Question about Canon imageCLASS MF4270 All-In-One Laser Printer
MF4270 won't connect to scan
The printer works fine, the scanner worked the other day and today it won't connect.
old marine
  • 2143 Answers
SOURCE: All in One Scanner/Printer problems
Go to this link and type "cannot communicate with scanner" in the search box. Click Search. Then select the "ERROR: Cannot communicate with scanner" link. You will see several things to try to correct your problem. Usually, this error shows up if there is another USB device connected which prevents the computer from "seeing" the scanner, even though it can print without problem. So do try to disconnect any other USB device (except mouse or keyboard) and reboot the system.
Posted on May 21, 2008
  • 4 Answers
SOURCE: scanner setting on canon pixma mp450 will not work.
Download drivers for PC or Mac from the official Canon website:
http://software.canon-europe.com/products/0010249.asp
Good luck! :)
Posted on Aug 15, 2008
SOURCE: trying to scan, but keep getting error code
I finally got a solution to my problem, which is the same as this one. When trying to scan via USB, you have to make sure the unit is set to USB. On the top panel just above the LCD display, is 3 buttons, Copy, Fax, Scan. Hit the SCAN button, till the display says USB SCANNING. Then try to scan again. Good luck!!
Posted on Sep 05, 2009
SOURCE: trying to scan, but keep getting error code 2,162,0 My scanner pr
This works!:
noavatar_s.gif the_sunman
Rank: Apprentice
Rating: 94%, 4 votes
Posted on Oct 21, 2009
drifterK
  • 4924 Answers
SOURCE: When i go to scan
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mx_series/pixma_mx340#DriversAndSoftware
go here and download and install the drivers for the operation system you use..even if they are installed do it again cause the driver may be corrupted or have a strange setting ..and reinstalling will default it ..
after that try again to make the connection ..
be sure the printer is set from the admin computer to be shared..and the drivers for the scanner are reinstalled..and try again ..
also check the firewall and even disable it for a moment cause it might be an issue ..and being on a closed network will not cause it any harm by doing it ..
Posted on Sep 04, 2010
Imageclass MF 4270 scans are too light
you can Adjust the density level of scanned image manually from MF4270 read the manual
if you don't have manual please visit this link
Download Canon imageCLASS MF4270 Reference Manual
hope that it will solve your problem
Feb 04, 2014 | Canon Office Equipment & Supplies
I was getting streaking across all photos that I was scanning. So bad that I researched getting a new scanner. Then one day it started working just fine. Now today I scanned some slides and when I tried to...
sounds like the scanner is skipping pixels. that is usually a sign of malfuncting. the best solution is get a new one. cost of getting new one is much cheaper to repair it.
Oct 17, 2009 | Canon CanoScan 4400f MultiFunction Color...
No Scan Options
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.hp.com/printer/prob676ijt65/solution
alkkk-3
Jul 01, 2009 | HP Officejet 5610 All-In-One InkJet...
Printer and copier work fine- scanner says USB not connected.
I had this same problem and it is fixable, but not the way you would probably like, though you can still scan with the printer. You just have to open the Paint program and click from scanner or camera, and then choose your printer and click scan preview, and then scan, it works just fine but its a little time consuming.
Jun 01, 2009 | HP Photosmart C4280 All-in-One InkJet...
USB NOT CONNECTED ERROR WHEN IT IS CONNECTED
This is a HP hardware/software error and HP has not fixed it.
The C4250 may report that "USB is not connected" but the printer works just fine and when you use the Microsoft Scanner and Camera Wizard to carry out a scan, it works just fine too. So the error message is wrong.
The Microsost Scanner and Camera Wizard can be found on the Control Panel.
May 05, 2009 | HP Photosmart C4250 Multifunction Photo...
Scanner
Try scanning from the Kodak AiO Home Center software. If that fails, you should get better feedback. Unfortunately, I have run into this when my ink is low. While it should not matter, is does. Check to see if you need to replace a cartridge.
Good Luck.
DigiChick.
May 20, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Refuses to Scan - All connections have been checked
i was lost my softer cd there fore please send me softer &dierver
Feb 11, 2008 | HP Officejet 5610 All-In-One InkJet...
Scanner Problems
uninstall the device and reinstall it
you need to reinstall the drivers
Mar 09, 2007 | Canon PIXMA MP780 All-In-One InkJet...
Canon imageCLASS MF4270 All-In-One Laser Printer Logo
51 people viewed this question
old marine
old marine
