Specific battery life bauhn 7 day dig timer PS42309A
Where can I buy the Aube 7-Day Programmable 40-500w timer
You might be looking for T-1032 or T-1034 500watt timer
Identify model number on following link, and then google-search that specific model.
Link to instruction manual appears for each timer.
http://waterheatertimer.org/Aube-timers-and-manuals.html
Honeywell Aube in-wall timers can be used for single-pole or 3-way applications.
Look at instruction manual carefully for 3-way wiring.
Timer can be used for incandescent, halogen and CFL with minimum wattage requirement.
Since Aube timers have internal battery, they cannot be exposed to freezing temperatures or high temperatures.
Sep 28, 2011 | Aube Technologies Aube 7-Day Programmable...
Where can we purchase Aube 7-Day Programmable 40-500w Light Timer Switch
WOODS 59018 TIMER WIREING CORRECT INSTALLED WITH POWER OFF NETURAL GROUND UP TO CODE LOAD /LINE PROPER.NEW OUT OF BOX WON'T RESET. STEP 1 LAMPS LOAD SIDE GOOD. RETIRED CONSTRUCTION ELECTRICIAN
I don't have answer for defective timer. Buy another timer if everything below checks out:
59018 7-day timer has limited 1 year warranty, and appears to be made by Tork
Timer is for 120Volt single-pole only.
Rated for 1000 watt tungsten, 8A ballast, 1/4 HP
Push reset button with toothpick > not necessary to press-and-hold other button to accomplish reset.
After reset, 12:00 am Monday should display.
Programs are deleted. Reprogram timer.
To check, change and delete specific programming, press PROG key until selected program displays, and then set new programming >>> or press-and-hold MODE button and press PROG button again to delete selected program.
Timer has non-replaceable 30-day carryover battery and does not lose programming after power outage, and will retain programs until battery is depleted.
Review wiring:
Hot to timer black.
Neutral to timer white.
Load to timer red.
Ground to timer green.
Lights will blink if timer red and timer white are connected to load together.
Timer will not function if timer black and red wires are reversed. Display will not show.
http://waterheatertimer.org/Woods-timers-and-manuals.html#59028
Aug 07, 2011 | Woods InWall 7 Day Digital Programmable...
Sunset sunrise doesn't seem to work anymore
Timer is not identified.
If digital timer does not function as before, try resetting timer and then re-program.
If timer has battery, then change battery and reset timer.
If reset does not restore functionality, then timer has gone bad. Most in-wall timers have 1 year limited warranty.
Below are common 7-day timers, but there are many different brands:
You posted under Woods 7-day timer: except Woods timer does not astronomic dawn dusk function. Woods 7-day is same as Tork 7-day and GE 7-day, and they do not have astronomic function.
http://waterheatertimer.org/pdf/Woods-59018-59028.pdf
Reset button is small round button.
Push in reset with toothpick or paper clip.
Then reprogram timer.
If you have Intermatic ST01C or EJ500 battery operated timer: Replace battery, then to reset timer: push-and-hold ON_OFF button, and then push reset button. Keep holding on-off button until display changes. Release on-off button and display will flash 12:00. Then reprogram timer.
http://waterheatertimer.org/Intermatic-timers-and-manuals.html
If you have Utilitec astronomic timer, then press reset button and reprogram:
http://waterheatertimer.org/Program-wire-Utilitec-LW60419.html
Aug 05, 2011 | Woods InWall 7 Day Digital Programmable...
59403 - OUTDOOR 7-DAY DIGITAL TIMER: with battery backup and if the power fails; does the clock stop or keep 'ticking'?
http://waterheatertimer.org/pdf/Woods-59403.pdf
The battery operates the timer.
If power goes out, the timer still functions as long as the battery is working.
To test, unplug the timer.
Nov 09, 2010 | Woods Outdoor 7 Day Digital Two Outlet...
I've lost the instructions on how to program the timer. Thank you for your help.
You posted the question under Woods 59377 indoor plug-in timer.
If you have a different timer, please re-post make-and-model and we will find that manual.
Link below is for the Woods 59377 manual
If you have a specific problem with the instructions, answer back and I will help.
http://waterheatertimer.org/pdf/Woods-59377.pdf
Plug in timer to charge battery.
When battery is charged, remove timer from plug so programming is easy
Plug timer back in, timer has two plugs for lights
If battery will not charge, then timer is no good.
Oct 25, 2010 | Woods Industries 59377 Indoor Digital...
Can i have programming instructions?
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
http://waterheatertimer.org/Aube-timers.html
http://www.aubetech.com/products/list.php?noLangue=2&noFamille=5&app=13
Links above shows 10 different Aube models
Select your model, click link next to your model, next page has instruction manuals at bottom of page
Each model has different instructions
4 models are 7-day timers
4 models are sunrise-sunset timers
2 models are combo sunrise-sunset
There are 2 exterior box-type timers with choice of sunrise-sunset or 7 day, depending on model
The instructions vary by model
Let us know if you have problems with specific instructions
Oct 19, 2010 | Aube Technologies Aube 7-Day Programmable...
Change engine oil soon light on, how do I turn it off?
Turn the ignition to ON. Press the GAGE INFO button on the driver information center (DIG) switch to view OIL LIFE INDEX. Press and hold the RESET button on the DIG until the display reads OIL LIFE INDEX 100% NORMAL. The engine oil life monitor is now reset.. Turn the ignition OFF.
Best of luck.
Greg
Jul 04, 2009 | 2003 Buick LeSabre
Computers & Internet Logo
168 people viewed this question
David Payne
David Payne
