Question about Dell Ethernet Card Network Adapter
Will the belkin N wireless Router be compatable with Dell 8250
  • 10,515 Answers
yes Its compatible .
Thanks. :)
Posted on Jun 18, 2009
Do i need a modem? if so which are compatible?
When you speak to Comcast you should see if they are providing you with a wireless modem/router that will be everything you need.
If so, you will not need the Belkin router as Comcast will supply you with the hardware you need. If they only give you a modem, your Belken wireless router should work fine with the Comcast modem.
Hope that helps!
Jul 25, 2013 | Belkin N Wireless Modem-Router F5D8633au4A
I have a Belkin wireless router connected to a Virgin modem. Always has worked fine with a Compaq laptop and 2 Dell Inspiron netbooks with excellent signal. Now have tried to connect with an Acer Revo rl...
The router is designed in such a that it is compatible with all the computers. The best way to get rid of this issue is log into the router interface and change the wireless channel to suit your requirement.
1) To begin with.. Open internet explorer on a computer connected to the router and delete everything from the address bar and type http://192.168.2.1 and hit enter. Now you will be in the Belkin Router setup. It will ask for a login password when you click on anything.. Leave the password field blank and click on submit. 2) Towards the left side under wireless click on "Channel and SSID". Now you see wireless channel change it to different channel and click on "OK / Save". Now check the signal strength in your Acer computer. If its still the same try different channel and check.
Hope this helped.
Feb 22, 2011 | Computers & Internet
What access point product should I use with my Belkin N wireless router. I have dead spots in the house
For optimal compatibility, make sure you use a Belkin router or access point for this.
Jul 06, 2010 | Belkin N1 Wireless-N Wireless Router
I have a macbook pro and I am having problem connecting wirelessly to a Belkin Wireless Router N. None of my roommates have problem connecting and I can connect wirelessly everywhere else on campus but not...
Most hotspots are using b/g protocol for the widest compatibility with other hardware. Your macbook pro may not be able to connect tot he Belkin router if it's only broadcasting the N protocol. First verify which protocol the Belkin router is using. If it's broadcasting N, try changing it to use b/g and see if you can connect. I seem to recall that the earlier macbooks needed an update to be N compatible.
Sep 21, 2009 | Belkin (F5D8231-4) Wireless Router...
Setting up a w.less repeater using an old w.less b.band router
Temporarily plug in wire network cable into Dell and log into Dell.
1. Set wireless up the same as the Belkin. Save these settings.
2. Set WAN to "Static IP Address and give it an address about 25 higher than Belkin. (Belkin 192.169.0.1 - Del 192.168.0.26). Save these settings.
3. Disable DHCP and Save these settings.
Exit web browser and disconnect network cable. Restart your complete system, first the Belkin, then the Dell, then your computers.
This way, the Belkin is running and able to assign IP addresses to all that start after it.
Jun 11, 2009 | Dell TrueMobile 2300 Wireless Broadband...
Dell Ethernet Card Network Adapter Logo
61 people viewed this question
Alun Cox
