Question about Toshiba Satellite 4090XDVD Notebook
Dim display on Toshiba Satellite 4090XDVD notebook
I've got an old Toshiba Satellite 4090XDVD notebook. Still works fine but screen is very dim. Is it possible to brighten display? I heard about re-calibrating the display but having difficulty getting help on this.
Regards
John White
PS: Got the " (PAS409U-T2DW8) PC..." part of my product name from your input form.
  • Toshiba Master
  • 32,281 Answers
The backlight CCFL lamp provides the lighting for the LCD screen. If you have already adjusted the brightness to the max. setting and it is still dim, it means the CCFL lamp is is nearly worn out. To determine if you have a LCD screen or video card problem, read this and follow the instructions. Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp. Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case. The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills. Check out www.lcdparts.net for parts, repair service and DIY info.
Posted on Jun 18, 2009
HOW TO SOLVE LAP TOP SCREEN TOO DIM
have you tryed going into your display settings???
Jun 04, 2014 | Toshiba Satellite M35X-S111 Notebook
After changing the converter on satellite M305D-S4830 the backlight still very dim
i'm sure you ment inverter..if its working on external screen? it would seem. that you still need it replaced have u checked the ribbon cables?
Nov 23, 2013 | Toshiba Satellite M305D-S4830 Notebook
My Toshiba Satelite 4090XDVD laptop has stopped woking
hello, try unplugging the power cord from the laptop and then remove the battery too, wait for 15 seconds put the battery back in and plug the power cord back in, now try to power the laptop back on and see if it works.
let me know if it doesn't and if you see any change in any of the lights blinking.
Regards,
Amar Sondhi
Dec 05, 2009 | Toshiba Satellite 4090XDVD Notebook
I have a Toshiba Satellite A55-S1063 the scrren is dim but I can still see using a flashlight. I have had the back light replaced once it worked great for about 2 weeks and then went back to being very...
Hello !
Since the screen is dim, the display's inverter board needs to be replaced.
If you were experiencing discoloration in the screen (pinkish lower light hues) before it failed, that would indicate a CCFL backlight issue. If the screen suddenly went dim on you rather than a slow degradation, the inverter would be indicated.
Hope this helps.
Dec 01, 2009 | Toshiba Satellite A55-S1063 Notebook
Satellite M105 S322 Display very Dim. The PC works fine with external monitor but the LCD display is dim and cannot see anything on the screen
You have lost your backlight which is a thin long bulb built into the bottom of the screen itself. You have the option of getting the backlight by itself and rebuilding the screen or buying a new screen assembly and changing that out. Below is the service guide to change the screen.
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-M105/take-apart-notebook-1.htm
Below is a general guide for display problems....
http://www.laptoprepair101.com/laptop/2007/12/09/replace-laptop-backlight-ccfl-lamp/
Oct 27, 2009 | Computers & Internet
Monitor is dim
Sounds like your inverter is failing. The inverter takes the dc power from the battery and charger and converts to high voltage AC current for the backlight lamp inside the screen. When the inverter starts to fail, the display will sometimes blink, dim out over time, flash just get dark and stay that way.
Sep 28, 2009 | Toshiba Satellite A215-S7422 Notebook
Have a P105 S6164 bought used lcd screen very dim
With the replacement screen did you replace the inverter board? Many laptop screens also have a very small fuse built into their power connecttions. Check this also.
Apr 03, 2009 | Toshiba Satellite P105-S6104 Notebook
Just replaced a cracked screen in a toshiba a105-s4074....when i turn it on i can barely see the screen....it is very dim.....when i plug the old cracked 1 up it works fine....any suggestions?
If you see a dim image on the LCD screen it means you have a backlight problem.
Connect an external monitor to the laptop and power it up, if you see a clear image on an external monitor, this means your video card is OK.
Mar 10, 2009 | Toshiba Satellite A105-S4074 Notebook PC
Toshiba satellite 4090xdvd video driver problem
what op sys was on computer before install.. toshiba has all drivers on there web site
Nov 20, 2007 | Toshiba Satellite 4090XDVD Notebook
Toshiba Satellite 4090XDVD Notebook Logo
236 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
