Question about Soleus Air SG-PAC-12E1 KY-120E1 12,000-BTU Self Evaporative Portable Air Conditioner - Single Hose
Soleus air gm-pac-12e1 H8 - Soleus Air SG-PAC-12E1 KY-120E1 12,000-BTU Self Evaporative Portable Air Conditioner - Single Hose
What does the message H8 mean?
Call tech support and they can give you all the info you need.
For Technical Support and Warranty Service Please Call (888) 876-5387 Or Write To: Soleus International Inc. 20035 E. Walnut Dr. N. City of Industry, CA 91789 USA www.soleusair.com
Sep 18, 2014 | Soleus LX-140 Portable Air Conditioner
How do i get this to the heat setting ?
Hello there.
If you have the right model of this machine
Press 'mode' switch as per page 9 of user guide here
http://www.soleusair.com/Manuals/2014%20B%20manuals/SG-PAC-12E1%2012E1HP%20manual%2010052012.pdf
Also can do it on the 'remote control' if you have it.
Sep 16, 2014 | Soleus Heating & Cooling
How do i recharge the gl-pac-08e4
needs to be recharged by a trained technician
Aug 04, 2014 | Soleus Powered by Gree Powered by Gree...
Is the H8 code for the GM-PAC-08E3 model of the soleus air mean
The back up water tank is full. If you have emptied it the manual says seek service
Jul 12, 2014 | Soleus Heating & Cooling
How do I repair the cooling system?
Well I signed up for HVAC classes at the community college and that worked out well for me. Repairing your own system is a great reason to go to HVAC school, but it will probably cost more than replacing the unit you mention.
Jul 03, 2014 | Soleus Air SG-PAC-08E3 8,000 BTU -...
Do you have a manual written in English for the AC listed.
This is just a world wide free chat room
There is no one at FixYa answering anything
Just people at home like Facebook
So call the company or use the internet to
find a manual online
Jun 02, 2014 | Soleus 8000 BTU Evaporative Portable Air...
Split ac error code u8 what problem
3 possibility for U8 Error code:
1) Signal receiver faulty
2) PC board fails
3) Indoor blower fan motor faulty
Aug 03, 2013 | Soleus Powered By Gree 8000 Btu Portable...
Soleus gb-pac-08e4 h8
The unit is NOT pulling water from the air to cause this error, yes they pull moisture out of the air and over TIME fill with water. The problem is that the unit shows the H8 error even when empty. Worked for 2 months and now just keeps popping the H8 code, EVEN THOUGH IT IS EMPTY. Unfortunately sometime you find out after buying a product that it is not quality, that is the case with Soleusair. Bad company, Bad product.
Jun 17, 2012 | Soleus KFR-18 Air Conditioner
My unit is only 2 months old and its making a squeeling grinding bearing kind of noise in front of the the unit and its on the bottom where youu can feel the grinding on the outer casing. What could it be?
I had the same issue with my Soleus PAC unit making a squealing, grinding noise.
I took the unit apart to locate the issue and found out that the water pump on the lower right side was the issue.
I removed the water pump and used warm water and a little bit of dish washing soap along with a qtip to clean the water way.
Squealing stopped.
Not sure if this is the same issue with your unit - but it can be a starting point.
Just be sure to unplug the unit while working on it. Also be careful not to puncture the coolant lines.
Good luck.
Jul 22, 2011 | Soleus PH3-10R-03 10000 BTU Portable Air...
Soleus Air SG-PAC-12E1 KY-120E1 12,000-BTU Self Evaporative Portable Air Conditioner - Single Hose Logo
59 people viewed this question
Top Soleus Heating & Cooling Experts
Michael Galve
Michael Galve
Coss
Dennis Boxerman
Are you a Soleus Heating and Cooling Expert? Answer questions, earn points and help others
