Question about Dymo LetraTAG Thermal Label Printer
Print fades over time - Dymo LetraTAG Thermal Label Printer
1815dn printing is faded
IF this is a high use printer, there are some other things that might be in need of attention. There is a corona wire, drum and drum wiper that are consumables too.
Mar 31, 2014 | Dell 1815dn All-In-One Laser Printer
Does an old PHD cause faded colors?
the PHD transfers the image to the printed page and when it starts to go bad the images can become dull or faded and even blurry or totally missing. Id recommend the PHD be replaced and it should resolve your issues.
Feb 24, 2012 | Dell 2135cn All-In-One Laser Printer
My CP1515n colour laser is giving faded colours.The left side of the print is very faded whereas the rest of the print is slightly faded
There are two reasons for faded prints. Firstly, faded print could be due to exhausting toner.
If it you have faded prints even after replacing the toner cartridge or if your current cartridge has enough toner, it is most likely be due to dust/ toner dust accumulated at the laser reflecting mirrors inside the printers,
which partially blocks laser beams and requires cleaning/ servicing by a professional.
Hence, it is recommended that you get the printer checked/ serviced from authorized service center.
Hope it helps! Good Luck!
CreativeTECH
Feb 26, 2011 | HP LaserJet CP1515n Printer
When typing the print is faded
Dymo LetraTAGs are thermal printers, so they don't use ink - just batteries and LetraTAG tapes.
When the print starts to fade it's time to put new batteries in. When the batteries are running out the text fades first even when the motor is still feeding tape.
Jan 31, 2011 | Dymo LetraTAG Thermal Label Printer
Faded printing. all cartridges full. Ran through cleaning routine several times.
You seem to have clogged print heads. Try soaking cartridge in warm water for 10 - 20 minutes and see if that helps.
Nov 09, 2009 | Office Equipment & Supplies
Faded text every few lines- Canon printer
When you print photos you print in Max dpi, for this no faded lines anywhere. Probably you have a problem only in black color in print head.
Мay be it's partially clogged or partially defective.
Sep 28, 2009 | Canon i850 InkJet Photo Printer
Light or Faded Areas in Solid Color Prints
If the issue is occuring in the same place on all prints, try the imaging drum (can't remember if this printer even uses one) or the transfer belt/roller (not sure which it uses). If you phone Dell support, they should run you through troubleshooting and send you either of those parts free of charge if you are under warranty. If not, buy them anyways; they don't degrade over time (if kept in the dark) and can be saved for when the currently installed one runs out if you don't need it to fix this issue.
Nov 27, 2008 | Dell 3010cn Laser Printer
Sharp AL1641 prints faded
The toner cart. has been in for a long time, has plenty of toner in it, it has been refilled 2 times.
Sep 17, 2008 | Sharp AL-1641CS Laser Digital Copier
Faded print on one side of page
I have a SCX-4100 Samsung, replaced the tonger cartridge, it was working fine for a few hundred sheets of printing, but after that, the left side of the page was printed very light, faded.
If I run the "Clean Drum", it will print a litter better, but still faded.
What can I do to correct this problem?
Thank you
TT
Nov 24, 2007 | Samsung ML 1710 Laser Printer
Dymo LetraTAG Thermal Label Printer Logo
21 people viewed this question
Top Dymo Office Equipment & Supplies Experts
Jax Planet
Jax Planet
jdthefixer
Are you a Dymo Office Equipment and Supply Expert? Answer questions, earn points and help others
