Question about Garden
Ace special edition model 13A5453F033
Does deck have a belt tensioner?
  • 218 Answers
SOURCE: can someone please help lookingh for belt routing
Hey John..my name is Keith..and you can go to an online lawn mower parts site..and they will have a pic of the deck and they way the belt is routed...one of the sites is www.outdoordistributers.com ...i hope this will help
Posted on Jul 08, 2009
The GR8 1
  • 7 Answers
SOURCE: Craftsman 42 inch deck mower.
That model number des not show up as a good number on the http://www.searspartsdirect.com site. Are you sure you have the belts on correctly? If it has 2 belts on the deck & 1 is not installed correctly they work against each other. Safely make sure that each blade will turn by hand. did you take the blades off? If they are too long by just a fraction, they will hit ach other, but that usually makes quiet a noise. Get your book out & systematically go over everything you touched or changed. It sounds like something really simple you have overlooked. you can go to http://www.searspartsdirect.com & enter a good model number & view all of the parts diagrams. Sometimes they are a big help, & at other times they just confuse you more:). Let me know what you find!!
Posted on Aug 13, 2010
  • 146 Answers
SOURCE: Replaced Mower Deck Drive Belt.
Yes, there is an idler arm with a pulley that presses either inward or outward against the belt to tension it. In some JD mowers, the arm is tensioned by pulling on a long metal rod that latches near the edge of the mower deck, but without the model number I can't be more precise about that. Just look for that extra pulley and arm it's mounted on -- you'll see a tension spring, and you should also see a way to pull the arm away from the spring to place it under tension. Good luck!
Posted on Aug 15, 2010
  • 147 Answers
SOURCE: How do I install deck belt on 1998 Model 13AN
Try this link and you can down load one directly to your computer. If you have difficulties please contact me.http://manuals.mtdproducts.com/mtd/Public.do
Posted on Jul 01, 2011
GodBlessU
  • 3513 Answers
SOURCE: On my 2003 Rider 155 mower, the mower blades will
Hi
After it's off make sure the belts aren't too tight. If they are then they won't disengage. They should be tight, but you should still be able to move then a little.
Please check this article to get a detailed idea related to your issue:-
http://www.bobshowto.com/landscape/mower-deck-disengage.htm
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting
fixya.com
Posted on Jul 31, 2011
How do I get tension on the belt that drives the deck. The belt goes from the PTO to the deck but is not tight. When you engage the PTO there is not enough tension to drive the deck.
You either have too long a belt or it is routed incorrectly. Do a Google search for you make and model deck belt routing or look up on jackssmallengine.com
Sep 10, 2016 | Garden
Belt is to long, is there a deck adjustment?
Jim, Double check to make sure you have correct belt for the deck and are installing it in the correct configuration as per manual or drawing on deck. Very few lawn tractors have deck belt adjustment, most do not, most deck belts have a spring loaded tensioner to take up the slack.
This could be some of your problem, the tensioner/idler pulley sometimes seize up and must be lubed up till they move freely, or your belt could be loose. Look in your manual or try google searching your make, model #, deck belt adjustment.
How to Change Riding Lawn Mower Deck Belt
Mower belt tensioner repair question to the Garage Gang
lawn mower deck belt routing Google Search
May 20, 2016 | Garden
Belt came off 97 achieva how is it put back on
to replace drive belt rotate tensioner pulley clockwise then slip on new belt look under hood on the radiator shroud for drivebelt routing diagram.check drive belt tensioner for damage or looseness because very seldom drive break either cracked worn or drivebelt tensioner faulty.
Aug 06, 2013 | 1994 Oldsmobile Achieva Special Edition
Replaced Mower Deck Drive Belt. Belt runs from Engine pulley to Mower deck Pulley. Purchased new belt rom JD dealer. Belt is slack, Is there suppodes to be a tensioner for this belt.
Aug 15, 2010 | Garden
I need to tighten belt for the mower deck, how is that done? it is a 2004 craftsman 17.5HP 42 " deck. Can you help me
Each of the pulleys on top of the deck should have tensioners. These tensioners are usually the type which have a bolt for you to tighten while attached to the pulley. While you tighten the bolt, the pulley puts tension on the belt.
Aug 05, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Where is the tensioner on 94 achieva?
If its a 3100 or 3.1 its under power steering pump.you will need belt tension wrench or thin crescent wrench to release tension for belt removal.
Sep 18, 2009 | 1994 Oldsmobile Achieva Special Edition
Install belt on toro mower model 70041
For removing/replacing the deck belt, the general method is:
  1. turn off engine, remove key and set parking brake
  2. disengage blade by putting blade engage lever into off (disengaged) position
  3. lower the cutting deck to the lowest position (closest to the ground)
  4. relieve the belt tension (depending on the model, use a 3/8 inch ratchet set to tighten in the square hole of the idler bracket)
  5. remove and replace the belt
NOTE: it's not necessary to completely remove the cutting deck.
Useful diagrams for removing the cutting deck, http://216.213.143.2/ProAuthor/ManProc.cfm?ManualID=425&ProcID=14794
For deck belt diagrams, http://216.213.143.2/ProAuthor/ManProc.cfm?ManualID=425&ProcID=14796
If the transmission drive belt needs to be replaced, several components must be removed and special tools (i.e. air/impact wrench) used in order to change the tractor's transmission drive belt. See an Authorized Toro Service Dealer to have your drive belt replaced.
Sep 09, 2009 | Toro Lawn Mower With Toro Power Tools
Replace belt tensioner on 1994 olds achieva S. has a 3.1 litre engine with air conditioning
you need to get a belt tensioner tool to put in tensioner square slot. to release belt tension.then you raise vechicle and safely support it.remove tire.then inner fender splash shield.then you remove tensioner bolt.becareful not to mash your fingers or hand.
Jul 18, 2009 | 1994 Oldsmobile Achieva Special Edition
Tighten altenator belt, need help
Your car has a spring loaded belt tensioner. If the belt is loose it is either routed wrong or the tensioner is bad.
Jan 13, 2009 | 1994 Oldsmobile Achieva Special Edition
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
