Question about Samsung BN59-00855A Remote Control
HOW DO I SET UP MY REMOTE
Remote stopped working
I need to find the user manuel for my audiosonic hdtd601 DVD set top box my remote control for the device has stopped working and I'm trying to connect it to my Sony Bravia TV REMOTE RM-GD003 HELPME
Hi Dennis, The sony bravo remote will only work with that television, You'll need either the same remote that stopped for your Audiosonic set top box or a universal remote........CHEERS..
Apr 07, 2016 | Sony Televison & Video
Remote control stopped working
You should synchronise the set with its set-up code after a power failure. If you wish to get more details; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" view. It will make surf easier.
http://electrohelponline.blogspot.com/
Mar 27, 2014 | Universal MX-900 Remote Control
My samsung remote AH59-02291A stopped working and cannot re programme it
If it is its original remote control, it should work without any adjustment after a battery replacement. If it is a universal remote control, you should set it up with with its set-up code, once again, after replacement of batteries in the remote control. If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" view. It will make surf easier.
Mar 09, 2014 | Samsung Ah5902291a Remote Control
Pioneer remote contyrol does't work with Pioneer 31FD blu ray
It will best to buy a remote control for TV, rather than try to repair this remote control. Sometimes, after repair, it won't work with Blu-ray; and it will be difficult to get a universal remote control for blue-ray. If you wish to buy its original remote control, contact the authorized service center, or authorized dealer to your device brand.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability? Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its user manual. Never accept a remote control, that hasn't both of this. If you see the site by "MOSAIC" view, will make surf easier.
Mar 02, 2014 | Pioneer Used Original VXX3351 Remote...
Remote will not work
Have the remotes which are infrared tested but seems unlikely both are bad, either the set has a lockout feature for the remote or maybe the receiver in the set is bad---get the remote as close to the receiver as possible to see if it works that way at all.
Dec 11, 2012 | Panasonic Viera TH-42PZ80U Plasma TV
Panasonic DMR-EZ485V. Remote stopped working when
Panasonic website under FAQs. Using code shown on dvd readout,
such as RC2, press 2 & enter or ok, hold for 2 seconds, and machine
will reset connection between remote & dvd recorder. So stupidly simple it works.
Feb 15, 2010 | Panasonic DMR-EZ485VK DVD Recorder/VCR
Tuner stops responding to remote though led
Well, if the remote has any kind of function working the set I would say the set is ok. Try replacing the batteries, if that doesn't help, then run to your local retail discount store and grab a cheapo universal remote, program it and see. If that fails then in the shop it goes. ( I doubt it tho )
Feb 01, 2010 | Panasonic Televison & Video
My remote suddenly stopped working.
If you're seeing on the LCD of the DVD player something like "DVD1" every time you press a button on the remote, try this: Change the command mode of the remote to match the player. Do that by holding down the Enter key on the remote and pressing the respective number. In my example above, hold Enter and press button 1 to set the command mode of the remote to DVD1. I had this problem and even unplugging the player didn't help, but the above worked for me.
Jul 16, 2009 | Sony RDR-VXD655 Recorder
Remote stopped work for my kp-61hs10
Sounds to me like a problem in the tv, not the remote. A short maybe, or a bad connection somewhere.
Dec 22, 2007 | Sony KP-61HS10 61" Rear Projection...
Samsung BN59-00855A Remote Control Logo
16 people viewed this question
Jerry Greenberg
Jerry Greenberg
