Question about Samsung RS265TDRS Side by Side Refrigerator
The screen on my samsung side "OF" on the digital temperature screen
Neither the fridge of freezer are staying cold
  • 1462 Answers
SOURCE: SAMSUNG SIDE BY SIDE FRIDGE FREEZER
these appliances are a pain in the butt. fault with water dispensor is oprob that the water bottle at bottom of fridge is frozen. rise in temp is prob that defrost not taking place. not a diy unless you are experienced
Posted on Mar 20, 2007
SOURCE: Samsung RCS21DCNS Side by Side
probly the evaporator coil in fridge all frozen up you need to pull all the back out inside the fridge section and defrost with air drier
Posted on Sep 21, 2007
SOURCE: SAMSUNG SIDE BY SIDE RS2556
Is it blinking 34???
Posted on Jun 17, 2008
SOURCE: Samsung RS2556 - Refrigerator side is not cooling - Freezer is fine
Ok, what I found out is that there are codes built into the front panel. If you hold the top left and right buttons for 5 seconds, the fridge will reset. If there are no issues, the panel goes blank. If there is a dash in the right side of the panel, there is an issue with the fridge side. In the left, freezer side. The dash indicates a defrost problem. Only a couple of things can cause this. 1. Sensor 2. Heater 3. Fan, 4. control board.
Posted on Jul 02, 2008
SOURCE: SAMSUNG RS20CCMS AMERICAN STYLE FRIDGE FREEZER
in the freezer section there is a 6 screws. unscrew them and remove the back panel. there will be 2 wires attached to the panels, remember where they go. you will see a metal evaporator which will be filled with ice. this is the problem. use a hairdryer to melt the ice. this is essential as you mustn't puncture the wall of the fridge with any sharp item. before replacing the panel ensure that everything is dry or ice will reform, and also ensure that the fan blades are turning properly or cold air will not be blown into the fridge.
Posted on Dec 10, 2008
Samsung side by side refrigerator RS265TDRS started making loud propeller like noise on the cooler side half way up. Notice bunch of ice around the lights on the back wall of it. I unplugged the fridge for...
A COUPLE THINGS U SAY FREEZER IS FINE FRIDGE IS NOT? THE FAN NOISE MAY BE DUE TO ICE BUILD UP DUE TO A DEFECTIVE BAD DEFROST TERMINATOR. WHICH EVENTUALLY WILL BUILD ICE UP IN FREEZER AND FRIDGE? HINDER COLD AIR CIRCULATION. ANOTHER THING TO LOOK AT IS UR FREEZER AND FRIDGE THERMISTORS AND UR COLD CONTROL THERMOSTAT. EVEN UR AIR FLOW DAMPER CONTROL VENT AND KNOB SETTINGS? ARE THEY TO FAR OPEN OR CLOSED? ARE U ABLE TO HEAR THE FAN AND COMPRESSOR RUNNING? ANY CLICKING SOUNDS?
Feb 25, 2012 | Samsung RS265TDRS Side by Side...
Refrigerator (Samsung RS2555SL) quit cooling on both sides. Front panel was blinking at set temperatures (34 fridge side/0 freezer side) but inside was warm. I unplugged for 5 min and ran self-diagnostic...
hello dont know if you have the same model
but this may be worht a look
samsung fridge freezer problems
http://www.youtube.com/v/RP9XLji-gdw?fs=1&hl=en_GB&color1=0xe1600f&color2=0xfebd01"> name="allowFullScreen" value="true">http://www.youtube.com/v/RP9XLji-gdw?fs=1&hl=en_GB&color1=0xe1600f&color2=0xfebd01" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344">
Sep 28, 2010 | Samsung RS2578BB Side by Side Refrigerator
I have a samsung side by side fridge, and the fridge side is not staying cool, but the chill drawers are keeping the right temp??? The Model# is RS267LABP
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
The chill drawers are probably staying cold because there is a vent to the freezer in the wall for the cold air to seep through.
Nov 03, 2009 | Coffee Makers & Espresso Machines
Fridge side wont cool properly.
Check out this link below for a PDF manual on your item. Great information to have. Just copy and paste into your browser.
http://www.samsung.com/us/function/search/espsearchResult.do?keywords=RS2630SH&input_keyword=RS2630SH
Try this:
Temperature Adjustment
• After 24 hours, adjust the controls as needed. Adjust temperature gradually: push the button in small increments,
allowing the temperature to stabilize.
• Press the button(Freezer Temp or Fridge Temp) repeatedly until the desired set temper.
• For lower temperature, press the button(Freezer Temp or Fridge Temp) towards coldest.
• For higher temperature, press the button(Freezer Temp or Fridge Temp) towards cold.
If this does not work for you let me know or you can contact Samsung support at 1-800-SAMSUNG (1-800-726-7864) Mon - Sun : 9am - 9pm (EST).
Or you can try this Live chat at this link below, just look to the middle left of their page for live chat:
http://www.samsung.com/us/info/contactus.html
Let me know how this works for you or if I can help you with anything else.
JimmyC
Oct 06, 2009 | Samsung RS2630SH Side by Side Refrigerator
I have a samsung fridge, model # rs-2545sh
check the cold for what you want but the ideal settings would be 5 for the freezer and 37 for the fridge
freezer can be really cold but the fridge if too cold will freeze vegetables and lettuce
Jan 03, 2018 | Samsung RS2630SH Side by Side Refrigerator
Samsung fridge freezer not cold enough
Hello whiten61,
Welcome,
You said, You noticed there was condensation in my fridge and a strange smell coming from it, also my freezer was cold but didn't seem to be cold enough, I have a digital display and it was still showing -22 for freezer and 3 for fridge. I turned the power off on the wall and when i turned it back on which was straight away it shown -3 for freezer and 16 for fridge... I then noticed the ice cream in freezer very watery, however ice in freezer still frozen? i pressed the quick freeze button which eventually the temperature came back up but i keep getting the exact same problem... Can you help. thank you.
Samsung side by side refrigerator SR-S2025CVW
How old is the fridge?
You did all the right things!!
But this sounds like a bad thermostat.
or a bad control switch.
Unfortunately it sounds like you may need service to do an hands on diagnoses and replacement of one of these parts I listed here!
Let me know how you do! Or if you need something else.
We do have very good sponsors here on this site that do repair work, should you take this course!
Huuum
Please remember to leave a rating.
Oct 14, 2008 | Samsung RS2630SH Side by Side Refrigerator
May 22, 2008 | Samsung 24.8 Cu. Ft. Side-by-Side...
Fridge running but not staying cold
you have a defrost problem, if SxS ref. most likely bad defrost heaters. They are behind interior back wall. Sounds like you have a GE.
Jan 05, 2008 | Refrigerators
Side by side fridge freezer
Based on your weird display issues I'd lean toward the control board problem. At least that can be "one" of a couple problems...
Feb 01, 2007 | Samsung RS2578BB Side by Side Refrigerator
Samsung RS265TDRS Side by Side Refrigerator Logo
12 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
