Question about RCA LED55C55R120Q 55" 1080p 120Hz LED HDTV Black
The unit sound like it is in Cinema Mode - RCA LED55C55R120Q 55" 1080p 120Hz LED HDTV Black
Says ct mode on my cinema sc-pt750 and i cannot lower or increase volume
I am assuming you have got a panasonic DVD Home Theater Sound system.
Please confirm whether the display shows CD MODE or CT MODE. I am not sure if there is anything like CT mode.
It is possible the CD Mode button on the remote unit has been pressed. In this case press the CANCEL button or the CD Mode button and see if the system is operating otherwise.
In case you do not have the manual see this site.
If this helps then please accept the solution otherwise post a comment with some more information on what are you actually doing with the system when the problem occurs.
Sep 05, 2011 | Panasonic Home Theater System System
Tring to connect my samsung tv to my samsung home cinema and having problems
Hi,here is my simple solution...
to listen your TV on your Stereo system thru your
samsung home cinema receiver,
** you need to connect "Audio Output " RCA jacks or "Optic cable output" of your TV
** to "AUX input " or "TV" OR "Any input" of your receiver ( except Phone ) or "Optic Cable input"
** than just switch to respective mode on
samsung home cinema RECEIVER corresponding your RCA or Optic connection..
There you go..Your TV sound is on the
samsung home cinema Receiver..By this means whatever you watch on the TV (TV tuner, satellite , Xbox ..etc.) ,it's sound will come thru your stereo..
Hope this helps!..if more help requires pls let me know.
Take care and please
Remember to rate/vote and give me 4 Thumbs Up for me to continue f
or Helping out the Community :)
Jun 25, 2011 | Samsung Audio Players & Recorders
Ht-z210 home cinema protect error
Protection Error means that there is a malfunctioning component inside your unit. It will go into protection mode and immediately shut down to protect your system from any further damage. Unfortunately you would have to bring it to a dealer or repair shop to diagnose the exact malfunction and that could be expensive.
Gary
Jul 18, 2009 | Samsung HT-X20 Home Cinema 600W Theater...
The system goes into Sleep mode every 5 minutes and just before going into the sleep mode,''protection Error'' flases on the screen
Unfortunately, the unit is not going into "Sleep mode".
The PROTECTION error actually means that the unit is overheating.
The unit shuts itself off to avoid further damage.
Try to make sure that no other device is below the unit. Also make sure the unit has adequate ventilation on the back of it.
If not, call 1-800-7267864 and let them set up a repair order for the unit.
Jun 30, 2009 | Samsung HT-X20 Home Cinema 600W Theater...
Audio
Protect mode will kick in whenever a fault is detected.
You get the unit not powering up, and sometimes you hear a clicking noise, that is the protection switch that keeps shutting down the unit.
Causes that can start protect mode are:
Electrostatic harges on internal circuits.
Leave the unit unplugged for power for one hour or so, this will allow discharge.
Bad speaker wiring.
Check speaker wiring, try unplugging and plugging back, or start after removing one speaker at the time.
Internal fault.
Internal fault is the natural cause for protect mode. If all the above did not work, then the problem is a blown component or an internal fault. In this case the unit must be taken apart , tested and repaired by an experienced person.
If the unit is less than one year old, or if you want to get service, call Sony at the phone number listed on the product documentation.
Regards.
Mar 21, 2009 | Samsung HT-X20 Home Cinema 600W Theater...
No sound when viewing normal TV broadcasts
You need to have either the red/white audio cable connected from TV out to cinema system in or a optical or coaxial cable tv out to cinema in.
Nov 30, 2008 | Sony DAV-IS10 System
Sharp television and panasonic cinema system with hdmi connection
Ok, here's the deal. You can have sound being putout from hdmi coming from one of those sharp units, but it just depends on how you are connected. If you are using a digital audio output, from the tv, it wont push out the sound the way that it should. You will have to downgrade to using audio composite cables to connect to your external speaker system from the audio ouputs, not the digital audio outputs. Its not designed to push out sound from an hdmi cable. The BEST way to have this setup is to run your sound directly from the cinema to the external audio source(leaving the hdmi cable in the tv).
Nov 17, 2008 | Sharp Aquos LC-32D40U Television
SAMSUNG HT-TZ212 home cinema kit comes up with protect
Protect mode will kicking whenever a fault is detected.
Bad speaker wiring.
Internal fault.
Regards.
Nov 14, 2008 | Samsung 500w Rrss Rear Reflecting Surround...
EPSON EMP TW2000 COLOR MODE QUERY
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Oct 23, 2008 | Epson Office Equipment & Supplies
RCA LED55C55R120Q 55" 1080p 120Hz LED HDTV Black Logo
14 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
