Question about Proform 505 CST Treadmill
Calibrate proform lx660 treadmill - Proform 505 CST Treadmill
SOURCE: Proform 520
Not sure what's happened here. treadmill won't turn on when red key is inserted. checked electrical plug to make sure it worked. I couldn't see that there's anything wrong with the red key. Have any ideas?
Posted on Sep 12, 2009
taran_2005
  • 10515 Answers
SOURCE: Proform 765 treadmill slows down when step on. Do
More likely time to replace the belt. Let me provide you with all the information you need. This information is already there on many websites.
BELT LOSES POWER
(Bogs Down or is Sluggish) This condition is when the treadmill operates normally without a person on the belt and then slows down when someone steps on the belt or when the treadmill operates normally for a given period of time with someone on the belt then abruptly begins to slow down.
There are four typical causes for this problem (listed in order of our experience:
1) The walking belt and/or deck are worn. (85% of the time)
2) The walking belt and/or motor belt are too tight- if you have adjusted either recently. (8% of the time)
3) The motor has lost torque and needs brushes or has demagnetized. (5% of the time)
4) The controller is dropping output. (2% of the time)
Walking Belt is Worn:
The only certain way to test for a worn walking belt is to take a DC amp draw (if you have a DC treadmill) or an AC draw (for AC). Trying to look at the belt or a feel test is highly unreliable. Better tests, if you lack a DC ammeter (they are expensive for a good one), are a coast test or an incline test. To test the deck, go back to the Troubleshooting section and download the belt and deck inspections instructions. The coast test is to get on the treadmill as the lowest incline setting and walk on the treadmill at 3 MPH. Pull the safety key and it should take you 2-3 full steps to stop (this is a general rule…some like a few Tunturi models stop on a dime even with a healthy belt but most this tests works well upon). Fewer steps indicate high friction.
The incline test is to put the treadmill at max incline and walk on it at 3 MPH. If the treadmill operates normally at max incline but bogs down at minimum incline, replace the walking belt. Gravity takes over for the drive system eliminating the friction problem. On some heavily worn walking belts, this test will not eliminate the problem.
Walking Belt/Motor Belt too Tight:
If you have adjusted the walking belt or motor belt recently, check for this problem. When the belts start slipping, some people just crank down the belts and on treadmills, tighter is not necessarily better. The
tighter the belts, the more the drive system has to work to keep everything moving. You should be able to lift the walking belt (with the treadmill unplugged) in the center of the treadmill about 3” without straining. Tighter belts should be loosen but make sure you don’t create a dangerous slipping situation by loosening.
The motor belt (with the treadmill unplugged) should be able to be turned by hand to almost a 90 degree angle from its normal operating position. Loosen the belt if too tight. Make sure to test for slipping and if it does with the proper tension, replace the motor belt.
Needs Brushes / Demagnetized Motor:
Typically when we find a motor that has lost torque; it needs a new set of motor brushes. Typically we can make brushes for almost any motor if we don’t already stock them. Motor demagnetization is not that common but it does happen and it is normally easy to diagnose. If you have confirmed the belt and/or deck is not worn and the belts aren’t too tight, you can test for a motor torque problem. DO NOT USE YOUR HAND OR ANY OTHER BODY PART TO IMPEDE THE MOTOR…YOU WILL LIKELY LOSE YOUR BODY PART IN THE PROCESS IF THE MOTOR IS GOOD. The step to test for the motor is to use a foreign object preferably on a long shaft. First determine the direction of the motor spin (most have directional movement printed on the motor tag), then apply pressure with an object with downward pressure on the flywheel in the direction the flywheel is turning (do not attempt to put force against the rotating direction of the flywheel as you can easily injure yourself). If you can slow the motor, typically you need brush replacement.
To test for demagnetization, the motor must be disassembled. Once you have the motor retaining bolts removed, remove the motor core by sliding it out of the end of the housing. If the magnets pull the core against the housing and it is difficult to remove, the magnets are good. If the magnets do not attract the core, the motor has to be replaced.
Controller:
This is the most uncommon of the causes. Typically replacing a controller in this situation will not solve the underlying problem and then you will end up replacing a belt as well as a control. Normally if a control is dropping output, it will do it with a person on the belt or not. Tests of DC output dropping is normal in many controls since they have a current limiter which will automatically drop output to prevent burning up the board. This is best diagnosed by eliminating the other possible problems first. If you are left with the control as the cause, replace the control.
The site :-
http://www.treadmilldoctor.com/Treadmill-Belt-Bogs-Down
Any further assistance, let me know.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Oct 10, 2009
maxtreadmill
  • 832 Answers
SOURCE: How do you calibrate a ProForm 530x Treadmill?
