Question about Pyle PLD10BT
Can you fix my radio
Volume isn't working in my radio
The volume on my dab dewalt job site radio doesnt work.any ideas how to fix it
If no volume at all it is the unit amplifier. If volume but no adjusting, then the volume control needs cleaning/replacement.
U sure the radio is getting power?
Feb 23, 2017 | Dewalt Audio Players & Recorders
Tip
Tivoli PAL volume problems
I posted this tip elsewhere but the FixYa site is, shall we say, challenging.<br /> After years of use my Tivoli PAL started having volume problems. The audio began popping, volume changed erratically, static, booming, almost feedback sounds.<br /> In my case, and others as well, I've gleaned, the problem was the volume potentiometer. Apparently it oxidizes over time and the poor electrical contact is the reason for the erractic audio.<br /> I'm not an electrical repair kind of guy, so this isn't pretty.<br /> The volume and frequency controllers are secured to the knobs with metal collars. I pried the collars loose and got the horizontal board off, I sprayed Stabilant 22 into the volume pot. There are other electrical contact cleaners as well.<br /> Put it all back together. Let the flud dry. Good as new.<br /> Good luck.
on Apr 27, 2011 | Tivoli PAL Radio
Radio volume control on 2008 Subaru Tribeca does not work, but remote volume control on steering wheel works. Any suggestions on repairs?
Replace the volume control(rheostat) inside the radio. Only way to fix it. I would personally just live with it until one or the other quits working. Then replace the radio.
Jun 07, 2015 | 2008 Subaru Tribeca
Low volume in my Zenith Chairside model 6p447. Tube radio AM/SW tube radio
clean the radio head at runnig time if it does not work then your volume controller fixed then it working nicely.
Feb 10, 2013 | Audio Players & Recorders
Hello, my Vibe 2003 year modle's radio or clook isn't working, a light went out in it and i tried to fix it. I worked on the fuses for awhile but now the whole radio or clook dosnt work, i can turn...
it sounds like either you need to pull radio and reconect outside of vehicle on different power source or replace check for power at fuses first.
Aug 21, 2011 | 2003 Pontiac Vibe
Radio on 2008 dodge nitro stops working it goes out for a while then comes back on. no sound even when turning the volume up and down. it makes a loud popping noise and goes out.
Im having the same problem! No pop, just a hum, and my volume dial won't adjust. Like the actual dial isn't working. I can't use radio, cd, or aux. Silence SUCKS.
May 31, 2011 | 2008 Dodge Nitro
FM radio works fine. AM radio worked fine when car was new but now it's like you're in a tunnel. Lots of static &/or weak signals. I have to turn up the volume very high to hear anyting on...
If you have window tint that contains metal sputter in it. That can cause interference on your fm/am signal strength. If that's the case change your tint to a carbon fiber tint that does not cause interfernce with your radio
May 29, 2011 | 2005 Volvo S60
2004 NISSAN SENTRA . THE VOLUME OF THE RADIO STOPPED WORKING. THE KNOB WORKS, THE BUTTONS FOR DIFFERENT RADIO STATIONS WORK. THERE IS JUST NO VOLUME.
same this happned to me in my 2006 sentra. the volume for the radio is gone. i can tune, its just barely audible/ quiet. weirdly though it sounds perfect when playing CDs. i almost thought maybe it got switched in to mute mode or something. did you figure out your problem?
Jun 17, 2010 | 2002 Nissan Sentra
The volume not does not work on the infinity radio. I can control volume from the steering wheel but not the knob. Is this normal? Can it be fixed?
dear friend-the volume on the steering works from the back of the radio and the knob from the front,they work seperate but both can be used,so the knob on your radio is not working.
Jul 07, 2009 | 2009 Hyundai Sonata
Intermittent volume level
Radio Shack does provide a volume control cleaner that you could gently spray to clean the contacts, but you may simply have a defective knob. (The first S350DL I bought had a defective volume control.) Don't hesitate to call Eton Customer Service either.
I hate to say this, but I've become a little wary of buying radios at Radio Shack. I have a suspicion that occasionaly radios that are returned get "recycled" back into stock rather than sent back to the manufacturer. I had to return 2 radios directly to Eton / Grundig after getting back to back defectives at RS.
Oct 21, 2008 | Grundig S350 AM/FM/SW Radio
Pyle PLD10BT Logo
29 people viewed this question
Top Pyle Car Audio & Video Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you a Pyle Car Audio and Video Expert? Answer questions, earn points and help others
