Question about AT&T ATT TL86109 Phone
Tl86109 line 2 always connected
How to pair AT&T TL7600 with AT&T 86103 Deskphone
*** How to Pair AT&T TL7600 with AT&T 86103 or 86109 !!!
If you have been going nuts on how to pair TL7600 with TL86103 or TL86109 Deskphone, here is a detailed answer.
First of all TL7600 does not need pairing, it is a passive wireless i.e it remains in hunt mode till a deskphone actually pairs with it.
First things first - Charge the Dect Headset TL7600 for 1-2 hours. Press the On/Off button once and you will see a blue/red light that will keep blinking every 2-3 seconds. This shows that the headset is unregistered with the Deskphone. When the headset becomes properly paired and placed on the charger, it will show steady blue light.
Okie, now to registering the headset.
a) First, lets reset the TL7600 just incase it was paired to another phone. Even if it is not, lets just do a reset to avoid some problem.
Push these buttons in the following order one by one :
Push these buttons in the following order:
vol+mutevol-mutevol+vol-mute
b) Go to the TL86103 and keep TL7600 very close to it. Lift off the TL7600 off the charger and then put it back in.
c) Press "MENU" on telephone mode with phone handset on the phone and the phone in Idle Mode.
c) Scroll to "Settings" and then scroll to "Register"
d) All this while, the TL7600 should be on the charger. If you remove it from the charger, it will not register.
e) Within 90 seconds to 2 minutes, the headset will be registered and you will see the handset will be assigned a name on the phone.
f) Pick up the headset, switch it on and you will hear a dial tone.
g) If this doesnt work, try to first press hold for 10 seconds till it says "Unregister All Devices', Click Yes and go through the process again.
j) If you want to know how to make a call, please note that the call will have to made first on the deskphone, then switch on the headset and there you go. Either lift the reciever and make a call or press Speaker and make a call and then switch on the headset, put the deskphone handset down or switch off the speaker and your TL7600 will be connected.
*** For TL86106, everything is same till (b). After that, press HOLD Button on the phone for 4-5 seconds till you see "Registering". Within 90 seconds to 2 minutes, the device will register the TL7600.pair-t-tl7600-t-86103-deskphone-wg3ndzwv23znm50ophchmy55-3-4.jpg
Dec 31, 2015 | AT&T Lands Phones
Replaced battery but will not charge
Did it fall in water, or have anything else happen to it (was it dropped ?) Also, check the metal prongs inside the phone to make sure they are touching the metal strips on the new battery.
Apr 06, 2015 | AT&T ATT TL86109 Cordless Phone
I have a two line TL86109. When I am on line 1, calls do not roll over on to line 2. How do I cause that to happen. I did not see that in the manual
You have to have the numbers set up as a "hunt group".The real telco companies can do this,but not sure about VOIP numbers or CATV co dial tones.The primary number on a hunt group will forward the calls to the next # in the hunt group(in your case there are only 2 numbers).You can get many numbers set up this way.
Jun 09, 2014 | AT&T ATT TL86109 Phone
Number 3 does not work on my TL86109 base
Hi Ralph,
Did you find a fix for your number 3 not working? I'm having the same problem.. #3 is displayed on the led and beeps when it's pushed, but it won't break the dial tone..
Please let me know if you found a resolution.
Thanks so much!
Apr 05, 2014 | AT&T ATT TL86109 Phone
The answering machine does not come on. How do I turn it on?
Please check the power sup[ply if it is connected.
Oct 23, 2013 | AT&T ATT TL86109 Phone
Want to put hold music on AT&T ATT TL86109
we have a solution for this with an adapter and digital player.
Feel free to call Tropical Marketing at 866-799-0003
Jan 08, 2013 | AT&T ATT TL86109 Cordless Phone
Have answering machine and fax on same line. How do I receive calls or faxes?
