Question about Traxxas Toys
Traxxas resetting throttle servo - Traxxas Toys
How to reverse throttle servo
switch the button on the bottom of controller it will say reverse throttle
Sep 18, 2011 | Traxxas Toys
I have a tmax 3.3, and I was driving it and ran into a curb and the engine rev'd up to high rpm and wont stop, when I start it up it still runs at a high rpm and it will not move, but when I pick up the...
Check the throttle servo linkage to make sure it is not damaged or binding. Also make sure that the throttle servo is going back to neutral position and did not get damaged.
Aug 16, 2010 | Traxxas T Maxx 3.3 Monster Truck
Traxxas tq controller has steering reversed. Left goes righ and vice versa
Towards the bottom of the controller there should be two small switches. One switch will be for the steering servo and one for the esc. Channel 1 should be for the steering servo, move that switch and that should correct your problem.
Aug 14, 2010 | Traxxas E-maxx Evx-2 Monster Truck
I cant turn it
If it has just happened all of a sudden without no impacts, first of i would check the receiver & make sure steering servo is plugged in. Then test servo, could swop throttle with steering to see if still happens.
Aug 11, 2010 | Traxxas T Maxx 3.3 Monster Truck
When i start my tmaxx it tries to take off by itself wide open i cant stop it just keeps going
Hi
Assuming the transmitter is still set correctly then the problem is either your receiver is defective or your throttle servo is defective and/or both. Don't start the engine but switch the servo wires. If the switched servo now doesn't work then your receiver is bad, if it does work then the other servo is bad. Good luck
May 03, 2010 | Traxxas T Maxx 3.3 Monster Truck
Hello! I just installed a Traxxas Link 2.4ghz
did you check your servos
Mar 08, 2010 | Toys
My trx 3.3 idles fine but when you turn the remote on it takes off
you either need to adjust your servo or your idle screw on your controller. when you turn your remote on, it's opening up the throttle causing it to take off. turn on your remote without starting it and if you cant get it to the idle position with the trim screw on the controller, adjust your servo linkage so that it does.
Jan 15, 2010 | Traxxas Rc Revo Nitro Monster Truck
My nitro rc traxxas truck is not turning what do i do?
Check servo saver to make sure it has not loosened up. If the servo is not trying to turn at all check the connection at the receiver. If it is okay, you can always switch the steering and throttle servos at the receiver to rule out the possibility of a faulty servo. They can fail if they get too wet or get hit hard enough.
Dec 27, 2009 | Traxxas T Maxx 3.3 Monster Truck
How do you change the throttle servo on a revo 3.3
Disconnect the servo at the receiver, remove the servo horn and linkage from the servo. Remove the four screws that hold the servo to the chassis. Replace with new servo, plug new servo into receiver and turn on transmitter and receiver. With transmitter and receiver on reattach servo horn and linkage. This will make sure that the servo is centered at neutral throttle.
Sep 25, 2009 | Traxxas Rc Revo Nitro Monster Truck
Toys Logo
18 people viewed this question
Top Traxxas Toys Experts
Michael Brisco
Level 1 Expert
cwradio73
Are you a Traxxas Toy Expert? Answer questions, earn points and help others
