Question about Evga (122-CK-NF68-AR) Motherboard
Vista 32 bit is a 32 bit system and can only handle 3 Gigs of ram. Same goes for XP. Doesnt matter if you have 4 6 and 8 the OS can only handle 3
  • Evga Master
  • 4,806 Answers
Vista X64 and XP X64 recognizes what memory you have installed in the system.
If your system doesn't support 64bit then your stuck with a 32bit system.
Regards
Posted on Jun 18, 2009
I have a Dell Optiplex GX620 with a 64-bit Intel chip, and 6 GB of RAM, and I can't install any 64 bit versions of Windows on it.
your ram may be bad but not fried so windows cant deyect it also may need to reset your ram aet in advanced setting ,although your system sjhould detect that and adjust so check system in control; panel see if its is matchiing ie .. if u put 4 gb ram it may say 3gb ,if it has 4 gb then yiur settings systems icon control panel double click avanced system settings click on it then click on advaced scroll down to virtual memory it should be for 4 bg. ram would read 4000 MB OR REAL CLOSE TO ADJUST IT,, AL;SO U MUST HAVE 64 BIT OS XP AND REINSTALL OS PLUS PICK 64 BIT DRIVERS FROM MANUFACTER OF PC TO RUN 64 BIT CANT HAVE 1/2 AND 1/2 [32 +64] DONT MESH FOR 64BIT...32 CAN HAVE BOTH NOT 64
Jan 18, 2013 | Dell OptiPlex GX620 PC Desktop
I want to add more RAM. Is it possible?? Worth it??
It Depends On How much ram you are running now. More ram is Always A good Thing.
However, The Amount of Installable Ram Depends On the Operating System you are running.
Windows XP, Vista, and 7 32 bit (x86) systems only except up to 4 gigs of ram. (Sometimes 3 1/2)
Windows XP, Vista, and 7 64 bit (x64) Systems will except up to 16 gigs of ram. (Some Beyond that)
If you are Unsure which System you are running,
1. Click on the Start Menu
2.Right Click on my Computer
3.Doube Left Click on Properties
On the Main Properties Page it should display
1. Which operating System you are running and Which bit it is (eiter 32 or 64)
2. How Much Memory (RAM) you are currently Running
3 and What Proccessor is Installed in your computer
Jan 18, 2011 | Gateway 3522GZ Notebook
I installed 4 Gig of RAM memory but only 3.25 shows up.\r\nis there a test I can run to see if the memory cards are working correctly? Thanks. Paul
It sounds like you are running a 32 bit operating system XP, Vista, or Windows 7 (32).
The 32 bit Operating Systems are only able to see and use about 3Gb of RAM. To use a greater amount you will need a 64 bit OS (either Windows XP/64 or Windows 7/64) or one of the open source 64 bit operating systems.
Oct 15, 2010 | Dell Dimension 4700 PC Desktop
Laptop shows only 4gb ram & 300 gb hdd
This is the limitation of a 32 bit (x86) Operating System. A 32 bit OS can detect upto 3GB RAM only.
You may either try installing the x64 Bit of XP Operating System or Vista Service Pack 1 or 2 for 32 bit Vista Operation System to resolve the issue.
After installing the SP 1 or 2 of the Vista OS in the Computer, the OS will detect 4GB RAM.
Good Luck!!!!!!!!!!!!!!
Oct 12, 2009 | Acer Computers & Internet
I have installed 4 GB of RAM but it only shows 3 GB RAM
Any 32bit OS can only read up to 3.5GB of RAM. In order to read additional ram you must have a 64BIT OS.
Sep 27, 2009 | Computers & Internet
Integrated Camera is not reconized by vista 64-bit.. Please help me....
Very often you will find that not much older periferials like Cameras, Printers, Ipods, Scanners, and many Applications do NOT work with VISTA 64 Bit O.S..
