenser is there ice in it and if not check water supply to it.
Jul 20, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
U-LINE BI15 ICE MAKER
This is usually a sign of a week water pressure
Jun 20, 2008 | U-Line Icemaker
Maytag MSD2732GR Side by Side Refrigerator Logo
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
