Question about Toshiba 72HM196 72" Television
Wont turn on yellow light blinks 3 times pause and repeats no other lights on
    Problem Solver:
  • 22 Answers
If you can't get it on, you'll have to have a new Ballast assembly. Try unplugging it from the wall outlet. You may have to do this several times. Keep trying. If it won't start, probably the ballast. Always change the lamp with new if ballast gets changed. I got mine from Ebay.
Posted on Aug 14, 2014
ladywinn
  • 5138 Answers
SOURCE: wont turn on
Replace both of your STK ics 392-560s or 570s they maybe 392-110s if so use 392-180s call electronixs for parts 1-800-223-3205
Posted on Dec 12, 2008
  • 668 Answers
SOURCE: Blinking yellow light ,no picture or sound.
You have done all you can do. If you had a power outage, when the power came back on a it surged and probably caused a Power Supply problem or something in the micro controller to fail. Either way it 's not good. I would call Toshiba and let them guide you to a Service Facility that can check it out. Depending on your Homeowners Insurance, repairs could be coverd or unit be replaced depending on cost to repair.
Sorry I am not able to help further,
skyassoc
Posted on Jun 23, 2009
roety
  • 585 Answers
SOURCE: Toshiba 65" Rear Projection DLP TV
Hi my name is Roety,
I can help you with your issue ,
Most likey you need the Lamp replaced
Use google to buy one using the model #
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks
Posted on Nov 20, 2009
walesarumi
  • 6993 Answers
SOURCE: model 50HM67 - will not
your TV is having a power problem. The power supply board is defective that's why the TV won't power up. Its receiving power but it cannot transfer the current to the necessary part of the TV because a capacitor, diode, etc may have been faulty. Until these bad components are replaced, the TV might not come on.
This may have occurred as a result of power surge/irregular power supply or excess power that may have entered into the TV previously.
If you know about TV repairers, I would suggest that you open the TV and read the power board/panel with a meter, detect the bad component and replace it. Take note that TV stores a lot of current that can shock, so leave the TV for a while before you open it.
If you don't know about TV repairers, take the TV to the nearest repairman to fix the fault for you.
I wish you good luck.
Posted on Nov 24, 2010
ginko
  • 19396 Answers
SOURCE: toshiba 72HM195 blue light blinks
Hi.
Rather than the number of blinks you need to count the blinking time intervals.
If the yellow is staying on 3 seconds, and the blue blinks last half second, then the problem is the lamp cage door. In that case:
  • Disconnect power cord for ten minutes.
  • If problem persists, disconnect again and check lamp cage door.
  • Replace door switch (must be done by technically trained person).
I uploaded here the full error code troubleshooting for this model. Click on the link, then click on the picture again to enlarge. Alternatively print out the error codes page.
Regards.
Ginko.
Posted on Mar 27, 2011
What does a yellow wrench indicator light mean on a Pronto M41 w/Sure Step?
The yellow wrench is a diagnostic tool. How many times does it blink between pauses. Example might be 3 blinks then pause then 3 blinks then pause, over and over. Hoe many does your chair blink?
May 07, 2014 | Electric Mobility Pronto M41 Power Chair...
Led light flashes 4 times, pauses then repeats
Which light blinks 4 times and pauses wash normal heavy etc if the model in the blue box is correct the to enter diagnostic press any 3 keys within 8 seconds I usually use normal and the 2 keys to the right all lights should light up if touch pad is up top where you had to open door to accomplish this then close the door after a pause the clean light will begin to flash example 7 flashes pause 1 flash these are your fault code it will do this 3 times for each code. The tech sheet should be behind the toe panel located below the dishwasher door which just repeats what I explained.
