Question about Konica Minolta bizhub C450P Laser Printer
Printing Crinkled paper
When I make copies my printer is printing crinkled paper. How can I fix this issue?
  • Konica Minolta Master
  • 6,161 Answers
Replace the fuser unit
Posted on Jan 10, 2016
3 Suggested Answers
Shah_Sheh
  • 81 Answers
SOURCE: magicolor 5440dl manual feed jams paper as it
If the paper was damaged we can presume that there is a blockage, however your jam sounds like the paper is not in the expected position at the expected time (ie a sensor is not reporting that a peice of paper has reached it) so this can be cased by
1. rollers slipping on the paper from
a/ slippy media - try a different paper (even as a test)
b/Build up of paper dust on the rollers- If you can see the roller, power off and wipe with cloth
c/ Roller ware - If you can see the roller and have a mild abreahisive like wire woll If you can see the roller and give the rollers a rub
2. Sensor failure-Try Powering off then unplug wait 2 minutes and then power back up, this will reinitilise a sensor
Posted on Sep 10, 2009
  • 351 Answers
SOURCE: My Konica Minolta bizhub C250 seems prints about
The paper may not be feeding straight out of the paper tray due to poor stacking of the paper in the paper cassette. try another paper tray or check the paper in the paper tray for folded over papers usually near the bottom. Also try feeding paper from the hand feed tray on the left side. This uses a different paper path.
Posted on Dec 07, 2010
Tip
Printing tips for paper jam
<b>ThePaper Jam</b> Wehave all had this one happen. You are printing merrilyaway when all of a suddenyou hear that distinctive crunch of paper gettingeaten by your printer. Youimmediately cancel the print job, leap from yourdesk and flip open the printer."Ugh," you say as you notice the crinkled edgesof paper wrapped around godknows what. Okay, so you have found the problem,but what do you do? Thebest way to remove a paper jam is to gently pull thepaper in the direction ofthe paper path-with power off, of course. Whateveryou do, don not pull thepaper backwards. You could damage your printer foreverby doing so!
on Mar 31, 2011 | Office Equipment & Supplies
User printing envelopes from MP tray. Envelope is getting bent and crinkled on the trailing edge. The size meets specs for the 1370dn. What else could be the issue here?
Printing with envelopes is a hit and miss affair. The best ones to use are the ones you have to lick. Dont think of using the ones where you have to peel the strip off. Also make sure you tell the pc that you are printing evelopes as this will allow the fuser to run cooler so as not to melt the adhesive too much. crinkling is usually down to excessive heat.
Jul 05, 2011 | Kyocera FS1370DN Laser Printer
When printing paper comes out all "crinkled" maybe roller problem?
It the paper comes out crinkled or accordion looking then it is your fuser. Check where your the paper comes out of. There might be a piece of paper jammed in there that is causing this. If no obstuctions then it might be the roller on the fuser cracking and cause it to crinkle the paper. The fuser is the last thing the paper goes through before coming out. It "fuses" the toner to the paper.
Apr 26, 2010 | Brother MFC-8660DN 5-in-1 Laser...
Paper is coming out wrinkled in one spot
Most of the crinkled paper issues I deal with have to do with the fuser roller lining going bad. If this is your issue the crinkle will be a vertical line from the leading edge to the trailing edge. You will need a new fuser.
Jan 30, 2009 | HP LaserJet 2840 All-In-One Printer
Crinkled paper
Pop open door to make sure nothing is stuck near rollers. Could be paper, staple, paperclip, etc. Clean out and try again.
Is it the same paper you always used?
Feb 26, 2008 | Brother MFC-8460N All-In-One Printer
PAPER CRINKLING
First check the paper path for something in the paper path. Staple, paper clip, etc, causing the paper to twist. Reseat the imaging unit and see if the transfer unit is seated properly.
But, What sounds most likely is that the fuser needs to be replaced. The rollers are most likely getting pretty bad inside that unit.
If I recall correctly, it is in the $200 range to replace.
Feb 16, 2008 | Xerox Phaser 6250DP Laser Printer
Crinkled paper
It sounds like a fuser problem. You may have something stuck in it, or the lower roller could be defective. You may have to replace the fuser.
Nov 01, 2007 | Lexmark E320 Laser Printer
Konica Minolta bizhub C450P Laser Printer Logo
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
