Question about Whirlpool Duet 4.0 cu. ft. Washer
Error code F6E1
Please help me with what this error code means. Washer quits 1/2 way through the first drain cycle and will not reset. Only after I **** the water out with my shop vac, but then gets stuck in the same place.
SolutionGuy
  • 331 Answers
SOURCE: Whirlpool Duet HT Front Load Washer
The hum you hear is the drain pump trying to get the water out of there, but it can't for one of two reasons. 1.) It's jammed by debris (pillow stuffing material, underwire from a bra, etc...) 2.) The pump itself has failed. UNPLUG THE WASHER! You'll need to remove the three screws that are located below the bottom front panel. (Do this easily by leaning the machine backwards toward the wall and propping the 2 front feet up with a brick or the 4" side of a 2x4) These screws are star shaped, called "Torx" screws, size #20. After you have those removed, pull the panel downward and pull out from the bottom at the same time, then set the panel aside. Mounted to the floor of the machine near the center is the drain pump, see the hose coming out of the bottom of the tub and into the pump? That one will HAVE to be clamped off before you continue. Use 2 open end wrenches and a pair of vice grips... use the wrenches to pinch off the hose and the vice grips to clamp the TIGHTLY into place. Now remove the drain trap cover. Rotate the hand grip counter-clockwise several turns and pull it toward you. (*THERE WILL BE SOME WATER COME OUT EVEN THOUGH YOU HAVE THE HOSE CLAMPED OFF. HAVE TOWELS READY) Use a flashlight and your fingers to inspect the pump area, remove any debris you find. Make sure it's COMPLETELY cleared out. Then re-install the drain trap cover next remove your hose clamps. Plug your machine back in and set it to "spin only" and engage. You should hear the pump fire up and water being evacuated. Is so? You did it! Rebuild everything. Job time= ~45 minutes. If not, you have a bad pump and it should be replaced. The part # is 280187 and list for ~$115.00 at your local appliance parts retailer. Good luck! Please post back.
Posted on Aug 13, 2007
jsrock516
  • 5911 Answers
SOURCE: Whirlpool Duet Washer
The error code is an indication of a slow drain, or no drain problem. Before you assume you have a component failure with the washer, however, the manufacturer recommends unplugging the appliance for at least 30 minutes. Sometimes this is all that is required to reset momentary glitches with the computer. If the error code reappears, then you will need to check your drain pump. The following link explains how:
http://www.fixya.com/support/r385845-checking_drain_pump_in_whirlpool_duet
In addition, you may want to check the drain hoses to ensure they are not clogged or kinked. The hose leading from the bottom of the wash tub to the inlet side of the drain pump is a common place that I have found small articles such as socks, underwear, and washcloths lodged. For this reason, it is recommended that you use garment bagfs for small items.
Now, if you perform all the preliminary checks above and still have a problem, you may have to replace the pump. It does not take much to damage the drain pump in these model washers. If anything has been lodged in the pump for any length of time the pump impeller and/or motor may be damaged. The pump may still run, but it might not be pumping any water.
If you require a replacement pump, they can be ordered on line at searspartdirect.com. Just type in your model number and the pump is located under the "Pump and Motor Parts" heading as item number 10 (part #8181684). The next link provides you with step-by-step instructions on how to replace the pump, if necessary.
http://www.fixya.com/support/r401845-replacing_drain_pump_whirlpool_duet
I hope you find this information helpful. Let me know if you require additional assistance.
Posted on Sep 13, 2008
abhishek33
  • 1239 Answers
SOURCE: whirlpool duet washer f-27 code error
hi Most washing machine timers are digital or mechanical. The timer controls most of the operations of the washer: water level, tub filling and emptying, length of cycles, and cycle setting sequences. For this reason, any repairs to the timer should be made by a professional service person. However, there are a couple of checks you can make when you suspect the timer is faulty -- you may be able to install a new timer yourself.
Step 1: Unplug the washer. To access the timer, remove the control knobs and the panel that covers the controls. This may be a front panel, or access may be through a panel at the back of the unit. Carefully examine the wires that connect the timer to the other parts of the washer. If the wires are loose or disconnected, try pushing them into position; they usually fit into their terminals like plugs. Use long-nosed pliers to avoid breaking the wire connections -- never pull a wire by hand.
Step 2: To test the timer, use a VOM set to the RX1 scale. Disconnect the power leads to the timer and clip one probe of the VOM to each lead. The VOM should read zero if the timer is working. Since the timer is a multiple switch, turn it through its cycle and test each pair of terminals in turn. The meter should read zero at all of these points. If one or more readings are above zero, the timer is faulty and should be replaced.
Step 3: To replace the timer, unscrew and disconnect the old one. Install a new timer made specifically for the washing machine. If there are many wires on the timer, have a helper hold the new timer next to the old one as you work. Disconnect the old wires one at a time, connecting each corresponding new wire as you work, to make sure the connections are properly made. Or, draw a diagram showing the connections before removing the old timer. After all the wires are connected, check the connections again for correctness and screw the timer assembly into place.
Posted on Nov 06, 2008
blueextc3221
  • 15935 Answers
SOURCE: washer will not drain, just hums then shuts down
If you put it on wash - does it agitate?
If not - Most likely the coupling is failed.
Any way you look at it - you will need to empty as much water out as you can - because to replace the coupling - the pump must be disconnected.
CLICK HERE to see the coupling.
