Question about Samsung HL-S5679W 56" HDTV
Samsung HL-S5679W The problem I am having is with powering on the tv. The unit turns itself on and off about 10 times before it stays on.
Re: Samsung HL-S5679W
Just got mine fixed, it was an undersized Capacitor that needs to be replaced, call Samsung get local repair to come out replace and it took less than an hour for repair to be complete, working perfect every time now, some had to have two caps replaced
Posted on Jan 08, 2008
Posted on Sep 23, 2008
0 characters
3 Points
Samsung HL-S5679W - Power-up issue
There can be a few causes. One of the LED Modules has gone bad, The LED Driver board has gone bad and or the Power Supply has gone bad. You will need to have a good tech look into it.
Apr 03, 2010 | Samsung Projection Televisions
I need to replace the bulb on my TV model # HL-S5679W. I can not locate the replacement number for the lamp. I have been unsuccessful with contacting Samsung and need help.
This model does not use a lamp----if the LED unit is bad you may want to just forget it---
Samsung part number for the entire optical engine:
BP96-01470BIt is marked as no longer available (2006 model) and had a suggested list of 495 exchange.
Google the above part number and you will find some places selling the engine---for much more than Samsung wanted.
SORRY TO GIVE YOU BAD NEWS---no replaceable lamp in this model----the LED light unit is part of the optical light engine.
Oct 28, 2009 | Samsung HL-S5679W 56" HDTV
My 56 inch tv shut itself off and will not turn back on, all 3 light lower right are blinking, any answers?
You need to change the lamp. This tele doesn't have a color wheel so that leaves the lamp or the power board. Try the lamp first, it is the most likely problem.
Jul 21, 2009 | Samsung HL-S5679W 56" HDTV
HL-S5679W won't start three light blinking
There is no lamp on this TV.. Your issues sound like a bad DMD board or bad capcitors on the power board. Remove the power board and inspect it.
Jun 21, 2009 | Samsung HL-S5679W 56" HDTV
TV Stopped turning on.
Apparently you can fix the issue by replacing a few faulty capacitors. I haven't done this yet, but plan to try it out next week.
Apr 03, 2009 | Samsung HL-S5679W 56" HDTV
Samsung HL-S5679W Check no. 3 fan message
Their is no more you can do.
You need a professional.
Stop using the TV until it is repaired.
Call the manufacturer to find you nearest authorized service center.
MR. TV Sales & Service Inc
Milwaukee, Wisconsin 53405
(414) 762-8600
Established 1974
Mar 24, 2009 | Samsung HL-S5679W 56" HDTV
Samsung HL-S5679W No video No sound
Check the capacitors on the power supply first. If any have domed tops or signs of leakage, replace them. I had two go bad on mine. Call electronics parts supply stores first as these are not your average capacitors.
Jan 22, 2009 | Samsung HL-S5679W 56" HDTV
Samsung TV will turn on and off several times, then stay on.
First, need to check the power bar(if you use).
then. if don't use power bar, need to check the power board.
Dec 12, 2008 | Samsung HL-R7178W 71" HDTV
Samsung HL-S5679W 56" HDTV Logo
933 people viewed this question
Top Samsung Projection Televisions Experts
Steven Wander
Steven Wander
The Wyzzyrd
Donald Griswold
Donald Griswold
Level 1 Expert
Are you a Samsung Projection Television Expert? Answer questions, earn points and help others