To calibrate the speed and/or incline, please refer to the instructions that are under the motor hood cover or are mounted on the inside of the belly pan. Be sure to unplug your machine. If the instructions are not there, please contact our customer service department at {~1-888-533-1333} while you are near your machine.
Posted on Apr 11, 2010
maxtreadmill
  • 832 Answers
SOURCE: my treadmill Proform caliber walk... belts keeps
The deck needs to be lubricated. The lubricant can be purchase @ gympart.com. LUBRICATION PROCEDURE: 1. Turn off and unplug treadmill. 2. Cut off the end of the tube of lubricant. 3. Holding the tube in one hand, insert the tube underneath the treadbelt halfway between front and back and halfway between right and left. 4. Squeeze the full contents of the tube onto the deck in a circular pattern in the center 1/3 of the deck. 5. Plug in2_bing.gif and turn on treadmill, then walk normally on treadmill at 0.5 mph for five minutes
Posted on May 16, 2010
sureshreddy8
SOURCE: can't get my proform xp 580 trainer treadmill out the door
sony ericession text pro ck 15i i want incoming sound incrise (or)...how to sending blooth with video
Posted on Nov 20, 2012
My treadmill won't go down the platform how to lower it please help
If it is stuck in the incline position all you need to do is re-calibrate most of the time
The first step to re-calibrate the incline. ProForm provides calibration instructions in the treadmill owner's manual.
Hold down the "Stop" button and the "Speed" up button. Insert the safety key into the console then release the "Stop" and "Speed" buttons.
Press the "Stop" button then press either the "Incline" up or down button. Wait while the treadmill raises then lowers the incline ramp. Press the "Stop" button and remove the safety key.
Hope this helps or solves the problem, if you have any further questions please do not hesitate to contact us at 888-713-2880 or visit us online at
http://www.sportsmith.net/supportsearch.aspx
May 18, 2015 | Proform 1050T Treadmill
Cannot start treadmill
Need more info to help solve this. Does the console light up and look normal? Or is all the readouts blank?
Oct 14, 2012 | Proform LX660 Treadmill Walking Belt
Calibrate new console
Dear Sir:
Please see the instructions 1) some models attached under the Hood of the main motor 2) Other model is under the cover of display board.
3) Follow the instruction from user guide.
Adjust the reed swithc see the attached diagram
If you do not have user guide. go : www.proform. com go to customer service go then parts% Manuals, give your model, etc, and download for free your u. manual.
sincerely. God bless you.
ernesto cuadra
managua, nicaragua. c.a.
Feb 29, 2012 | Proform XP 580 Trainer Treadmill
Machine is plugged in but won't turn on. We haven't used it in about 6 months. Please advise as to what we can do. Other electrical appliances work using outlet that we have the treadmill plugged into.
Check the circuit breaker located beside the power cord. Be sure that it has not tripped. Snap it back into place if tripped.
Confirm that the on/off switch is switched on.
Insert the safety key in the slot on the front of the console. The console should light up.
If nothing lights up, I would suspect the power supply PCB, part #180635.
Dec 18, 2010 | Proform LX660 Treadmill Walking Belt
The treadmill stops after about 20 minutes or so. I push the fuse back in, and then I can start it again. It shuts off again after 15 - 20 minutes or less. Can I replace the fuse, or what is the...
try lubricating the running belt. Any decent sized fitness store should have a lubrication kit. Also, make sure the machine is plugged into a dedicated circuit. Meaning, there are no other devices on the same circuit as the treadmill. Not just the same outlet, but the entire circuit of the room you have the treadmill in. You also want to make sure it's not on any extension cords. Plug it into a surge protector (power bar with a cord less than 6') and then directly into the wall. Those are the 3 main culprits why treadmills shut down after a short period of time.
Jul 10, 2010 | Proform LX660 Treadmill Walking Belt
I have a proform xp 580. when I turn it on,
Press the Stop and the Speed Up keys down while inserting the safety key.
Press the Stop key one time. The Time window should read EP:2P. Some newer models may also say FP, Pass, or the like. This means that it passes the EPROM test.
Press either incline key and the incline will calibrate automatically.
After completing calibration of incline, press the Stop key and then remove the safety key.
Jun 12, 2010 | Proform XP 580 Trainer Treadmill
Turns needed to install adjustment bolts on rear roller of treadm
There is no turn amount, you just want to go until they are snug. Do not crank on the bolts or force them you will be able to tell when tight enough
May 31, 2010 | Proform LX660 Treadmill Walking Belt
Apr 10, 2010 | Proform 530 Treadmill Walking Belt
I have the proform 7.0 personal fitness trainer
Try to calibrate the incline threough the calibration mode.
Apr 13, 2009 | Exercise & Fitness
Proform 505 CST Treadmill Logo
48 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Electro Med Services...
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