Another telltale sign of a failed coupling are black rubber bits, and plastic pieces under the washer when you tip it up.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Oct 01, 2009
SOURCE: Whirlpool Duet Washer-error code "sud"
Just take off the bottom kickplate (3 screws on the bottom). You'll see the pump front and center. Twist the front face of the pum slowly to the left. All the trapped water will flow right out towards you. There could be a sock or some other debris there. Unclog, screw that faceplate back in and start it up.
Posted on Jan 16, 2011
What is Error Code "F6E1"
I had the f6 e1 code flashing on Whirlpool Duet washer. It would stop midcycle and beep. I cleaned out the lint filter. This seemed to help but gradually the problem got worse. I cleaned filter again. Still beeping. I read more solution and finally found the answer! I never put the cover back on. There is a switch on the left bottom that is held in by the cover. Works fine now!
Jan 14, 2012 | Whirlpool duet Washing Machines
Le keep coming on
dfgf
dSorry to read about your problem, I hope this helps you out.Is this a new installation?
In new installations, this error can sometimes present because of a miscommunication between the control panel and the wash motor. In this instance, the washer simply needs to be reset.
Step 1: Unplug the washing machine.
Step 2: While the washer remains unplugged, press and hold the [Start/Pause] button on the front panel for 5 seconds.
Step 3: Plug the unit back in, and run a rinse and spin cycle to test if the LE code is cleared.
Has a large load size been used with a gentle wash setting?
Gentle wash cycles such as Perm Press, Delicates, Hand Wash, and Wool/Silk should only be used for smaller loads. Because the cycles are more gentle while tumbling and spinning, too many items in the drum can register as an issue with the motor. In this instance reset the unit and run a test rinse and spin cycle.
Has the washer been overloaded?
Single bulky items or large loads can add extra weight to the drum and place stress on the motor. Remove some of the clothing and restart. If the issue is still present after a few items have been removed, unplug the washer for 30 minutes to allow the motor to cool and then restart the cycle.
NOTE: Make sure the drum is not overloaded
Are there soap suds visible in the drum?
Over-sudsing is the main cause of LE error codes. Using non-HE (high efficiency) detergents or too much detergent will cause stress on the motor. In addition, detergent residue can also cause leaking and odor. Follow these steps to resolved an LE error code caused by over-sudsing.
Step 1: Unplug the washer and allow the unit to sit for 30 minutes to give the suds time to dissolve.
Step 2: Plug the washer back in and press [Power] to turn on the washer.
Step 3: Do not choose a washing cycle. Press the [Spin Speed] key until "No Spin" is selected.
Step 4: Press [Start/Pause] to begin a drain only cycle.
Step 5: After the drain only cycle has completed, remove the clothing items from the machine. Turn the power back on and select [Rinse and Spin] and then press [Start/Pause]. This will remove excess soap suds and light residue from the drum. Repeat this step until no visible suds are in the drum of the washer.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
1 Thumb - Not Helpful
3 Thumbs - Helpful
Jan 02, 2011 | LG Washing Machines
1 1/2 year old lg WM2496H showed oe error code while washing a heavy unbalanced load. I removed the wet blanket (sitting in water) and tried drain/spin command with empty washer but washer will not go into...
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code..
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!!!!!!!!!!!!!!!!!!
Jun 09, 2010 | LG WM2496H Front Load
Problem draining. Getting 5d code.
Hi
Thanks for using FixYa. Error 5d means too much detergent was used. Try the following procedure---
Run the unit through a RINSE/SPIN cycle.
Run a NORMAL cycle without adding any detergent.
This should clear the unit of the excess detergent. If still the problem persists, then please check the following things--
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the drain pump, pressure switch, and Central Control Unit (CCU).
4. Check/clean drain pump filter of foreign objects.
5. Plug in washer or reconnect power.
6. Check drain pump.
7. Check the pressure switch.
8. Verify CCU operation by running a Diagnostic Test or any cycle.
Please do rate the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jun 07, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore front load washer error code E 10 - washer stops and beeps periodically and needs to have start button pushed again to complete cycle. Seems to happen one minute into cycle and then a coupleof...
1 Beep/E10--Error: Water doesn't enter Cause: Water supply problem, Check kinks and faucets
1 Beep/E10--Error: Water leaks Cause: Water connections loose,household drain clog,oversudsing. Correct problems.
1 Beep/E10--Error: Dispenser drawer is open Cause: Washer will not operate if drawer is open.
Jan 11, 2010 | Kenmore HE2 Plus Front Load Washer
My LG Clothes Washer has stopped mid cycle and is displaying an "OE" error code. How do I get the machine to finish the cycle?
oe means drain error (outlet error)
Poss causes:
drain hose kinked,
filter blocked,
pump impellor blocked.
Hope that Helped
Please Rate Me
George
Apr 29, 2009 | LG WM2688HWM TROMM SteamWasher
Kenmore Calypso washer Ld code?
I just had the same problem. I borrowed my neighbors wet vac. The hose of the wet vac fit right over the end of the drain hose and I sucked out all the remaining water. My hope was that if the hose was clogged that it would clear it out. It seems that it worked. I put the drain hose back in the drain and turned on the extended spin cycle. It was working, so I put the water logged clothes back in the washer on the extended spin cycle and it took the water out. I am now in the process of washing another load to see if it really fixed the problem. I hope this helps.
Jan 18, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Duet 4.0 cu. ft. Washer Logo
Dan Webster
Dan Webster
Sal De