Feb 04, 2014 | KitchenAid KUDE70FXSS Builtin Dishwasher
My sony trinitron kV ES 34M90 GIVES 6 ERROR BLINK CODES
Six blinks - No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206. To get more details, http://electronicshelponline.blogspot.com/
Nov 28, 2013 | Sony Televison & Video
Error code 13 on mitsubishi wd52628
wait for the light to go out then press power. Then if it doesnt power up hold the menu and the Device/input buttons on the set both in together for 5 seconds the light will blink a series of blinks pause briefly then blink another number of blinks then pause then it will repeat the same two digit blink sequence a few times . Let me know the two digit blink sequence.
Aug 29, 2012 | Mitsubishi WD-52628 52" Projection HDTV
Red light flashing, tv wont turn on
need the model number of the panasonic and also how many times it is blinking. The blinking is an error code.
Aug 03, 2012 | Panasonic Televison & Video
I cant get sony trinitron to turn on. the standby/timer red light blinks several times and it wont turn on what can i do i am bored without tv
Likely damage to main power supply-------try to see if there is a specific number of blinks then a pause and repeats like 7 blinks a pause and repeats---that is an error code if there---with it AND THE MODEL NUMBER OF THE TV I might be able or not to help.
May 25, 2012 | Televison & Video
Door stopped working when I was trying to adjust the door. Blinking yellow light on the overhead unit
The motor has a thermal overload that will turn it off it if starts to overheat. Normally a 15 or 20 minute rest and it will automatically reset. The blinking yellow light may be sending a code. If it blinks 5 times and then pauses and then repeats it is the overload.
Feb 10, 2011 | Sears Craftsman LiftMaster Chamberlain...
I have a toshiba 42HL167. Love it but recently when the power is off iget a repeating blinking yellow light. Blinks 3 times pauses blinks 3 time pauses blinks either 2 or 3 times then stops for 25 seconds...
Yes. The Yellow LED blinking 3 times is a normal boot-up, but if it keeps doing it -- it needs the firmware "update" (which is more like a reload because it got corrupted.) The problem is, no one talks about how to do that. (there is a PDF and firmware on toshiba's website, but it lacks some crucial details.)
My friend gave me his 42HL167 after this problem started after a power event during a storm and I managed to fix it by reloading the firmware.
I posted instructions on my website at:
http://www.benjammin.net/www/pages/techtips/Toshiba-Regza-42HL167.html
Once I figured out some of the facts, it was a breeze...
Nov 06, 2009 | Toshiba 42HL167 42 in. LCD Television
I use nissan sentra 2002 my service engine soon is on for 2weeks
Finding out what the code number is, is the first step.
You can find this easily by watching the blinking yellow check engine light and counting the number of flashes for each of the numbers in the 4 digit fault code.
To do this without a code reader; sit in the car and turn the ignition on (do not start the car) and after 3 seconds push the accelerator pedal all the way down to the floor and release fully (pull your floor mat out from under the gas pedal). After the 3 seconds, do this 5 times quickly, in less than 5 seconds. Then hold the accelerator pedal down for exactly 7 seconds and release it fully. Then within 10 seconds, the yellow check engine light will begin to blink.
The numbers of blinks will go from 1 to 10. A 10 will represent a "0".
For example; 0303 would be 1st number is 10 flashes, short pause then 3 flashes, short pause then 10 flashes, short pause and 3 flashes. It will repeat this again if there is only one fault code. There could be other fault codes and you would count those in the same way.
The 0303 code means that you have a cylinder misfire in the #3 cylinder. This could be a fouled plug, poor connection between the plug and the coil or something else.
To erase the code hold the gas pedal down while the yellow light is blinking for about 15 seconds then turn off the ingnition. Code will now be reset and light will go out.
If for some reason you do not get the yellow light to start blinking, tturn off the ignition and try it again. You may wish to get a watch with a second hand as the time is critical as to the seconds between steps.
After you find out what codes you have, send back an email and we can document the actual codes and the problems you are having.
Bob - 2003 Nissan Sentra SE-R spec V
Feb 11, 2009 | 2003 Nissan Sentra
Toshiba 72HM196 72" Television Logo
142 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
