Question about Facebook Computers & Internet
Fix my registry serial number
Dll problems
Hw to remove run DLL error in microsoft window 8.1
run.dll is a DATA LINK LIBRARY FILE if it is sikped in installing windows {or} other any software ,malware,adware virus problem you can fix it by using DLL suite { the dll suite download and install it will have a lot of serials keys in serial.ws.com } you will enjoy the features of windows
Apr 06, 2015 | Microsoft Computers & Internet
Erdmpg-6.dll access violation error
Getting the erdmpg-6.dll error pretty much indicates there is something wrong with the erdmpg-6.dll file, either it is absent from the computer or is damaged (corrupted), if so, the system will unable to read or access to the file when needed. When you encounter the error, first reboot your computer once, if the error persist, you can try to download the erdmpg-6.dll file from the internet, or get a healthy copy from another computer, and then replace the file in the suitable area in the computer.
Secondly, you can try to reinstall the program/application that trigger the error tofix erdmpg-6.dll error. but remember not to reinstall it until you uninstall the current installed one, to uninstall a program, go to Start > Control Panel, click onAdd/Remove program option and use it to do the removal.
Most of the time, registry problem is responsible to the erdmpg-6.dll error. Windows registry is part of the system, it is much important than any other system components, all the software & hardware data are stored in the registry. The erdmpg-6.dll error usually happen when the Windows registry gone corrupted or the related entries inside is damaged. To test if the registry of your computer is having problems, you can perform the steps below:
If you are experienced enough, you can open the registry editor, find out all the unnecessary or wasted entries inside, and delete them all, then modify the problematic key value to the proper status. Before any modification, we suggest you to backup the registry first to avoid crucial problems caused by mistaken operation.
Step to backup Windows registry
  • First open Registry Editor by clicking Start and go to Run.
  • Type in regedit, and click OK.(fig1)
  • Click on the File menu, select Export.(fig 2.png)
  • In the pop-up window, select the location to store the backup file.
  • In the 'Export Range' section, select All.
  • Type in the backup file name, and click 'Save' button.(fig 3.png)
How to restore the registry
  • Open Registry Editor.
  • Go to File > Import.( fig11.png)
  • Locate the backup file you have already created.
  • Select it and click Open button.
  • Restart the computer after the restore.(fig 12.png)
  • Registry modification is kind of a complicated task for average computer users since there are thousands of registry entries, it is hard to spot out and clean every wasted one, no mention to modify the incorrect entry value, it can be dangerous if the value is modified improperly, your computer may end up crash, even registry backup can't save it. Fortunately you can use registry tool to help you out, simply follow the below three steps, you will be able to fix the registry as well as fix erdmpg-6.dll error automatically:
    Step1: Free download erdmpg-6.dll error fix tool, and then install it in your computer.
    Step2: Click Start Scan Now button to scan over your computer for existing problems and errors.
    Step3: Click Fix All button to completely fix erdmpg-6.dll error.
1_27_2013_10_16_57_am.png1_27_2013_10_17_34_am.png1_27_2013_10_17_51_am.png1_27_2013_10_18_57_am.png1_27_2013_10_19_12_am.png
Jan 27, 2013 | CoolwareMax WebcamMax
Windows XP boot after an error, it can not find the file shfolder.dll, and is included in the Windows folder. What do I do?
http://www.fix-all-dll-errors.com/shfolder.dll/
This will fix the issue without any botheration.find that dll here :)
Dec 15, 2010 | Microsoft Computers & Internet
Missing DLL files
hi,
Just visit this site...this will help in case of missing or for downloading dll's or also if there is errors in dll's..!
I also registered few dll's from this site...worked in my case :)
Apr 08, 2010 | West Wood Studios Command and Conquer...
D3d9.dll
Well you can download from below, then put it in windows\system32\ Then START>>RUN>>regsvr32 d3d9.dll and enter to "Register" it. Do that as Administrator. www.dll-files.com/dllindex/dll-files.shtml?d3d9
You may have to re-install the application though.
Mar 13, 2010 | Capcom Devil May Cry 4
Error \PROGRA~MYWEBS~1\bar\6.bin\M3PLUGIN.DLL
Maybe Registry Easy can help fix this .dll error.
Registry Easy is an excellent Windows Registry Cleaner that helps you scan your PC, safely clean the errors & invalid entries cause system slow, freezing and crashing, and repair registry problems to speedup your computer performances. It is easy to use.
http://www.keep-pc-clean.com/registry-easy-cleaner.html
Aug 04, 2009 | Microsoft Windows XP Professional for PC
Install missing dll file
Dear
If u have missing .dll file (download from web)
copy .dll file to c:\windows\system32
go to run and type (if ur dll file is abc.dll)
regsvr32 abc.dll
and press enter n ok
Oct 19, 2008 | Computers & Internet
Dll file have error
Hi alexistech, the wininet.dll & newdev.dll are windows fies. You can try this link to fix your *.dll files.
http://www.dll-files.com/dllindex/dll-files.shtml?normaliz
Luck!
If this helps, please let me know.
Need more help just post your questions here.
Mike
Apr 17, 2008 | MSI AMD ATHLON-64 939 PIN MOTHER BOARD...
Trouble with slbcsp.dll and sccbase.dll
http://www.fix-all-dll-errors.com/slbcsp.dll/
http://www.fix-all-dll-errors.com/sccbase.dll/
This is the best place to get dll problems solved.
Just follow the link given above and click the button "Fix dll errors now" and you are through.
Jan 02, 2008 | Computers & Internet
Computers & Internet Logo
11 people viewed this question
Top Facebook Computers & Internet Experts
David Payne
David Payne
Are you a Facebook Computer and Internet Expert? Answer questions, earn points and help others
