Question about Ryobi 40-Volt Lithium-Ion Cordless String Trimmer
Ryobi 40 volt battery problem
Machine cuts out after 5 seconds
2 Suggested Answers
  • 156 Answers
SOURCE: 40 volt ryobi trimmer runs for 3 seconds then will not run at all, battery is good
Check this out; it may be helpful:
Homelite String Trimmer Engine Stops After Few Seconds
Posted on Apr 26, 2015
Op 400 40 volt ryobi charger output voltage
IT most likely is not 40 volts! It can be 20 or less. Depends on the battery configuration. There can be 2 twenty volt batteries in series and the charger charges them in a split configuration.
Apr 01, 2017 | Ryobi Drills
I have a 40 v cordless trimmer. What should the voltage be at the motor? Mine is 8 volts
Frank,
I would think it should be the 40 volts. Do you have it on the battery itself?
May 30, 2015 | Ryobi Garden
Ryobi miter saw laser is way off. I can get it parallel, but it's about 1 inch away from the actual cut line. How can I fix the laser side-to-side?
Forget it. The lazer site gets obscured and useless after 5 minutes of cutting. It is the most useless improvement I've seen on a power tool in 40 years.
Feb 22, 2015 | Ryobi 10 In Miter Saw With Laser
Ryobi 18-Volt Impact Wrench P260 stop during use
Well I was having the same problem and I found out that the p108 and p109 cut power when to much of the battery power is being used, kind of dumb just to say the new batteries last 4x longer( its because u can't use all the torque of the impact). Fortunately I've found out that the older batteries don't cut power such as the p104 p103 and the black ryobi batteries without the gauge indicator work the 1/2 " impact without cutting power
Mar 19, 2013 | Ryobi 18-Volt Impact Wrench P260
Who rebuilds ryobi 18 volt li ion batteries
Rebuilding the Lithium batteries is a waste of time and money. For starters the cells cost a minimum of $5 ea and a low power pack takes 5, so now you are in for $25 without doing any work. You can pick up packs on eBay for around $30 - $40 if you shop around. If you know what you are doing, you can strip cells from bad packs and test them to find good ones and then rebuild with those. It can be tricky and you may get mixed results.
Aug 23, 2012 | Ryobi Two 18V Lithium-Ion Batteries +...
Can a bad ryobi 18 drill ruin a new 18volt ryobi battery
If the drill has a short in it, then yes, it could short the battery out. Probably in the trigger switch.
Jan 24, 2009 | Ryobi Multi-Volt Battery Charger
Ryobi 40-Volt Lithium-Ion Cordless String Trimmer Logo
796 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