First go to the CAMERA MANUFACTURER Customer Services or Website and see if they have a PATCH or another Driver for this camera so it can operate on VISTA 64 Bit. If it does, simply DOWNLOAD THE DRIVER AND "RUN" it and it will replace to old driver and your Camera will Run Properly,
If there is no Driver offered to run on 64 bit program then you have more serious issues that require more radical fixes which you have to evaluate on the basis of how much you need the Periferial or can there be a substitute that can run on the 64 bit program. 64 Bit programs are basically not much different from the much more popular 32 Bit Programs your camera would probably work on, no problem.
Try Calling Microsoft Customer Service and/or look on their Home Page for Solutions but generally the only alternative is:
1) Return the Camera and Exchange for one that runs on Vista 64 bit O.S.
2) Downgrade your Computer to a 32 Bit Version of Vista.
3) Look for the latest Beta Solutions you usually find on Google that may fix this
Vista 64 Bit O.S. Versions are only necessary if you are using more than 4 GB of RAM for e.g. GAMMERS who require a lot of Memory (actually up to 128 GB). Otherwise there is little difference between 32 and 64 bit versions. As VISTA was not that popular to begin with, many manufacturers did not bother providing UPGRADED SOFTWARE AND DRIVERS for VISTA 64 BIT assuming few would buy it off the shelf and mostly their product would be used with WIn XP or Vista 32 Bit until the Next Microsoft O.S. Came around.
Vista is a Memory Hog and as such should be used with only 4 GB of RAM for it to run properly. 3 is adequate, 2 GB its lethargic at best. VISTA 32 bit HAS A LIMIT OF 4 GB of RAM so that is cutting it close but still a better idea to "DOWNGRADE" to 32 Bit so your O.S. would be much more compatable with other Periferals and Software Applications. Many Periferals ( appliances) and Applictions will not run on 64 bit programs especially if they were designed before 64 bit was introduced. THE BEST FIX, IF YOU ARE NOT A RAD GAMMER REQUIRING MORE THAN 4 GB OF RAM is to "DOWNGRADE" TO VISTA 32 bit or even better to Windows XP if your computer can work with that O.S.: check with the Manufacturer. Your camera may even work on XP 64 bit.
Kodak still makes some nice disposable Film Cameras; you can take your pictures then have them developed, and scan them into your computer that is if your SCANNER STILL WORKS with the 64 bit program LOL
Good Luck
Aug 20, 2009 | Lenovo ThinkPad T61 Notebook
Windows XP Professional x64 Will not start up with more than 2gb.
Move your ram into different slots, put different ram in slot 2 or 3, sounds like bad ram, 32 bit apps access ram VERY diferently that 64 bit apps.
Mar 25, 2009 | Microsoft Windows XP Professional x64...
Cust is not able to download any program on vista operating system it gives an error message as not supported on windows 64 bit
there is very little software, and virtually no freeware, that supports vista 64 bit. return the computer if u can and exchange it for one with vista 32 bit, these machines usually have 3 gigs or less of ram, where as the vista 64 bit systems will typically have 4 or more gigs of ram.
Nov 28, 2008 | HP xw6600 Workstation with 650W 80 PLUS...
4 gigs of ram on xp 32 bit
Depends on how much memory your motherboard can accomodate. If *********** board can support 4 gig then just plug your ram and it should work.. xp supports up to 4 gig of ram so even if you connect an 8 gig,it will only recognize the 4gig. Hope this help,
May 11, 2008 | Microsoft Windows XP Professional
It says board can take 4 gig of memory but back slots 2 big
If your MoBo supports 4 Gigs, Vista 32 bit will only utilize approximately 3.48GB, and XP 32 bit will only use 2GB, so unless you are running Vista 64 bit (which will use up to 8GB, if your MoBo will?), the OS isn't going to see but 2 to 3+ depending on which version of windows you're running,
As for the slots being too big, you are probably attempting to install the wrong RAM for your MoBo. Compare the RAM in question with what the MoBo manufacturer says is compatible.
Good luck, and I hope I helped you.
Apr 10, 2008 | Computers & Internet
Evga (122-CK-NF68-AR) Motherboard Logo
54 people viewed this question
Top Evga Computers & Internet Experts
David
David
Larry Rider
Larry Rider
Josh Levin
Josh Levin
Are you an Evga Computer and Internet Expert? Answer questions, earn points and help others
