Question about Acer Computers & Internet
Sound no audio output sound for window 7
  • 1738 Answers
SOURCE: Windows 7, HDMI output, realtek acl888, abit
I would back to windows vista or windows xp. Everytime MS release a new windows they always have drivers issue with audio and printers.
Posted on Nov 09, 2009
engg_cool_bo
  • 236 Answers
SOURCE: No Audio Output Device is installed
plz follow this link, there is a window will be open , paset comments which is present there and download drivers for ur windows 7. i hopw u will get the solution.
http://www.realtek.com.tw/downloads/downloadsView.aspx?Langid=1&PNid=24&PFid=24&Level=4&Conn=3&DownTypeID=3&GetDown=false
Posted on Nov 17, 2009
bronk50
  • 27725 Answers
SOURCE: the error says, "no audio output device is
if you are having problems with your sound
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps don
Posted on Mar 11, 2011
  • 16 Answers
SOURCE: since installing windows 7 I
You should go to your motherboard manufacturer's website and download the chipset drivers for your motherboard.
If you have a separate sound card you may need drivers for that too.
Posted on Mar 21, 2011
barbjaco730
  • 5 Answers
SOURCE: My Packard Bell Easynote Z94T laptop has no audio output after windows 7 upgrade - help!
Packard-Bell.DriverUtilities.com go to device manager and uninstall the current driver. prompt will then come up stating new hardware found and will ask you to chose a location to install from. go to P-Bell site and upload driver once in the download file you can open the driver file. I also suggest you go to Microsoft Security Essentials and run a quick scan of your computer( this will update virus definitions and remedy many latent computer issues.
Posted on May 21, 2012
No Audio Output Device Installed
might need to go in a do a system restore to a point before the upgarade
Dec 20, 2012 | HP Touchsmart 610-1030y 23" Lcd Desktop...
I wanna connect my laptop(lenovo G450) to samsung series 4 lcd through hdmi cable
A HDMI cable can output both audio and video, whilst some computer with Windows XP cannot automatically switch to HD Audio output as Windows 7 can. Thus manual setup can solve the problem.
After connecting the HDMI cable, Go to "Start" > "Control Panel" > "Sounds and Audio Devices", double-click "Sounds and Audio Devices. Select "Audio" tab on "Sounds and Audio Devices Properties" window.
On "Sound playback", change "Default device" from "Conexant HD Audio output" to "NVDIA High Definition Audio".
Your television should have several HDMI ports, select the appropriate HDMI port number and check if TV is not muted.
Hope this helps.
Jul 13, 2012 | Lenovo Computers & Internet
I converted my windows from XP to Windows 7, and now it says that my laptopd doesn't have an output audio installed.
Its an older laptop not supported by hp for windows 7, so you'll need to hunt for the driver or use a usb based head phone or speakers to output sound. You may want to look in a the vista/windows 7 audio drivers section of http://driverpacks.net/ .
Jul 22, 2011 | HP Compaq Business nx7010 Notebook
Audio problem. computer speakers are working beeps etc, but radio and video no sound
In Windows XP, go to:
Start -> Control Panel -> Sounds & Audio Devices -> Audio
Ensure that your sound card, and not a USB device, is selected for audio output as the default device.
In Windows Vista/7:
Ensure that 'speakers' is selected as the default device.
Alternatively, if the beeps are coming from the computer case itself, please clarify as such with a follow up response.
Mar 19, 2010 | Lenovo 3000 N500 Notebook
I have windows 7 running thru vmware fusion. i cannot get audio in the windows environment.
If there is is no sound output in Windows 7, simply run Windows Update to update the sound driver from within Windows 7.
If this fails however, try this procedure:
Click 'Start' > Select 'Control Panel' Type troubleshooting in the top-right search field > Select 'Troubleshooting' Click 'Hardware and Sound' > Select 'Playing Audio'
If a driver is needed, it is recommended that you run Windows Updates. If Windows Update doesn't install a driver for your device, go to your computer manufacturer's website and download/install the latest driver for your computer.
If this simple procedure does not help, reply back to this post and let me know.
Thanks!
-Mactechtrainer
Feb 09, 2010 | Apple MacBook Air
Nov 17, 2009 | Sony Computers & Internet
Computers & Internet Logo
13 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
