Question about ViewSonic PJD5122 3D Projector
ViewSonic PJD5122 3D Projector bulb turn off within few seconds
4 Suggested Answers
SOURCE: Viewsonic PJ556d shuts down after 30-60 seconds
My solution sounds dumb, I had the same issue. Took the lamp cover off the bottom. The screws were loose holding in the lamp. Maybe they heat and expand and eventually work their way out and the lamp doesn't make good contact. Just tightened mine up, the unit would power off after 45 minutes prior. Been on now for 5 hours, no trouble.
Posted on Feb 11, 2009
SOURCE: my viewsonic pj400 projector switches itself off
hello
i have the same problem, a clear image, the the projector shuts down, turn the fan on, and "lamp" blinks.
i returned my projector to viewsonic service center, they told me to change the lamp.
the problem is that a lamp is very expensive!
HudgeFR
Posted on Aug 05, 2009
salt56
  • 373 Answers
SOURCE: I have a Viewsonic PJ558D
You need to reset the lamp timer. This is likely your problem since you changed the lamp.
Turn the projector on. open the menu. Go to advanced. Scroll down to the first option which should be auto source. Make sure this option is checked. While on this option press right once, left twice, right 3 times, then left 4 times. Another menu will appear. Scroll to lamp time and push enter. This will take it back to zero.
Posted on Jun 12, 2011
Viewsonic PJ558D shuts off after a few seconds
Sounds like the ballast board for the lamp stopped working.
Nov 19, 2014 | ViewSonic PJ558D DLP Projector
Viewsonic Pjd6531w bulb not turning on and projector requires unplugging to turn off
Have a good day! any question ,contact me,Please
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry Lampdeng Limited
Mobile: 0086-13178867858
Wechat ID: 008613178867858
Whatapp ID: 008613178867858
Skype: lampdeng@hotmail.com
http://www.lampdeng.com
Feb 23, 2014 | ViewSonic PJD6531W Projector
Bulb not turn
bulb should stationary, not fault.
make sure bulb proper fit, push in hard, screw up, all covers on and screw, all cables correct insert, hours reset if exceed safe limit.
then google viewsonic pjd6251 projector manual
Jan 29, 2014 | ViewSonic PJD6251 Projector
I turn on my Viewsonic PJD6251 but the lamp does not come on, and after a few seconds I get 2 red lights TEMP and LAMP. It is new, only 2 weeks I barely used. Good care.
sounds like a bad bulb
projectors get a resistance reading from the bulb and if it doesnt get right value it will give you the double red lights
only other thing it could be is if the fans in projector are not turning on
call viewsonic and tell them issue and make them resolve issue
or
if unit is only 2 weeks old bring it back to store and get replacement or call viewsonic and get them to send you replacement unit - it is too new to mess with it yourself and take chance on voiding warranty
Mar 24, 2011 | ViewSonic PJD6251 Projector
My viewsonic pj400 projector switches itself off
hello
HudgeFR
Jul 13, 2009 | ViewSonic PJ400 LCD Projector
Sep 15, 2008 | ViewSonic PJ556D DLP Projector
My ViewSonic PJ458D problem
This is known as 'cycling' and is common with mercury-vapor bulbs nearing end-of-life. When the bulb first starts, it glows dimly and grows in brillance. As the light grows, the pressure and temperature of the bulb also grows--increasing power demand. After a short while, the demand exceeds the ballast limit and the bulb extenguishes until the temperature (and pressure) drop again. Then, the cycle starts over. Bottom line: you need a new bulb (or, the correct bulb).
Nov 13, 2007 | ViewSonic PJ458D DLP Projector Multimedia...
Shrinking Screen Display
It can be a problem with teh bulb...you may want to make sure that the fan is not shutting down when you power off the projector becsue that may shorten the life of the bulb,...the fan should remain on for a while to continue cooling off the bulb....it probably won't hurt to have use another fan pointing to the projector while in use...
Apr 30, 2007 | ViewSonic PJ458D Multimedia Projector
ViewSonic PJD5122 3D Projector Logo
48 people viewed this question
Top ViewSonic Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Are you a ViewSonic Office Equipment and Supply Expert? Answer questions, earn points and help others
