Question about HP Office Equipment & Supplies
Files explorer cannot find files explorer on my computer
How do i restart file explorer, I can`t get into some apps. must restart file explorer
restart computer would be the way to go there....if problem persists then you may have another problem but heres a link for you to look at...
http://www.ubergizmo.com/how-to/restart-windows-explorer
May 08, 2017 | Computers & Internet
Tip
Desktop Short Cut Missing
Hello,Some times your Desktop shortcuts or Start Menu Disappeared.It is happening due to Error Occurred in Explorer.exe. You can Clear this Error without Formatting.Just Do Following..
  1. Copy "explorer.exe" from other clean computer (from C:WINDOWS)
  2. And Paste it In your computer go to C:WINDOWS
  3. Show hidden files from (Tools - Folder Options - View - Show hidden files and folders)
  4. Delete existing 'explorer.exe' and any other files start with explorer...
  5. Put the new file (explorer.exe)
  6. Log off / Restart
  7. Log on
OR Just try this Solution.Close all your Opened Windows/Programs(OR Restart PC). Just Run this Dos File.It will Restore your Desktop Surely.. I/we need your valuable Feedback...Keep Using FixYa
Check this Link............. "Unable to Open Theme Corrupted" in Nokia 6300 Click here
on Apr 11, 2010 | Computers & Internet
Tip
How to Restore Disabled Folder Pane in Windows Explorer
Problem:
When you open Windows Explorer, the left hand Folders pane is disabled or gray or blank and the folder tree on left is not available.
Cause:
There may be an error in the registry. A required system file is missing or an incorrect version.
Solutions:
Close Windows Explorer.
Start the Registry Editor (click Start, Run, type regedit and click OK).
Expand HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\Main.
In the right-hand pane, locate the value named ExplorerBar. If present, delete it.
Restart Windows Explorer. If this does not resolve the issue,
The correct solution depends on the version of Internet Explorer that is installed on the computer.Internet Explorer 5.5 or lower
The preferred solution for computers with Internet Explorer 5.5 or lower is to upgrade to the latest version of Internet Explorer.
If this is not possible:
Open the folder C:\Windows\System. Check that the file browseui.dll is present. If it is not present, restore this file.
Internet Explorer 6
Open the folder C:\Windows\System. Check that the file shdocvw.dll is present. If it is not present, restore this file.
Open a command prompt.
Enter the command cd \Windows\System
Verify that the command prompt shows C:\Windows\System.
Enter the command regsvr32 /i shdocvw.dll.
Enter the command regsvr32 /i browseui.dll.
A message will appear confirming the successful registration of the files.
Now restart the sytem and confirm the problem is solved.
on Jan 17, 2010 | Computers & Internet
Where do I find my computer
  • You can open File Explorer by swiping in from the right edge of the screen, tapping Search
    If you're using a mouse, pointing to the upper-right corner of the screen, moving the mouse pointer down, and then clicking Search), entering File Explorer in the search box, and then tapping or clicking File Explorer.
Nov 18, 2014 | Toshiba Computers & Internet
Using usb stick
First you will have either copy and pate the movie or download it to your usb drive
One of the benefits of putting files on a USB flash drive is that you can make any type of file portable.
This includes not only documents, spreadsheets and photos, but also media like video clips and movies.
If you have movies saved on your flash drive that you want to view, watching the movies directly from the USB drive is a simple process and can be achieved on almost any computer.
Connect your USB drive to the device on which you want to watch your movies.
This includes all USB-compatible computers, as well as some select television-compatible devices (like the PlayStation 3, Xbox 360 or Sony Media Extender).
Launch the file explorer application on your device.
In Windows, access this utility by accessing the "Computer" application and then double-clicking the USB drive to display the files.
If you are trying to watch the movie files on a compatible television device, look for a "media," "device" or "USB input" application or button to bring up the file explorer.
Select the movie file you want to play.
In Windows, do this by double-clicking on the file.
The appropriate media-handling program should automatically launch and begin playing the movie automatically.
If you are using a television device, select the file from the list of compatible files in the device's internal explorer system.
hope this helps
Oct 15, 2012 | Computers & Internet
Free computer instructions on how to save a document on a usb flash drive
Assuming the thumb drive is working and the computer's ports are working and has sufficient space, you use the drive like a floppy disc. Plug it in and wait until the computer recognizes it. Either edit the document in the appropriate program and then save it to the USB drive (for most File > Save As, choose location and name the file (if needed) and then click Save or OK).
Alternatively, use the File Explorer (in Windows) and navigate to the directory where the file is stored (Computer (My Computer) > Users/(user_id)/My Documents (or My Pictures or whatever folder) is the default for many applications these days). Left click on the file and drag to the USB drive on the left column (under Computer); it should default to asking if you.
You can also can right click to select move or copy. (Using two File Explorer windows (one for the hard drive's directory and one for the thumb drive) is also an option and will let you check the dates on the file(s) if you want that information and have File Explorer giving the details.)
When done, click on Safely Remove Hardware (in the taskbar) or right click and select Eject (in the File Explorer). When the computer signals that you can remove the drive, do so. (If you skip this step, you may remove the drive while data is being written and loose part of the document.)
I hope this helps.
Sep 07, 2010 | Dell Inspiron 531s Desktop Computer
I want to get the solutions menu up on my new hg computor
Follow these steps to the menu up
1- copy "explorer.exe" from other clean computer (from C:\WINDOWS)
2- in your computer go to C:\WINDOWS
3- show hidden files from (Tools - Folder Options - View - Show hidden files and folders)
4- delete explorer.exe and any other files start with explorer.
5- put the new file (explorer.exe)
6- log off or restart
7- log on
Thank you
Mar 21, 2010 | Canon PIXMA MP240 All-In-One InkJet...
Internet Explorer keeps closing me down
Solved the problem with explorer/tools/advance/ reset explorer and everthing was fine.
Mar 12, 2009 | Microsoft Internet Explorer 8
Explorer.exe Application error when ai files show at windows.
there is a great possiblility that your explorer.exe is corrupted by existing virus in your computer. purchase or update you antivirus program and scan your computer immediately.
Dec 04, 2008 | Microsoft Windows XP Professional
11 people viewed this question
Seeker5211
Seeker5211
