Question about Konica Minolta Bizhub C451 Copy-print-scan
Crinkled paper crinkle paper
  • Konica Minolta Master
  • 6,161 Answers
Replace the fuser
Posted on Jan 10, 2016
4 Suggested Answers
Shah_Sheh
  • 81 Answers
SOURCE: magicolor 5440dl manual feed jams paper as it
If the paper was damaged we can presume that there is a blockage, however your jam sounds like the paper is not in the expected position at the expected time (ie a sensor is not reporting that a peice of paper has reached it) so this can be cased by
1. rollers slipping on the paper from
a/ slippy media - try a different paper (even as a test)
b/Build up of paper dust on the rollers- If you can see the roller, power off and wipe with cloth
c/ Roller ware - If you can see the roller and have a mild abreahisive like wire woll If you can see the roller and give the rollers a rub
2. Sensor failure-Try Powering off then unplug wait 2 minutes and then power back up, this will reinitilise a sensor
Posted on Sep 10, 2009
  • 351 Answers
SOURCE: My Konica Minolta bizhub C250 seems prints about
The paper may not be feeding straight out of the paper tray due to poor stacking of the paper in the paper cassette. try another paper tray or check the paper in the paper tray for folded over papers usually near the bottom. Also try feeding paper from the hand feed tray on the left side. This uses a different paper path.
Posted on Dec 07, 2010
SOURCE: Paper jam in fuser that crinkles the paper during
If you get crickling check the rollers or replace the fuser. Sometimes you can WD 40 the rollers or blow out the paper dust.
Posted on Mar 11, 2011
Fix Paper crinkling on the left of each page starting about half way down?
Crinkling paper is usually due to either an obstruction in the paper path or a bad fuser, which is the part of the printer that heats the toner so it melts to the page. It is located at the top of this printer. It can be a little challenging to see the fuser on this model, but if you look close you should be able to determine if the fuser is bad. You might also have a bad transfer belt, inspect it closely on the side the has the crinkle.
Feb 28, 2015 | HP Color LaserJet 2600n Printer
Paper will not go through printer and also crinkles when comes through the printer
When the paper does not feed straight, then dirty or stickyrollers can cause the paper to jamb or crinkle.
Try cleaning the rollers with methylated spirits
Jun 01, 2011 | Kodak Esp 3250 Allinone Multifunction ( ...
When printing paper comes out all "crinkled" maybe roller problem?
It the paper comes out crinkled or accordion looking then it is your fuser. Check where your the paper comes out of. There might be a piece of paper jammed in there that is causing this. If no obstuctions then it might be the roller on the fuser cracking and cause it to crinkle the paper. The fuser is the last thing the paper goes through before coming out. It "fuses" the toner to the paper.
Apr 26, 2010 | Brother MFC-8660DN 5-in-1 Laser...
Only on Quicken to 3210 all-in-one printer. Paper starts to feed then indicates paper jam, wait long enough and paper feeds with crinkle and no print.
I would check the paper path on the printer where it is crinkling the paper. More than likely there is some small piece of paper or something that is causing it. Does it only do this out of quicken? I wouldn't think so if the paper comes out damaged....
Feb 22, 2009 | HP Photosmart 3210 All-In-One InkJet...
Paper is coming out wrinkled in one spot
Most of the crinkled paper issues I deal with have to do with the fuser roller lining going bad. If this is your issue the crinkle will be a vertical line from the leading edge to the trailing edge. You will need a new fuser.
Jan 30, 2009 | HP LaserJet 2840 All-In-One Printer
Crinkled paper
Pop open door to make sure nothing is stuck near rollers. Could be paper, staple, paperclip, etc. Clean out and try again.
Is it the same paper you always used?
Feb 26, 2008 | Brother MFC-8460N All-In-One Printer
Paper crinkles for fax or copies
either your feed rollers are bad or there is a piece of paper stuck
Dec 05, 2007 | HP LaserJet 3030 All-In-One Printer
Crinkled paper
It sounds like a fuser problem. You may have something stuck in it, or the lower roller could be defective. You may have to replace the fuser.
Nov 01, 2007 | Lexmark E320 Laser Printer
Konica Minolta Bizhub C451 Copy-print-scan Logo
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