Your fax machine *may* have specific instructions (if not too old) for this very common type of installation (many do). Consult your fax manual to learn how to set this up. Your AT&T TL86109 phone has no options for adding a fax machine.
If your fax machine lacks the built-in ability to forward non-fax calls to your telephone or TAD, you will need to either purchase a fax machine that can do this, purchase and install a "fax switch" or, manage your fax calls manually - by only enabling the fax machine to answer calls when a fax is expected.
If yout still have problems, please post the name / model of your FAX machine. I hope this helps & good luck!
Jan 07, 2013 | AT&T ATT TL86109 Cordless Phone
Trying to hook up a pilot light switch to a gfi recp not having much luck with getting it to work properly i got 2 conductors from the panel and 2 conductors going to the gfi recp and on the switch i have...
It is unclear what pilot-light-switch is supposed to turn on-and-off.
Option A) pilot-light-switch is going to turn GFCI on-and-off
Option B) pilot-light-switch is getting power from existing GFCI circuit, and switch controls another Load (light, fan or motor) located elsewhere.
Add a comment at any point.
Bare copper wire always connects to green screw.
1) I have a Cooper pilot-light-switch in my office.
Black Hot wire from breaker always connects to dark-colored screw(s).
White Neutral wire from breaker box connects to silver-colored screw
Wire going to Load (light, fan, motor) connects to brass colored screw.
2) Two things happen when pilot-light-switch turns ON:
a) Pilot light turns on. This circuit is powered by black Hot wire, and circuit is complete with white Neutral.
b) Brass screw that had no power, is now powered.
The GFCI:
Hot from breaker always connects to brass-colored Line screw
Neutral from breaker connects to silver-colored screw that is opposite Line screw.
If other switches and plugs are going to be protected by GFCI, they connect to brass Load screw and to silver screw that is opposite Load screw
Option A) You want pilot-light-switch to turn on GFCI receptacle.
a) Wire pilot-light-switch as described above
b) Black wire from GFCI line-screw connects to brass screw on pilot-light-switch.
c) White wire from GFCI silver-screw-opposite-line-screw connects to any white Neutral.
Option B) Pilot-light-switch is getting power from GFCI receptacle AND you want pilot light switch protected by GFCI.
a) Black wire on pilot-light dark screw connects to Load screw on GFCI
b) White wire on pilot-light silver connects to silver screw on GFCI that is opposite Load screw
Option C) same as option B except pilot-light-switch is NOT protected by GFCI.
a) Black wire on pilot-light dark screw connects to Line screw on GFCI or any Hot wire
b) White wire on pilot-light silver connects to silver screw on GFCI that is opposite Load screw or to any Neutral wire
Nov 19, 2010 | Cooper Wiring Devices 277W-BOX SINGLE POLE...
Breaker keeps tripping when turning on pump.
The red and black wires if ran correctly are the load lines(power). The white is neutral or ground. If its a 1/2 to1-1/2 hp motor connect the red and black wires to terminals #1 and #4. If its 2 hp use #1 and #4. If its 3 hp use #2 and #4. Connect the white wire to the green colored screw. A grounding conductor should always be connected under the green grounding screw, which is located within the terminal compartment of the motor. You can check the breaker for the wire colors, one should be black and the other red. The white wire should be terminated to the neutral/ground bar in the can.
May 16, 2010 | AO Smith 1 HP 115/230V 56C Replacement...
Line 1 of my phone is always busy.
From your description it sounds that you have a short on your Line 1. Its either on DMarc of your carrier or it cross connected improperly. However your post is not clear on voicemail. In normal operation if busy it doesnt go to voicemail.
Call your carrier first and report troubled line. Their technician will tell you what to do next.
Mar 15, 2009 | Panasonic KX TC1451 Cordless Phone
AT&T ATT TL86109 Phone Logo
37 people viewed this question
Top AT&T Lands Phones Experts
Paul C.
Are you an AT&T Lands Phone Expert? Answer questions, earn points and help others
